Pages: [1]   Go Down
  Print
Author Topic: MFS 400 ?  (Read 1866 times)
Tom R
Offline Offline
« on: December 31, 2010, 11:44 AM »
What is the smallest circle the MFS 400 can cut with a OF 1010 router?
Please advise,
Tom R
Tim Raleigh
Online Online
WWW
« Reply #1 on: December 31, 2010, 03:14 PM »
Accurately: with a 1/8" up or down spiral bit in the circle routing insert: 82mm or 3 3/16" diameter.
Not accurately: With a 5/16" template guide held next to the side of pivot guide with a 1/8" up or down spiral bit: 23mm or 7/8" diameter
Tim
Tom R
Offline Offline
« Reply #2 on: December 31, 2010, 06:55 PM »
Thank you for the reply
I have to make several small circle cuts ranging from 72mmm - 94mm, accuracy counts. I am considering the MFS 400 or the circle gig from Micro fence. I believe the MFS
may be a more versital tool but the Micro Fence with the lift kit will be accurate and repeatible. I needed some input from someone who was familiar with the MFS 400
Thank you for the information
Tom R
Dovetail65
Offline Offline
« Reply #3 on: December 31, 2010, 07:03 PM »
Microfence all the way, IMHO.
JD2720
Offline Offline
« Reply #4 on: December 31, 2010, 07:34 PM »
I agree that the Micro Fence will work best for what you are wanting to do.
neilc
Online Online
« Reply #5 on: December 31, 2010, 07:36 PM »
I have both the MFS and Micro Fence.  For what you want to do, I think the Micro Fence is the better choice.
neil
Tom R
Offline Offline
« Reply #6 on: December 31, 2010, 10:56 PM »
Mr Tim,
 I was leaning towards the Micro Fence, just need more info - Festool does not publish enough specs
on there tools, need user input.
Thanks,
Tim Raleigh
Online Online
WWW
« Reply #7 on: January 01, 2011, 03:08 PM »
Tom:
As Brice Burrell recommends, if you are thinking of buying the 400 also buy the 700.
You will find you will use these things everywhere.
Tim
HowardH
Offline Offline
« Reply #8 on: January 08, 2011, 11:05 PM »
I love my 400!  I hardly ever use it for it's intended use - with the router.  It's a perfect oversized square and it also acts as big flag stop for making repetitive cuts on my MFT.  I simply butt it up against the fence and use a quick clamp to hold it in place where I want it.  I can think slide my stock under the rail and butt it up against the MFT and quickly make several identical parts.  Don't know what I would do without it.
Howard H
The Plano Texas Festool Fanatic!
Shelby Metcalf, basketball coach at Texas A&M, recounting what he told a player who received four F's and one D: "Son, looks to me like you're spending too much time on one subject."
mft1080, T15, RO150FEQ, TS55, RTS400, ETS 150/3, OF1400, CT22, CT33, MFS 400 & 700, Boom Arm, 800, 1080, 1400, 1900 rails CSX drill Qwas dogs
Pages: [1]   Go Up
  Print
Jump to:
