Author Topic: ETS EC 125/150?  (Read 29634 times)
Offline leakyroof
Re: ETS EC 125/150?
« Reply #60 on: January 24, 2017, 10:33 AM »
Anyone want to trade their ets ec 125 for my pro5 and an ets ec 150 without the pads?  Lol  [crying] [unsure]
You could easily sell those two and buy the ETS EC 125/3.
  True, esp. since the Pro5 is so hard to get still with Festool trying to catch up to the initial order.  [scratch chin]
Offline Holmz
Re: ETS EC 125/150?
« Reply #61 on: January 24, 2017, 06:01 PM »
This makes no sense to me.
If the ETS ETC 150 is 5-mm stroke, and the pro-5 is 2 or 3, do you really believe that you are going to want to switch out the base between course and fine sanding? That will get older than switching out router bits.
The 5-mm is not bad for finish sanding, and the smaller strokes are not good for taking material off quickly.
The only people what want one that does it all are those who do not want to spend the money for more sanders, but you are already invested
Or am I missing a key factor?
Offline AVO
Re: ETS EC 125/150?
« Reply #62 on: April 26, 2017, 03:42 PM »
After reading this post many times my question is related to reply #36 from Cheese that states one of the differences between the 125 and 150 is bearing assembly.  It seams to me that that would be an important difference???
First off... [welcome] to the FOG.
Now to your question, the ETS EC 125 & 150 use different pad mounting geometries, thus the 125 assembly is different than the 150 assembly only because of the different mounting shaft styles, that's the only difference. Check out the photos below and it becomes more obvious.
Hi
I have started a new tread about almost the same subject as here. But i think my question belong here instead. I have an old RO150E which has the shaft style without the wings. I can fit the wings-style pad on the RO150E, but the sealing lip ( or is that the brake ? ) is not touching the pad. What will that mean ? Bad dustcollection or ?
I cannot find the old style pads anywhere, and I have two 150 mm sanders and a lot of sandpaper :-/
Offline Distinctive Interiors
  • Modern Kitchen Specialist
    • distinterior.com
Re: ETS EC 125/150?
« Reply #63 on: April 26, 2017, 03:55 PM »
Avo, go and have a look on your thread you started. I have put a link up that you may find useful.
Tim.
Offline Eddy N.
Re: ETS EC 125/150?
« Reply #64 on: October 24, 2017, 08:29 AM »
Hello all of you,
first of all, i am new here and from the Netherlands, so please don't mind my language. I try to be as clear as i can be.
For this topic: when i look at the pictures at Reply #43 and compare the 2 discs (125 and 150 mm) I see that the only difference is/are the 2 cutouts on the 150 disc. Since I want to use the ets ec 150/5 with an 125 mm disc i am wondering if it is possible to cut out these 2 little cutouts of a 125 mm disc myself. Because in that case I will end up with an ets ec 150/5 with 125 and 150 mm pad. And I know that would be the same set up as the Mirka Deros, but to me it looks like the Festool is more dureable than the Mirka Deros.
Anyone have experience with adjusting the 125 mm pad?
Offline Holmz
Re: ETS EC 125/150?
« Reply #65 on: October 24, 2017, 06:25 PM »
The Festool 150 pad fits on the 125, but not the other way around.
No one has posted such a modification so have at it. Seems conceptually easy enough.
Since you are in Europe and have 230v the DEROS seems to be a good choice.
If you really like the Festool switch over the DEROS paddle then that would make sense too.
Mirka have been making sanders for many decades, so they could be more durable than they "look".
Offline JimmyFord
Re: ETS EC 125/150?
« Reply #66 on: March 12, 2019, 10:21 PM »
Long long time lurker, but this made me register an account.
Has anyone with the ets ec 125/3 using the 150mm pad had any issues arise from using the larger pad at all? I have the ets ec 125 and a couple days ago bought the 150/3 for table and desk tops... but if I can just use the 150 pad on what I already have... I just wanted to check in to see if anything has occurred with long term use of the larger pad before I ‘mod’ my favorite ROS lol.
