Pages: [1]   Go Down
  Print
Author Topic: Drywall with MDF????  (Read 3601 times)
Matthew deBeaupre
Offline Offline
« on: July 23, 2009, 12:27 AM »
Can drywall be mudded well to MDF? There is a transition where we need to run a drywall ceiling into an MDF face - curious if anybody has tried this.
Thanks a bunch
m@
Peter Halle
Global Moderator
Online Online
WWW
« Reply #1 on: July 23, 2009, 10:17 AM »
My guess is that a crack will develop at the joint.  Different expansion contraction rates.  Not knowing the exact application I would suggest that you look to see if a j bead or other transition joint would work to allow for the movement.
Holzhacker
Offline Offline
WWW
« Reply #2 on: July 23, 2009, 11:07 AM »
I cannot reasonably imagine it working and not cracking in short time. I would also recommend a transition joint instead. A drywall endbead, a run of 1 1/8" stop moulding as a detail, etc. painted the same color. This would stop any call backs.
If I had to try to mud it ... mesh tape, structolite base finished with DB and mud.
Pages: [1]   Go Up
  Print
Jump to:
