Author Topic: Work bench MFT top material?  (Read 935 times)
Offline 3PedalMINI
    • Signature Sound & Video
« on: April 08, 2018, 05:21 PM »
I have lined up a CNC shop todo my top cheaper then I can buy a jig/20mm bit for! I’m scheduled for Tuesday but need to drop the material off tomorrow. I was all set to just do 3/4” MDF but I’m having second thoughts. I know Festool is MDF, but I know it’s different then the MDF you buy at the home centers. I was going to go to my supplier and get it, but I’m concerned about the MDF top.
The bench will be a Paulk style top “torsion” so I think the top will be adequately supported to prevent sagging. Would MDO be a better option? Or should I just do a good quality AC plywood. No matter what I’m going todo I’ll finish it with a clear!
Thanks!!
The Bitterness of poor quality remains long after the sweetness of low price is forgotten -Benjamin Franklin
Professional Custom Audio Video System Designer/Installer serving Southern - Middle NJ, Eastern PA & the Surrounding Shore Points.
www.sigsv.com
Kapex 120,TS55,RO150,ETS125,CT-26,CT-MIDI,Tradesmen Cleaning Kit, Festool Ratchet Kit, Sys-lite, Sys Roll Cart, T18 +3, 2013 Centrotec Kit, Carvex 420, Carvex Accessory Kit, CXS,RO90, TI15 and Various Festool Systainers
Offline Corwin
Re: Work bench MFT top material?
« Reply #1 on: April 08, 2018, 06:24 PM »
The bench will be a Paulk style top “torsion” so I think the top will be adequately supported to prevent sagging. ...
If it is truly 'adequately supported,' then why wouldn't the MDF be fine?
Looks like your rabbit joint is a hare off! ;)
Offline BarneyD
« Reply #2 on: April 08, 2018, 07:34 PM »
I built one a couple of years ago out of MDO (just because I had some). It's 30 x 48 and has no noticeable sag yet. Good luck with yours.
Barney
Offline 3PedalMINI
« Reply #3 on: April 08, 2018, 09:07 PM »
Is there any reason not to go with MDO? Will it hold up ok with clamps and accessories?
I’m just concerned that MDF won’t hold up since we can’t get quality MDF here....or am I just overthinking this?
Thanks Guys!
www.sigsv.com
Online neilc
« Reply #4 on: April 17, 2018, 09:20 AM »
Lightweight MDF is what I have used.  Available at most quality lumber yards. Big box typically won’t stock it but might be able to special order.
