SteveC
Offline
« on: March 10, 2011, 11:05 AM » |
Nick, Nice video. I recently got the tradesman/ installer kit and was able to make it all fit. Watching your video confirmed I did it right because I saw your systainer front edge bows as did mine. One question I have, is the systainer handle strong enough to lift a CT26 ? Should I break it down to load into the truck or carry up stairs ? Mine was purchased for site work. (I will double post at "Ask Festool")
SteveC
Shane Holland
Festool USA Employee FOG Administrator
Offline
« Reply #1 on: March 10, 2011, 11:12 AM » |
Is it strong enough? I would say yes. I carry my CT 22 by the handle of the compact cleaning set on top of it when I take it out to the garage to vacuum the vehicles.
Is it recommended? Not sure. We don't have any specifications on weight limits.
SRSemenza
Global Moderator
Offline
« Reply #2 on: March 10, 2011, 12:27 PM » |
I do not know how much weight the handle can withstand. But it takes a lot of force to remove them in the folded down position that allows removal. In the carry position I think it would take more than anyone would want to try to carry. http://www.talkfestool.com/vb/festool-tanos-all-things-systainer/2121-remove-install-systainer-handle.htmlSeth
Festool Service 800-554-8741
Ken Nagrod
Restricted
Offline
« Reply #3 on: March 10, 2011, 12:41 PM » |
Thanks for the info Seth. I was trying to figure out how to do that without damaging anything.
SteveC
Offline
« Reply #4 on: March 10, 2011, 12:54 PM » |
Thanks. If by chance it did fail, is this a warranty item? Anyone want to sacrifice a systainer to find the limit and/or warranty?
SteveC
Ken Nagrod
Restricted
Offline
« Reply #5 on: March 10, 2011, 12:59 PM » |
Steve, check out the other thread you posted this in for my "test".
Alex
Offline
« Reply #6 on: March 10, 2011, 01:20 PM » |
I've carried my CTL22 around many times by the handle of an attached systainer, the handle held up just fine.
Nigel
Offline
« Reply #7 on: March 10, 2011, 01:39 PM » |
I've carried ctl 36 [full] with systainer.I've often wondered about the little green tabs on the ctl but never thought about the systainer handle.I'd be interested to know of any specifications from Festool.
Kevin D.
Online
« Reply #8 on: March 10, 2011, 01:48 PM » |
Looking at pictures in my 2007 and 2008/2009 catalogue, they do not show any pictures of the CT's being carried with a sys attached to the top, but only of the CT unit being carried solo.
I just tried my own out carrying it with a sys on top, and it doesn't seem to be precarious in any way.
TS75, MFT 1080, MF-SYS/2, PS300 EQ-Plus, Parallel Guides Set, LR32 SYS, RO 150FEQ-Plus, OF1400 EQ Plus, DOMINO 500 Q-Plus, MFK 700 EQ-Set, FS-SYS/2, CT22 w/hose storage, D36HW-RS-Plus, FS 1900/2, FS 3000/2, FS 1080/2-LR32, FS 1400/2-LR32, Gecko, Festool Hat, Festool T-Shirt (2), Festool Floor Mat, Festool Stein.
Wish List: Kapex, and more sanders.
jmbfestool
Offline
« Reply #9 on: March 10, 2011, 01:53 PM » |
I have a systainer 5 which holds my Paslode first fix gun a few nails gas 2x batteries and charger AND Dewalt second fix gun few nails 3x 18v batteries and charger! Well that systainer ALONE is heavy! Well I have had it attached to my CT22! The reason because the weight! I can roll the systainer around on my CT22 to the job but some times it needs lifting over things or up some steps so instead of unclipping it I just lift the hole lot and the handle has held fine no signs of plastic turning white under strain.
JMB
Shane Holland
Offline
« Reply #10 on: March 10, 2011, 02:00 PM » |
Systainers and sortainers are not covered under the warranty.
Ken Nagrod
Restricted
Offline
« Reply #11 on: March 10, 2011, 02:04 PM » |
Good point Nigel. Those are probably the weak link in the whole idea. If the green tabs fail, the CT drops.
fritter63
Offline
« Reply #12 on: March 10, 2011, 02:18 PM » |
I do the same as jmb and lift it over thresholds , etc.
For me it's not an issue, because at my age and after 25 years of weightlifting, my shoulder sends signs of impending failure long before the handle will....
Brice Burrell
Offline
Remodeling Contractor
« Reply #13 on: March 10, 2011, 02:25 PM » |
Video test forth coming. Stay tuned.... Video test, sorry about the bad quality video. I pause for a second when I hear something come loose in the router bit Systainer. I know you guys would ask so I did the test with both a classic and a T-Loc. I weighed the vac, it came in at 53 lbs, not including the Sys. I didn't do any prior testing so I was sweating the new T-Loc little.
« Last Edit: March 10, 2011, 02:55 PM by Brice Burrell »
SRSemenza
Global Moderator
Offline
« Reply #14 on: March 10, 2011, 03:01 PM » |
Good point Nigel. Those are probably the weak link in the whole idea. If the green tabs fail, the CT drops. Keep in mind that the CT latches will only ever have to hold the weight of the CT. No matter how much is stacked on top. Might seem obvious but sometimes the mind plays tricks.... Same goes for the rolling caster boards with the little rubber tabs (spangummi  ) . Seth
Alex
Offline
« Reply #15 on: March 10, 2011, 03:08 PM » |
Look at the lids in that test .....