Regarding the Mirka deros question, you can use the 5” pad on the 6” models (625/650) but not vice versa, and you can only use the 130g weighted pad not the standard 5” pad. Although they all fit all the pads, and seem to work, using the 6” pad on the 550 or the standard 5” pad on the 625/650 will prematurely wear out the machine.  I got the answer from the regional mirka rep for my area, but the weighted pad is only available in medium.
Online Cheese
Re: ETS EC 125/150?
« Reply #67 on: March 12, 2019, 11:10 PM »
 [welcome] to the FOG!
I purchased a ETS EC 125 when they first came out in 2016? I've swapped back and forth with a 125 mm and a 150 mm pad for the last 3 years and everything is fine. If you're hesitant, check out the Ekat files and you'll notice that all the electrical parts are the same.
Offline ScotF
Re: ETS EC 125/150?
« Reply #68 on: March 13, 2019, 12:14 AM »
Except the shaft is shorter on the 125 and so the brake doesn't seem to engage. I noticed the 150 pad spins freely and the 125 engages the brake. Not sure if it impacts performance, but something I did notice when I tested this week.
Online Cheese
Re: ETS EC 125/150?
« Reply #69 on: March 13, 2019, 09:38 AM »
Remove the 150 pad and see if maybe something is caught between the pad and the bottom of the shaft. Also check to see if there are any small burrs causing a problem. I just fired up my ETS EC with the 150 pad on and at full speed it takes 1/2 - 3/4 of a second to stop. Definitely less than a second.  [smile]
Offline JimmyFord
Re: ETS EC 125/150?
« Reply #70 on: March 13, 2019, 10:15 AM »
Thanks cheese, appreciate the response!
Online rvieceli
Re: ETS EC 125/150?
« Reply #71 on: March 13, 2019, 11:55 AM »
I’ve got an ETS EC 125 with the150mm pad on it and the brake on it works the way it’s duppoed to. Mine newer than Cheese’ manufactures 5-2018. So it still works.
 Ron
Offline ScotF
Re: ETS EC 125/150?
« Reply #72 on: March 16, 2019, 02:11 PM »
OK. I tried to put the new hard pad on my ETS EC 125 and the pad brake does not work - at all - regardless of the bolt. This is the newer style hard pad with all the extra holes - sander spins pad fine, but you shut it off and the pad just spins and spins until it eventually slows down - no brake engagement at all. I wonder if the newer style is slightly different than the older style hard pads and it now does not work as well as others have reported.
Online Cheese
Re: ETS EC 125/150?
« Reply #73 on: March 16, 2019, 02:35 PM »
I have the new pad on mine and it works fine.
Offline ScotF
Re: ETS EC 125/150?
« Reply #74 on: March 17, 2019, 02:14 AM »
Thanks. It fits, but definitely does not engage the brake for whatever reason. Weird. I bought a 150/5 so a moot point for the time being and that pad engages the brake the same as the 5 inch pad on the 125.
Online Cheese
Re: ETS EC 125/150?
« Reply #75 on: March 17, 2019, 02:37 AM »
I also made a video on my iPhone showing how effective the brake is but I’m unable to upload it to this website.  [sad]
Re: ETS EC 125/150?
« Reply #76 on: March 17, 2019, 09:17 AM »
Just read the official description of the sander, what does “active electronic vibration control” mean?
Offline ScotF
Re: ETS EC 125/150?
« Reply #77 on: March 17, 2019, 06:20 PM »
It slows the speed down if there is any vibration detected - speeds up once it is minimized. This happens all the time when I use an interface pad.
Offline jesse_le
Re: ETS EC 125/150?
« Reply #78 on: April 22, 2019, 10:45 PM »
I just purchased a ets ec 125/3 with a 150 pad it worked as suggested by @Cheese. Looking on the bottom of my housing, it does not show 150/3 rather just a 3.
