Author Topic: Weather resistance of maple  (Read 1671 times)
Offline Kodi Crescent
« on: November 26, 2018, 08:23 AM »
I'm considering this swing for my daughter:
https://www.amazon.com/dp/B07D42N3CF/ref=psdc_7432792011_t3_B00NU9VMAK#customerReviews
The description claims that the maple for the seat is "UV and weather resistant".  I know nothing about maple or using anything but pressure treated wood outside.  If I were to get this for her, would I need to do anything to maintain it long term?
Thanks!
Offline tjbnwi
  • Cedar Tucky Indiana
Re: Weather resistance of maple
« Reply #1 on: November 26, 2018, 09:04 AM »
I don't consider maple as a great outdoor wood. My guess is the finish has a UV protection rating. Figure on refinishing it every couple of years. As long as you treat it as the finish fails it should last a long time.
Offline Alanbach
« Reply #2 on: November 26, 2018, 09:19 AM »
I agree with tjbnwi. Also, what part of the country do you live in? If you have rough winters I would consider hanging it in a way that makes it easily removable. Then you can just take it inside during the winter / rainy months. This should extend its life considerably.
Offline SRSemenza
« Reply #3 on: November 26, 2018, 09:48 AM »
Yes, it must have poly or some other finish making it "resistant" .
« Reply #4 on: November 26, 2018, 10:15 AM »
The rope will be fine for extended exposure...the maple not so much. I'd gin up a simple quick disconnect under the maple seat to allow the seat to be brought indoors when inclement weather hits.
Offline DeformedTree
« Reply #5 on: December 01, 2018, 10:06 PM »
As has been mentioned, it's most certainly sealed with a few layers of something.
That said, various woods have lived exposed to elements since the dawn of time.  Pioneers for instance built there building out of almost anything. These buildings have been exposed for hundreds of years.  As long as you are ok with the wood turning grey, almost anything can be left exposed. The key is it stays dry or is able to dry out.
Non PT wood is doomed when its in dirt, or in a position where it can't dry out on all sides.  A nice smoothly sanded bit of wood hanging from a rope probably would be fine for a long time.
Offline Birdhunter
« Reply #6 on: December 06, 2018, 08:57 PM »
Try Ipe. It’s a great outdoor wood. My Ipe benches have been outside with no finish for years and are still unaffected except for turning gray. You do have to treat the ends with a sealer immediately after cutting to prevent splitting. A lot of weather resistant woods can trigger allergic reactions so use with caution. Ipe is an extremely hard wood so plan on predrilling holes for fasteners and t,asking time on cutting operations.
Birdhunter
Offline Kevin D.
« Reply #7 on: December 07, 2018, 09:58 AM »
Ditto to that.
Kapex, CT-SYS, SYS-Cart, Pro 5 Sander, CT36AC, TS75, MFT 1080, MF-SYS/2, PS300 EQ-Plus, Parallel Guides Set, LR32 SYS, RO 150FEQ-Plus, OF1400 EQ Plus, DOMINO 500 Q-Plus,  Domino XL, MFK 700 EQ-Set, FS-SYS/2, CT22 w/hose storage, D36HW-RS-Plus, FS 1900/2, FS 3000/2, FS 1080/2-LR32, FS 1400/2-LR32, Gecko, Festool Floor Mat, Festool Stein, Multi-Tool, tape measure, large and small Festool floor mats (foam rubber).
Offline HarveyWildes
« Reply #8 on: December 07, 2018, 11:18 AM »
Ipe is also a high silica wood, and will dull cutting tools faster than other woods.
Offline leakyroof
« Reply #9 on: December 12, 2018, 03:55 PM »
I would have more faith in it if it was painted versus a film finish.  As a reference, I have a fairly old Wood 2 person Glider that I got from my next door neighbors when they were moving. I'm pretty sure all the wood that's original is poplar or something similar and inexpensive for the maker. The only way it's survived all these years living outside year-round is with constant vigil on my part and good paint. And I've still replaced rotted sections from time to time with outdoor rated wood species in place of what ever it came with.  It does have a Vinyl Cover for the Winter, but that's it.   Maple as noted by others would never be my first or even second choice for an outdoor item.
Offline JimH2
« Reply #10 on: December 12, 2018, 04:04 PM »
+1 on constant vigil