Brice Burrell
Offline
« Reply #16 on: March 10, 2011, 03:11 PM » |
Yes, they flex. Remember that 53 lbs (24.09 kilos) bouncing and everything held.
RvB
Offline
« Reply #17 on: March 10, 2011, 03:19 PM » |
Nice vid!,, I carry my ctl with sys 5 Tloc on top around all the time!! no problem.. (i stuffed the craftsman cleaning kit in a sys 5, because of the big python d 36 as hose talking back at me!!! )  .. and, now i got more space for cleaning acc. haha
ALLREADY GOT:Domino XL DF 700 - CS70 precisio - Kapex 120 EB - TS 55 EBQ Saw - EHL 65E - PS 300 EQ - OF 1010 EBQ - OFK 500 R3 - CTL 26 E - CTL Midi - BS 75 e-set - DTS 400 EQ - ROTEX 90 - FS SYS/2 - FS 1400/2 x2 - FS 800/2 - FS Bag
D 36 HW RS craftsman cleaning kit - D27/D36 portable cleaning kit - RO90 & DTS 400 abrasive sys - Festool & Protool tool-box - carpenter sys - Fein supercut sys - homemade drills&drivers sys - nailguns sys5 -SYS-CART RB-SYS
WORKIN' REALLY HARD FOR: UG-KA-SET - OF 1400 - ETS 125 - ROTEX 125 - Boom Arm - FS/2 3000
Tom Bellemare
Festool Dealer
Offline
« Reply #18 on: March 10, 2011, 03:21 PM » |
You must have about 13 pound in your bag, Brice. The unit weighs a little less than 40 lbs.
Brice Burrell
Offline
« Reply #19 on: March 10, 2011, 03:24 PM » |
Yes, the bag is fairly full of construction debris.
Alex
Offline
« Reply #20 on: March 10, 2011, 03:26 PM » |
Yes, they flex. Remember that 53 lbs (24.09 kilos) bouncing and everything held. I meant more the difference between the 2.
RvB
Offline
« Reply #21 on: March 10, 2011, 03:28 PM » |
t-loc flexin at the front/sides.. classic sys flexin in the middle.. potato, potaato..
SteveC
Offline
« Reply #22 on: March 10, 2011, 03:37 PM » |
SteveC
jmbfestool
Offline
« Reply #23 on: March 10, 2011, 04:35 PM » |
Yes but the Flex is FAR FAR less with the classic in the middle than it is with the T-loc on the size! Because the 4 points on the Classic systainers are closer to the handle than the 3 points on the T lock so AND the handle points are on the OUT side of the triangle if they where inline with the 3 points then their would be far less flexing. Also like mentioned above the green latches on the CT will hold because they will never be holding any more weight than the CT its self. Different story with the handle though because a larger systainer with heavier stuff inside does add including the CT on the handle thats why I said I have used my large systainer many of times with all the heavy nails guns inside and had no problem with the handle and even then the classic flexes less than Brice's T-loc demo bouncing it in the air and thats only a small light T-loc so it only has the weight of the CT JMB
Ken Nagrod
Restricted
Offline
« Reply #24 on: March 10, 2011, 05:02 PM » |
The green latches on the CT will be subjected to more loading stress the more weight is added above the CT in systainers while lifting the whole mass. The weight of the CT itself is not the only factor.
RvB
Offline
« Reply #25 on: March 10, 2011, 05:32 PM » |
not true, JMB is right.. just general physics..
WarnerConstCo.
Online
« Reply #26 on: March 10, 2011, 05:48 PM » |
I think this is right, I believe it is.
I was told the handle will support up to 400 pounds.
I was told the latches will give out at 200 pounds.
I am not going to carry 200 pounds.
My cleaning kit is pretty much permanently stored on my 22.
You can carry the vac by the tradesman set no problem.
I wouldn't suggest carrying it like that if you have to go up more then a few steps though.
Holzhacker
Offline
« Reply #27 on: March 10, 2011, 06:29 PM » |
I have a Sys 1 with the bottom cut out attached to the top of the hose garage on my 22. This allows me to keep the cleaning kit handles, rags, sponges, etc in a sort of permanent place readily available. Whether the bag is empty or full I've carried the whole thing by the Sys handle repeatedly, no problems.
WarnerConstCo.
Online
« Reply #28 on: March 10, 2011, 06:50 PM » |
I meant it is kind of awkward carrying the CT with a sys 4 on top up a couple flights of stairs. You really have to lift it pretty high.
Alex
Offline
« Reply #29 on: March 10, 2011, 07:13 PM » |
It's like 5 mm for the classic and 35 mm for the T-loc. In your anology that's more like ... potato, potaaaaaaato.... People can keep on telling me the lid can hold the weight, but for me, seeing such flex in a systainer lid makes the whole look and feel flimsy. An empty systainer starts at a cost of 53 euro making it the most expensive type of plastic box I can think of, so you'd better get some quality. The green latches on the CT will be subjected to more loading stress the more weight is added above the CT in systainers while lifting the whole mass. The weight of the CT itself is not the only factor.
Indeed not true. The weigth of the CT itself is the only factor because that's all the weight the latches have to hold. But I'm pretty sure the latches were not intended to hold the weight of the CT while it's been carried around, they're only there to hold a systainer in place while the CT properly rests on the floor.
