Pages: [1]   Go Down
  Print
Author Topic: New Blade For TS55  (Read 1176 times)
KevinW
Offline Offline
« on: May 25, 2010, 07:35 AM »
I need to replace original blade on TS 55.  I use saw to rip and cross cut plywood. Want to keep rubber strip on my guiderails unchanged. Current (original) blade is 491 952.  Is there an exact match for this blade that is available? Thanks
Kevin
Wood_Junkie
Online Online
« Reply #1 on: May 25, 2010, 09:47 AM »
Interestingly, the Festool USA site still lists that blade part number (491952) as the standard with the TS55.
http://www.festoolusa.com/products/plunge-cut-circular-saws/ts-55-eq-plunge-cut-circular-saw-specs-561174.html
However, it is not found by part number.
Maybe Shane will fix the above.    Wink
The current 48-tooth blade is here:  Item #495 377
http://www.festoolusa.com/products/plunge-cut-circular-saws/blades/fine-48tooth-saw-blade-495377.html
Current sale price comes to $55.35
Shane Holland
Festool USA Employee
FOG Administrator
Online Online
WWW
« Reply #2 on: May 25, 2010, 10:14 AM »
Oops, missed that part number on the specs page.  I have corrected it now.
We changed all of our saw blade product numbers not too long ago.  The only change was to the packaging, not to the blade.  As pointed out, the direct replacement for the stock blade is the 48-tooth (495 377).
« Last Edit: May 25, 2010, 10:15 AM by Shane Holland » Logged
Shane Holland | Festool USA | Sales: 888-337-8600 | Service: 800-554-8741 | sho@festoolusa.com
Faster. Easier. Smarter.
Power Tools, Domino Joiners, RRP HEPA Vacs, Track SawsDrywall Sanders, Cordless Drills, Tools for Painters, LED Worklamp, Router Tables
Pages: [1]   Go Up
  Print
Jump to:
