Author Topic: Engineered flooring recommendations (UK) please  (Read 2509 times)
Offline cliffp
« on: January 04, 2018, 04:55 AM »
I am planning to have an engineered wood floor fitted to my lounge and hallway and am unsure of the best make/model of flooring to use. I would like to have a decent wear layer of 6mm or so if possible so it will stand being re-sanded a few times. Can anyone recommend a good product? I realise that better products are likely to cost more and don't mind paying extra for the right product as long as it is good value.
I am also open to suggestions that solid wood is worth considering instead.
Finally, if anyone is interested in quoting for the job (Chichester), please pm me (I think the total area is around 45m2).
Regards
Cliff
T15+3 set, CXS set, Centrotec set (2011), TS55REBQ, TS75EQ, 1400 rail, 1900 rail, 1400 LR32 rail, LR32 set, MFT/3, OF1400, OF1010, Guide rail adapter, edging plate, angle arm, chip catcher, small bore base, MFS400, MFS1000 profiles, RO90DX, RO150, ETS150/3, Domino DF500, Domino assortment systainer, CTL Midi, compact cleaning set, CMS GE, TS75 Module, OF Module, VL and VB extensions, LA Stopper, Sliding table, Carvex 420 Li 18 GG, core maker set, EHL65EQ, Syslite.
