Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 25, 2013, 06:29 AM
Home
Search
Login
Register
Festool Websites
Festool USA
Festool UK
Festool Canada
Festool Australia
Festool Netherlands
Festool Germany
Festool International
Product Websites
CMS Router Table
Cordless Drills
DOMINO Joiner
HEPA Dust Extractors
Jigsaws
Planex Drywall Sander
Rotex Sanders
SysLite Work Lamp
Track Saws
Woodworking & Power Tools Forum - Festool Owners Group
GENERAL DISCUSSIONS
Building Materials
Cutting high pressure laminate for cabinet doors
Pages: [
1
Go Down
« previous
next »
Print
Author
Topic: Cutting high pressure laminate for cabinet doors (Read 4288 times)
Mark Enomoto
Offline
on:
May 08, 2009, 03:31 AM »
I'm planning a kitchen remodel and am going to use various colored HPL for the doors. Designed this for our last house but have to do it myself now due to budget. That said, can my TS55 with the right blade cut through the laminate and plywood core w/o any chipping? I'm trying to avoid the double work of cutting close and then to size with a trim router. I want to expose the plys on the edge of the doors (yes... it won't be the most bullet proof design but it looks sweet :-) and finish it with something like OSMO. Advice/Experience? Thanks
jonny round boy
Offline
Re: Cutting high pressure laminate for cabinet doors
Reply #1 on:
May 08, 2009, 06:17 AM »
If it's good quality laminate, well stuck to the ply, and you're using a sharp blade & good edge strip on the guide rail, then no problems.
If you want to be doubly sure, clamp the rail to the panel, and set the blade depth to cut <1mm (just through the laminate) and pull the saw
backwards
at this depth, before re-setting the depth stop and cutting forwards through the ply. I've done this before to cut down high-gloss laminate doors. It works like a scoring blade on a table saw.
Do you have access to a press for bonding the laminate to the ply?
Don't forget, you'll need to laminate the reverse side too with a balancer.
woodshopdemos
Inactive Member
Offline
Reply #2 on:
May 08, 2009, 08:00 AM »
I think JRB gave you as about the best answer there is. I would NOT take the chance. Any chipping will screw up the panel. I would cut panels to exact final dimensions. Cut the laminate to 1/2" greater on all four sides. Apply laminate using laminate adhesive. Trim with router. Hang.
In memory of John Lucas (1937 - 2010)
Mark Enomoto
Offline
Reply #3 on:
May 10, 2009, 12:17 AM »
Thanks for the advice. Given my skill level, John's method would be safer and I've done it that way before with smaller jobs. I've just used a J-roller most of the time but not sure its the best way to do a counter top. Should this just be jobbed out and I can site cut it to fit?
woodshopdemos
Inactive Member
Offline
Reply #4 on:
May 10, 2009, 10:25 AM »
J-roller is the tool of choice. Laminating with that tool and good cement is easy and a good skill to learn. Be sure to use a laminate cement and a good short nap roller. Too thick a coating is as bad as too thin.
Tom Bainbridge
Offline
Limey Carpenter
Reply #5 on:
May 12, 2009, 04:47 PM »
what is high presure laminate
the prefix "high preasure" suggests there are various grades of laminate
i know laminate only under the general term of formica, altough there are a number of manufacturers
Bromley, Kent. UK
aka dirtydeeds
mastercabman
Offline
NORFOLK,VA
Reply #6 on:
May 12, 2009, 07:31 PM »
Quote from: Tom Bainbridge on May 12, 2009, 04:47 PM
Hight pressure laminate (AKA "HPL") is plastic laminate such as Formica that you would use for counter top.
Pages: [
1
Go Up
Print
« previous
next »
Jump to:
Please select a destination:
FESTOOL DISCUSSIONS
=> Festool Tools & Accessories
=> Festool Tool Reviews
=> Festool How To...
=> Festool Tool Problems
=> Festool Jigs & Tool Enhancements
=> Festool Wish List
=> Festool and Tanos Systainers
=> Ask Festool
=> Sales & Dealer Area
=> Fun, Games, Diversions
GENERAL DISCUSSIONS
=> Member Projects
=> Other Tools & Accessories
=> Other Tool Reviews
=> Hand Tools
=> Building Materials
=> Finishing and Painting
=> Various Woodworking & Crafts Topics
=> Home Improvement & Other Projects
=> Member Connections
FORUM TECHNICAL
=> Gallery & Attaching Images
=> Forum Features & Functions
=> Forum Rules, Guidelines, & Suggestions
OFF-TOPIC
=> Computers, Gadgets, Technology
=> Photography
=> Sports & Recreation
=> General Friendly Chat
=> Classifieds
