Pages: [1]   Go Down
  Print
Author Topic: size of steel i beambuilding a leanto  (Read 781 times)
kjm
Offline Offline
« on: February 18, 2012, 05:34 PM »
need to know size of steel i beam for a 20 foot span. i am building a lean to in backyard the size is 10by 20 .it will be 8 feet height on one side and 7 feet on the other
Steve R
Offline Offline
« Reply #1 on: May 13, 2012, 12:19 PM »
The beam supplier should have rating for this.  But you need know load/wind load etc.  I would look for plans and see what they say to use. Even if they say use wood you can figure out the load rating from that.
Cheers,
Steve
Pages: [1]   Go Up
  Print
Jump to:
