Author Topic: MFT cross brace supports  (Read 1373 times)
Offline Linbro
« on: November 05, 2017, 05:37 AM »
Hello,
Do the MFT 'cross brace supports' fit the small Kapex MFT style table?
Offline thudchkr
Re: MFT cross brace supports
« Reply #1 on: November 05, 2017, 07:43 AM »
The way they’re designed, I would assume they could be installed but don’t know if they could both be installed on the same side due to the legs of the the MFT Kapex being shorter as well as the smaller table size. Will try to measure later and post findings.
Clint
Clint
TSC 55, TS 55, TS 75, HKC 55, DF 500, DF 700, Kapex 120, UG Ext. Wings, MFK 700, OF 1010, OF 1400, OF 2200, CT 22, CT 26, ETS 150/3, ETS EQ 150/5, PRO 5, DTS 400, RO 90, RO 150, CXS, DWC 18-4500, MFT Kapex, MFT 3 (2), MFT 800, MFT 1080
Offline Linbro
« Reply #2 on: November 05, 2017, 04:08 PM »
Thanks Clint, appreciate it
Offline thudchkr
« Reply #3 on: November 05, 2017, 04:35 PM »
Just went and looked to see if the braces could be mounted on one side of the MFT Kapex similar to the way they mount to the MFT-3 and the answer is . . .  “Maybe”.
The crossbar on the leg assemblies is at the same location, so that wouldn’t affect the fit.
I measured the distance between my two mounts where the braces on my MFT-3 connect to the bottom of the rail to come up with a space of 290mm.
When I compared the rail lengths of the two tables, I came up with a 288mm difference. (Festool specs for the two also show 288mm of difference as well.
Those brackets are adjustable as to where they mount on the rail, so you can definitely make it work on one side. If the brace was a little two long, all one would need to do is slide the mount that attaches to the leg crossbar away from the leg until the brace fit.
Clint
Clint
Offline Festool USA
  • Festool USA Employee
    FOG Administrator
    • Festool USA
« Reply #4 on: November 06, 2017, 08:50 AM »
Yes, the MFT Cross Members will fit both the MFT/3 and the MFT/3-MINI. Thanks for your help, @thudchkr!
(Tyler)
Offline Linbro
« Reply #5 on: November 06, 2017, 03:22 PM »
Oh, great. Thanks Tyler and Clint.
