Author Topic: Centrotec bit for Kreg Bit and DowelMax bit  (Read 2252 times)
Offline webpp
« on: August 28, 2017, 09:09 PM »
Does Festool sell any Centrotec bit that works with the Kreg Jig and DowelMax?
If so, link and detail would be much appreciated.
Offline RobBob
Re: Centrotec bit for Kreg Bit and DowelMax bit
« Reply #1 on: August 28, 2017, 09:14 PM »
Snappy makes a 6" square drive bit.  Atlas also makes Centrotec square drive bits, but they are only 4" long.  Don't know about imperial drill bits.
Scroll down for the 6" Snappy square drive.
Cetrotec Square Drive Bit
« Last Edit: August 28, 2017, 11:43 PM by RobBob »
Offline webpp
« Reply #2 on: August 28, 2017, 11:10 PM »
What about a 3/8" and 1/4" drill bit in Centrotec so that I can use it with the Dowelmax.
Offline Svar
« Reply #3 on: August 28, 2017, 11:16 PM »
Festool had a limited run of imperial sizes drill bits in the installer set. Might work for DowelMax, but not for Kregg jig. Not available any more anyway.
Try Snappy, a US company that makes Centrotec compatible bits.
« Last Edit: August 29, 2017, 12:04 AM by Svar »
Offline Festool USA
  • Festool USA Employee
    FOG Administrator
    • Festool USA
« Reply #4 on: August 29, 2017, 08:14 AM »
No, that is not something that we have available at this time.
Offline Richard/RMW
« Reply #5 on: August 29, 2017, 08:52 AM »
@webpp - you could try modifying standard 1/4" bits as discussed here.
RMW
Online Cheese
« Reply #6 on: August 29, 2017, 09:06 AM »
This is probably what you're looking for to use in the DowelMax. However, as Svar noted, it was a limited production kit, run about 2 years ago, P/N 201312.
The problem then was, and still is, that Festool never made individual replacement drills available. So if you lost one or damaged one, well that's just too bad...they called it tough love. [sad]
Offline SRSemenza
« Reply #7 on: August 29, 2017, 12:03 PM »
Snappy makes a 1/4" (also available in a set), and 3/8" centrotec bits (not in the set). Shop the net to find them. But no step (?) drill bit for the Kreg.
Offline skinee
« Reply #8 on: August 29, 2017, 04:03 PM »
for a kreg drill bit the following is centrotec compatible,its from axminster here in the U.K. a very reputable company,many on here from the US and elsewhere have ordered from them and found shipping easy and inexpensive I believe,you will also be able to deduct 20% from the price(sales tax)as you are outside the U.K.
   http://www.axminster.co.uk/ujk-technology-pocket-hole-drill-bit-hex-shank-103397
Offline TSO Products
    • TSO Products
« Reply #9 on: August 29, 2017, 09:32 PM »
does anyone know of a source for individual 20mm CentroTec bits in the US or elsewhere?
Hans
TSOproducts.com
Home of the GRS-16 and GRS-16 PE  plus TPG Parallel Guide -  the MTR-18 Triangle and Work Holding solutions plus AXMINSTER UJK in the USA
Online Cheese
« Reply #10 on: August 30, 2017, 09:13 AM »
Brad point bit or Forstner style bit?
Offline Richard/RMW
« Reply #11 on: August 30, 2017, 10:44 AM »
@TSO Products  - Hans, you may want to contact Fisch, they seem to have a lot of Centrotec compatible stuff.
RMW
    • TSO Products
« Reply #12 on: August 30, 2017, 10:45 AM »
same style as sold by FESTOOL in sets -( which I have not seen)
Hans
TSOproducts.com
Online Cheese
« Reply #13 on: August 30, 2017, 12:01 PM »
That'd be a brad point then.
