Pages: [1]   Go Down
  Print
Author Topic: Changing 8mm collet to 1/4  (Read 1709 times)
suds
Offline Offline
« on: March 31, 2012, 12:01 AM »
I convinced my buddy to buy the OF1010 and he called me to let me know his 1/4 bits don't fit. Since I have the 1400 I was a bit perplexed.  He said there was a 1/4 collet in the systainer but he has no clue on how to change them and surprisingly there's no mention/instructions.  He's prying on things so I told him to hold on till I could see if anyone knows how to change out the 8mm for the 1/4?
MFT's, Kapex, TS 55, Vac, 150 Rotrex, 300 Trion, Domino
PaulMarcel
Online Online
WWW
« Reply #1 on: March 31, 2012, 12:10 AM »
It just unscrews, right?  I don't have a 1010 to know, but every router I've seen just unscrews the collet.  Lock the spindle, though.
Shirt size: L Cool
Twitter: @HalfInchShy
jlyons
Offline Offline
« Reply #2 on: March 31, 2012, 12:19 AM »
yes just unscrew it.  the only thing i can think of is it is at that last spot where you need your wrench again before it comes right off.  hope that makes sense.
Alex
Offline Offline
« Reply #3 on: March 31, 2012, 04:27 AM »
I found this in the OF1010 manual that's on the USA website:
suds
Offline Offline
« Reply #4 on: March 31, 2012, 07:41 AM »
He says he's fully unscrewed the collet nut and the 8mm cylinder won't budge. He's hesitant to grab it with pliers but has tried to wedge it out with a screwdriver tip. He's talking about the 8mm collet cylinder that's not coming out.
« Last Edit: March 31, 2012, 07:52 AM by suds » Logged
Peter Parfitt
Magazine/Blog Author
Online Online
« Reply #5 on: March 31, 2012, 08:01 AM »
When I have had sticking collets I have been able to release them by thumb pressure at an angle to the nut. If this fails do not use pliers. Try using a flat piece of soft metal (aluminium) rod to gently tap the collet. The nut should be supported of course.
Kapex 120, OF 2200, OF1400, TS55, TS55R, CMS-TS55R, PSC420, Domino 500, MFT3, Rotex 90, Rotex 150, CTL26, 1400 & 2700 Guide Rails and a lovely watch
Wish List: C15, HL850, BS75, DF700, Second Extractor, new secretary
JimB1
Offline Offline
« Reply #6 on: March 31, 2012, 08:30 AM »
After unscrewing the collet, I've just tapped mine side to side a couple of times with the wrench. Usually comes right out after two or three taps just hard enough to get it away from the wall of the shaft a little. Seems like the collets go in tight enough that it makes a friction seal. Great to help the bits stay in tight, not so easy to change collets...
Instructions seem to be Festool's weakest point.
-Jim
« Last Edit: March 31, 2012, 08:32 AM by JimB1 » Logged
OF 1010, RO 150, ETS 150/3, RTS-400, Pocket StickFix Sanding Block and a CT Midi
suds
Offline Offline
« Reply #7 on: March 31, 2012, 11:54 AM »
Thanks guys.  Evidently when he got the router it had the 8mm collet installed and he didn't realize it was in there and tried to install the 1/4 in bit.  He tightened it all the way down which really wedged the 8mm in there.  Kind of like when they tell you in the instructions to not tighten without a cutter installed.  We were able to tap it out with a screwdriver and all is well.
Pages: [1]   Go Up
  Print
Jump to:
