Author Topic: Dominofix plate material?  (Read 4781 times)
Offline tallgrass
« on: July 13, 2018, 01:46 PM »
What material is the Dominofix made out of and where do you get it
Re: Dominofix plate material?
« Reply #1 on: July 13, 2018, 02:14 PM »
It’s phenolic, the same material Woodpeckers uses for its MFT template.
Online Svar
« Reply #2 on: July 13, 2018, 02:20 PM »
Phenolic sheet/plate, eBay.
Offline tallgrass
« Reply #3 on: July 13, 2018, 03:12 PM »
that makes sense. Does anyone know where to buy this stuff in a more reliable fashion than ebay. That was a good source but I am looking for a commercial source that I can order from.
« Reply #4 on: July 13, 2018, 04:09 PM »
I know Woodcraft sells small 1' x 1' sheets that are used for zero clearance inserts.
This stuff isn't cheap. I know I priced a 2' x 4' x 1/2" piece several years ago and it was in the $300-$400 range
Offline rst
« Reply #5 on: July 13, 2018, 05:22 PM »
Tallgrass, I don't know where you live but most major metropolitan areas have commercial plastics distributors...AIN plastics is our stocking distributor. There are various grades of plenolics that can dramatically affect price. Make sure that you use good dust collection and wear a mask as the resins they use for bonding is carcinogenic.
Offline tallgrass
« Reply #6 on: July 14, 2018, 10:53 PM »
thanks, I live in los angeles. I can find the plain stuff, not the stuff like this with the color covering or sheet. Many of these materials like parklex exist but not really. The other problems figuring out what trade name means what exactly. I wonder if it is a phenolic with a "formica" sheets?
Offline tallgrass
« Reply #7 on: July 14, 2018, 11:08 PM »
I wonder if that is my solution. buy it and cover it the way I would want? Will the adhesives work on formica and phenolic?
« Reply #8 on: July 15, 2018, 12:42 AM »
The trouble with phenolics is that there are tons of them and the commercially available ones may not satisfy your requirements if you need one with a specific performance feature.
Let’s approach this in a different manner, in general what are you trying to produce? What are you trying to achieve? What type of surface finish do you want?
There are a lot of folks on this forum that work with “alternative “ materials daily that will probably weigh in.   [smile]
Offline tallgrass
« Reply #9 on: July 15, 2018, 03:31 AM »
It is not a particular at this point. I have several cnc machines and this stuff looks like it would be great for certain kinds of fixtures and for prototyping. Much like solid surface is. As an engineer, when I run across a new material or product I try to figure out cost and properties. I like the particular surface of this particular type of phenolic. It looks to be wear resistant, more than the usual variety of phenolic.
« Reply #10 on: July 15, 2018, 11:09 AM »
When I looked into the pricing of phenolic sheet, my idea was also to use the stuff for fixtures and jigs. After finding out how much it cost, I settled on phenolic faced plywood for fixtures when I needed the smooth surface characteristics. A 2' x 4' x 1/2" sheet is $50 compared to $400.
Many of Woodpeckers products are machined from phenolic (MFT square, MFT template, clamping cauls, clamping squares) and it's real nice stuff. The surface is smooth & durable and it rather reminds me of Delrin.
Offline blaszcsj
« Reply #11 on: July 15, 2018, 02:55 PM »
McMaster.com
OF1010 EQ Router | MFT/3 | DF500Q | Carvex 420 | ETS EC 150/3 | CT 36 Auto Clean | TSC55 | LR32 | OF1400 EQ Router | ZOBO Metric Set | CXS Li 2.6 - 90 Limited Edition | Universal Cleaning Set | HKC55 | Centrotec CE-SORT | RO150 FEQ | DTS 400 | RO90 DX | CTSYS | C18 Drill | SysLite KALII | Syslite STL 450 | RAS 115 E | OF2200 EB
Offline tallgrass
« Reply #12 on: July 15, 2018, 07:03 PM »
I know Mcmaster sells some forms of Phenolic. I can find the usual stuff but this has a coating or surface that seems different. The contrast in colors between the surface and the base material has benefits.
Offline tallgrass
« Reply #13 on: July 15, 2018, 09:15 PM »
OK, I have found where is this stuff is used. The question no becomes how to get it. It is Solid Phenolic Core Panels like the ones used in restrooms. So this stuff is everywhere, but in the material stream. Suggestions? Besides raiding the local bathrooms.
Online Svar
« Reply #14 on: July 15, 2018, 09:18 PM »
That might be different grade of panels then used in router plates or Dominofix jig. It would be extremely expensive for bathroom dividers.
« Last Edit: July 15, 2018, 09:21 PM by Svar »
« Reply #15 on: July 15, 2018, 09:34 PM »
Ya I’d have to side with Svar on this one. Aluminum privacy panels used in bathrooms are a lot cheaper than the equivalent panel in phenolic.
Online Svar
« Reply #16 on: July 15, 2018, 10:00 PM »
Just to be clear. I have encountered phenolic partitions and locker doors in public spaces, but I think it is of lower strength/quality than router plate stuff.
Offline tallgrass
« Reply #17 on: July 15, 2018, 11:16 PM »
yes there are different grades and solutions. You are absolutely right. I was not suggesting that this is the only solution for bathrooms commercially. Only that it this common commercial solution  for high pressure phenolic laminate that allowed me to find the stuff with the protective coating. Now it is a matter of finding out if there is a non bulk purchase possibility. here are examples.
Offline tallgrass
« Reply #18 on: July 15, 2018, 11:18 PM »
another example
Offline tallgrass
« Reply #19 on: July 15, 2018, 11:20 PM »
more
« Reply #20 on: July 16, 2018, 09:34 AM »
yes there are different grades and solutions. You are absolutely right. Here are examples.
This all black version looks exactly like the Woodpeckers MFT Template.
Offline tallgrass
« Reply #21 on: July 17, 2018, 12:35 PM »
I think it is. This is odd stuff. It is hard to actually get a hold of.
Offline Musto
« Reply #22 on: September 27, 2018, 11:03 AM »
Here in Belguim its easy to get hold of this material, there are a few brands that i can get in all wood dealers around me (Formica, Trespa) and plenty web shops make this stuf for a great price its mostly not from a brand but sold as HPL plate.
Offline tallgrass
« Reply #23 on: September 29, 2018, 03:15 PM »
it is hard to come by here. I actually love the stuff
