Author Topic: 3mm vs 5mm ocillation  (Read 1500 times)
Offline mike221
« on: October 31, 2017, 12:07 PM »
What is the difference in function between 3mm and 5mm oscillation?
Offline Festool USA
  • Festool USA Employee
    FOG Administrator
    • Festool USA
Re: 3mm vs 5mm ocillation
« Reply #1 on: October 31, 2017, 02:27 PM »
5 mm will be more aggressive and faster for stock removal. Using 3 mm is less aggressive and better for finishing your finish or sanding in-between coats. Most of the time, 5 mm is what people will need.
(Tyler)
Offline Sparktrician
« Reply #2 on: October 31, 2017, 05:05 PM »
An ideal combination might be the RO 150 and an ETS 150/3 to get the best of both worlds...
- Willy -
Offline Holmz
« Reply #3 on: November 01, 2017, 06:25 AM »
What are you doing with it?
Big sheets, small pieces, corners, etc?
One is primarily for finishing work, or the other is more general purpose.
Offline bulubuluplopplop
« Reply #4 on: November 01, 2017, 07:57 AM »
of course having both is the best.
I have found that finishing sander (I have a festool ETS125) does not work very well with coarse sand paper (like 40 and 60), i.e. it does not sand faster than with 80 sandpaper (I use only abranet).
However, 5mm sander are in general heavier and less ergonomic to handle (more vibrations etc...). The wear on the sandpaper (specifically the edges) is also much quicker than with 3mm sanders.
So I use a (cheap) 5mm sander for 40-80 grid, and a 3mm sander (festool ETS) for 80-220.
Offline HarveyWildes
« Reply #5 on: November 01, 2017, 08:04 AM »
That's the route I took.
Offline Lettusbee
« Reply #6 on: November 01, 2017, 11:53 AM »
What is the oscillation on the Pro 5 sander?
Offline blaszcsj
« Reply #7 on: November 01, 2017, 11:57 AM »
Dis is the combo!
OF1010 EQ Router | MFT/3 | DF500Q | Carvex 420 | ETS EC 150/3 | CT 36 Auto Clean | TSC55 | LR32 | OF1400 EQ Router | ZOBO Metric Set | CXS Li 2.6 - 90 Limited Edition | Universal Cleaning Set | HKC55 | Centrotec CE-SORT | RO150 FEQ | DTS 400 | RO90 DX | CTSYS | C18 Drill | SysLite KALII | Syslite STL 450 | RAS 115 E
Offline Holmz
« Reply #8 on: November 01, 2017, 06:26 PM »
You'all fan boys don't even know what the person needs to sand and you already have the RO as the ideal sander.
@Lettusbee more like "square root of 5" being somewhere in the 2 to 2-1/2 range (I think).
Offline antss
« Reply #9 on: November 01, 2017, 06:39 PM »
2mm
