Pages: [1]   Go Down
  Print
Author Topic: T15 run-on  (Read 2288 times)
harry_
Offline Offline
« on: October 14, 2011, 01:41 PM »
I could have sworn there was a relevant thread for this,, damned if I can find it. Mods please feel free to bounce it over there if you know.
Anyway,... occasionally and unpredictably my T15 experiences run-on. Sometimes for several second and once for a good long time (I was curious). Since 90% of my current work has me using it in maple or oak when driving a screw, it doesn't really matter. However one time it was pine and my reflexes did not catch it before it went 1/2 way through a piece of 3/4 pine.
Is this a known electronics `problem` or is just a matter of crud having worked it's way into the case?
I know Festool service turn around time is awesome, but I don't really want to give up the drill for a week if I dont have to.
>yeah, yeah... call Festool. number is on the tool & on Shane's profile Laughing<
Rick Christopherson
Retailer
Offline Offline
WWW
« Reply #1 on: October 14, 2011, 06:45 PM »
This will happen when your battery is near dead and the back EMF does not engage the mechanical chuck lock pins. Next time you notice it happening, replace the battery and see if it still happens.
Oh, near-dead is not the same as dead, and that is why you might think it is not really predictable.
One more edit: I really noticed this when I was chasing some threads after powder coating. The battery had more than enough power to drive the tap without slowing, but did not have enough power to provide the back EMF to lock the motor (and therefore lock the mechanical pins). This left the gear box to coast to a stop instead of locking to a stop.
« Last Edit: October 14, 2011, 06:57 PM by Rick Christopherson » Logged
ccmviking
Offline Offline
WWW
« Reply #2 on: October 14, 2011, 06:48 PM »
     Happened twice on mine Harry... I could make mine repeat over and over.  Didn't do it every time, but maybe every 5-10 or so trigger pulls.  You should be able to mimmick it just free air pulling the trigger and letting off.  It's a bummer for sure, but sending it in is the only way to remedy it.  Do like I did and just buy 3 C-15's so you have backup for your backup.  I'm j/k about that, I just keep two in the trailer for daily work and one in the garage.  I hate fetching stuff from the trailer when I need it in the shop or house, and it serves well as a backup just in case.  Love the C-15 and it was a killer waiting to get them.
Chris...
harry_
Offline Offline
« Reply #3 on: October 14, 2011, 10:04 PM »
Well, since I am getting ready to move I'll need to dig it out of the truck to remove some shelving.. I'll see how it plays AND also dust off my Bosch...... once I remember where I retired it to  Laughing
wood pulp
Offline Offline
Each another's audience...
« Reply #4 on: October 15, 2011, 07:11 PM »
I read this today and sure enough my T-12 did to me today, for the first time.  I popped the new battery in and it seemed to be fine.  The one thing I noticed is that the low battery signal never came on???  Has the battery theory been confirmed by Festool?
sg1011
Offline Offline
« Reply #5 on: October 15, 2011, 10:55 PM »
What is run on in a cordless drill?
Alan m
Online Online
« Reply #6 on: October 16, 2011, 10:14 AM »
itswhere you release the trigger and the drill is slow to react and stys turning for too long
now
wish list
GhostFist
Offline Offline
« Reply #7 on: October 16, 2011, 10:49 AM »
I've yet to experience this on mine, still the best drill I've ever worked with.
jmbfestool
Offline Offline
« Reply #8 on: October 16, 2011, 12:30 PM »
It's what Rick Christopherson said!
I have had my T15 for almost 3years and had it replaced once and BOTH did/do the the same a few other brand drills do it some times not just festool.    When your battery is low but not low to beep at you while driving a screw in or drilling a hole it will carry on spinning after letting go of the trigger.
I always believed that it takes more power to stop a motor then to run it?Huh? Or something like that!
I made this assumption because of two things!
1. The T15 on low batterie does not stop dead but yet can drive a screw in
2. The TS75 240v has electronic brake and stops the blade quickly!  The TS75 110v does not have electronic brake and let's the blade spin out to a stop.
Jmb
Rick Christopherson
Retailer
Offline Offline
WWW
« Reply #9 on: October 16, 2011, 02:19 PM »
Inside the gearbox of your EC-TEC drill is a one-way drive system. The primary purpose of this is to lock the chuck so you can tighten the bit in the chuck. It means that you have unrestricted power from the motor to the chuck, but no power can be transmitted backward from the chuck to the motor.
In the diagram below, the three green-colored pins and pink-colored 3-lobe coupler serve this function. When the motor is driving the output shaft, one of the gold-colored pins on the 3rd-stage gearset drives against the lobe of the pink coupler. However, the adjacent gold pin keeps the floating green pin centered in a small relief area.
If the output shaft turns faster than the 3rd-stage (gold) gearset, then the green pin is no longer held within this recess area and jams against the outer wall of the gearbox. This instantly locks the output shaft. (Important: This action is also why it is critical to never try to connect two drills together for a "torque-off". One of the drills will lock its output shaft and you will destroy the other drill.)
When the drill's battery is right within a small "sweet spot" of reduced power, the motor and output shaft can "coast" to a stop at the same speed and the green pins will not leave their recessed area. Another thing that can cause this is too much grease (or too sticky) in the gearbox. I learned this little fact when I reverse engineered the gearbox in the first place, and repacked all of the grease but put too much grease in the output area.
By the way, allowing this to happen too much, or at too high of a coasting speed may damage the EC-TEC electronics power transistors. This is because this type of motor will function as a 3-phase generator when you spin the output shaft. A little spin is OK, but too much will send power backward through the transistors. I have seen this happen only when I had the motor and controller disconnected from a battery, so I suspect the EC-TEC controller has circuitry to protect against this that wasn't active without the battery.
Edit: My mistake. I suddenly remembered that way back when I first examined the C12 drill, I removed the 3 locking pins from my drill and then tried the "torque off" with another drill. This allowed the output shaft to be spun at high speed, which is what fried the EC-TEC controller.
« Last Edit: October 16, 2011, 02:25 PM by Rick Christopherson » Logged
davee
Offline Offline
« Reply #10 on: March 29, 2012, 12:47 PM »
My T15 has started to "run-on" recently.  I found it did so early on when the battery was low.  Now, I am experiencing this almost all the time with either of my two batteries even when fully charged.  My drill is probably three years old.  Could this be a sign of dying batteries?  What battery life should be expected?
Shane Holland
Festool USA Employee
FOG Administrator
Offline Offline
WWW
« Reply #11 on: March 29, 2012, 12:52 PM »
Dave,
Give the service department a call. They can help figure out what's going on and get it resolved for you. They can also give you an idea of the expected battery life in terms of charge cycles possibly. The batteries are covered by a 3 year warranty, just like the tool. They can see if the drill is still under warranty as well.
Shane Holland | Festool USA | Sales: 888-337-8600 | Service: 800-554-8741 | sho@festoolusa.com
Faster. Easier. Smarter.
Power Tools, Domino Joiners, RRP HEPA Vacs, Track SawsDrywall Sanders, Cordless Drills, Tools for Painters, LED Worklamp, Router Tables
Pages: [1]   Go Up
  Print
Jump to:
