Pages: [1]   Go Down
  Print
Author Topic: Can I build a small outdoor kitchen cabinet in green oak?  (Read 2424 times)
Mauri Motti
Offline Offline
« on: September 14, 2011, 09:36 AM »
I've harvested and sawn to boards an oak about three months ago. I wondered if there's any trouble if I'd use it in a month or so to build some outdoor furniture for under a roofed patio? The boards range in thickness from about 4 to 6 centimeters.
Any help appreciated!
waho6o9
Offline Offline
WWW
« Reply #1 on: September 14, 2011, 09:56 AM »
I would use a moisture meter first.  Good luck.
best is to cut it into slabs quickly, otherwise the wood will split. as for drying, a rule of thumb is at least 1 year per 10mm thickness. best is to lay them not on the ground, in a covered area with good air flow    From TimTool   Belgium
« Last Edit: September 14, 2011, 10:00 AM by waho6o9 » Logged
Mauri Motti
Offline Offline
« Reply #2 on: September 14, 2011, 12:43 PM »
Thanks waho609,
I have used a moisture meter several weeks ago and from the 4 cm boards it reads 12% at the end grain which isn't a fair indication but it's better then nothing. The boards are about three meters in length and I'm sure there's lots of moisture in the wood. And I am aware of the 2,5 cm per year but (ideally 8%) that is for indoor use and I want to use the oak outside and hoped that as long as I'm not dovetailing or use other fine joinery, I should be fine. (?)
waho6o9
Offline Offline
WWW
« Reply #3 on: September 14, 2011, 06:50 PM »
Patience my friend patience.   Blink
tjbier
Offline Offline
« Reply #4 on: September 14, 2011, 10:10 PM »
I wouldn't build it out of green lumber, it will move, more than you think. Although 12% isn't terrible, where are you checking with the meter? Try cutting a board in 1/2 and see what the % is in the cut.
But considering that some kiln lumber goes down to 6% or lower that is still a bit to dry out yet.
Tom- ps, I read these.
Pages: [1]   Go Up
  Print
Jump to:
