Author Topic: Worst plywood I have ever seen.  (Read 12154 times)
Offline Gr8trim4u
  • I did it all!! The woodwork I mean.
« on: February 15, 2017, 12:11 PM »
Can you believe this is in the core of the plywood. 258398-0
Not my first rodeo!!!
Online kevinculle
Re: Worst plywood I have ever seen.
« Reply #1 on: February 15, 2017, 12:37 PM »
That is truly junk!  Did the price reflect that terrible quality?  Don't think I'd build anything with that stuff.
Offline HarveyWildes
« Reply #2 on: February 15, 2017, 01:30 PM »
Terrible.  Take it back if you can.
Did the little blocks come with the plywood ([scared] [scared] [scared]) or did you add them to try to shore it up?
Offline SRSemenza
« Reply #3 on: February 15, 2017, 02:36 PM »
Yup, I've seen similar. Also found blue plastic pieces and other unidentifiable  items. All in big box plywood.
 Also had stress cracks appear in the veneer layer  after staining. Couldn't see them before the stain went on. [mad]
Offline Dane
« Reply #4 on: February 15, 2017, 03:30 PM »
Is that the ubiquitous "Sanded Ply" from HD?  I stopped buying that stuff a few years ago- truly reprehensible QC on that stuff.  PureBond tends to be better, but I still get some of that from time to time.
Offline Gr8trim4u
« Reply #5 on: February 15, 2017, 05:07 PM »
The little blocks was already in the plywood.
This came from the oldest lumber yard on the east coast.
The builder I am working for purchased the product. It is pantry shelving(paint grade). I showed the builder ne said it was cheaper than the birch(NO SH&T). We quickly came to an understanding that if he required the same finish look as the birch yielded then he would have to pay me to work around these kinda issues. He agreed to buy yhe better grade of ply.
Offline #Tee
« Reply #6 on: February 15, 2017, 05:18 PM »
wow...they might as well throw in some garbage and banana peels in there.
When youre feeling depressed just treat yourself to a systainer even if its a mini systainer its ok.
IG: tee212
Offline RussellS
« Reply #7 on: February 15, 2017, 06:40 PM »
The sheet on the bottom looks OK.  And the sheet you made the bench out of looks OK.  But I would only use that for something where appearance did not matter.  Like as a subfloor.
Offline antss
« Reply #8 on: February 15, 2017, 06:43 PM »
no, no, no, no, that stuff would be horrible for a subfloor too.
Those voids won't just be limited to the edges.
Offline Sparktrician
« Reply #9 on: February 15, 2017, 06:47 PM »
If that crap had ever hit one of my job sites, it would never have gotten off the truck and I'd have a new supplier within an hour.
 [mad]
- Willy -
Offline Gr8trim4u
« Reply #10 on: February 15, 2017, 06:55 PM »
 [mad]
 Problem is i didn't see it till i cut it. We will no longer be using it.
Online Untidy Shop
« Reply #11 on: February 15, 2017, 07:51 PM »
Regretfully we do see defective ply down here too, but fortunately in my experience in sales and use, this is usually restricted to non structural non furniture grades with correspondingly much lower prices.
Usually I only see delamination or air pockets in inner layers. Certainly not what we see here from @Gr8trim4u . If this is not discounted non structural ply he should take it back.
Non structural ply has its uses however - assembly benches and Systainer cages.
My assembly bench. Two sheets glued and laminated. Then edgebanded.
« Reply #12 on: February 15, 2017, 09:02 PM »
Naw, that's even worse to use as a subfloor or underlayment, as there's no solid structure to support the layer on top. Think tile and grout, how long will that hold up when there are voids in the substructure? That's exactly the reason tile floors can fail...
Offline Rollin22Petes
« Reply #13 on: February 15, 2017, 09:25 PM »
From what I can tell  what you have there is an import plywood most likely China birch and all of it is pure garbage. Being a business I buy all our plywood wholesale even though all of my suppliers care this junk they sell it buyer beware. They will not take it back or exchange for another. We don't use it in our shop for obvious reasons but I have seen everything from razors to cigarettes in this stuff. I really fill sorry for all of the consumers buying this stuff for such an inflated price at the big box store without knowing what they are buying. A product we have been having excellent results with here lately is a maple plywood coming out of Spain called Garnica really good product and it's lighter.
Offline fignewton
  • "Fine Quality Sawdust"
« Reply #14 on: February 16, 2017, 08:37 AM »
Gr8trim4U, I saw that Hardwoods in the Rough in Manassas is carrying the Garnica.  Looks good from the side edges and the faces are pretty.
TS55, MFT3+, OF1400, C12, CT-26, LR-32 system, Domino 500, RO125, MFK 700, Carvex w/ accsy, Sys-roll,  CXS, Kapex, UG with extensions, RO90
Offline leakyroof
« Reply #15 on: February 16, 2017, 09:08 AM »
So they're making Plyish now instead of actual Plywood.... [mad]
« Reply #16 on: February 16, 2017, 05:15 PM »
A&M Supply in Upper Marlboro also carries Garnica, and I concur that, based on samples that I've seen, Garnica is a very nice product.
- Willy -
Offline Gr8trim4u
« Reply #17 on: February 16, 2017, 06:10 PM »
Yea was bummed when A&M left Alexandria. I will check into the Spanish product.
Offline johnbro
« Reply #18 on: February 17, 2017, 12:25 AM »
This Garnica looks interesting. Anybody know where I can get it in the Pacific NW?
TS 55, 3 guide rails, MFT 1080, RO 150, ETS 150/3, MFK 700, OF 1400, Kapex 120, Domino 500, CT 26
Offline builderbob
    • RJP Remodeling
« Reply #19 on: February 17, 2017, 07:20 AM »
All I have been using is Garnica. For paint/pigmented finishes, I use the pluma HDF. Their prefinished birch is awesome as well.
Here's a photo of the cross section on a sheet of 3/4".
Kapex, TS55, CMS GE, Carvex 420, Domino DF500, MFK 700, OF 2200, OF 1400, OF 1010, EHL65, RAS 115, RTS 400, RO150, ETS 150/3, ETS 125, CT 22 (2), CXS (2), C-15+3, T-12+3, PSB 300 & more MFT's than i can count!
Offline SRSemenza
« Reply #20 on: February 17, 2017, 02:41 PM »
Bob,
  That Garnica looks nice. How about a couple face shots?   Also price range?
Thanks,
Online Oldwood
  • Alberta, Canada
« Reply #21 on: February 17, 2017, 03:15 PM »
I have never been able to understand the logic of saving a few bucks on the material resulting in wasting big $$$ in labor [unsure]
Confucius
Offline JeremyH.
« Reply #22 on: March 21, 2017, 03:31 AM »
Out of high school I worked in a plywood factory. Let me tell you, that took some effort, the kind of effort that would only be worth it if you had essentially slaves find the pieces to put that puzzle together like that.
Offline Bob D.
« Reply #23 on: May 06, 2017, 06:29 AM »
But (correct me if I am wrong) HDF is not wood, its High Density Fiber, same as a
sheet of MDF but a little tougher due to the higher density.
So what you show in the photo is a sheet with HDF on both faces and a plywood core.
Good for painted work or rough work such as shop cabinets but not stained cabinets
or furniture.
Lumber core plywood used to have all kinds of junk in it. You don't see it much but I
remember it when I worked in a lumber yard 40+ years ago.
« Last Edit: May 06, 2017, 06:31 AM by Bob D. »
Offline builderbob
    • RJP Remodeling
« Reply #24 on: May 06, 2017, 06:40 AM »
or furniture.
Bob, yes you are correct...as I stated in my post I use the HDF for painted or pigmented lacquer. The same brand, Garnica, makes veneered ply also for furniture grade work. They also have prefinished maple and birch. The core composition is the same for the veneered ply as well.
Offline Holmz
« Reply #25 on: May 06, 2017, 09:48 PM »
Bob,
Thanks,
I go so far as to agree that the plywood does look nice.
Offline Thebesciak
« Reply #26 on: May 06, 2017, 10:10 PM »
as long as there is no rocks and little pebble stones inside of the plywood it is OK  [embarassed]
« Reply #27 on: May 06, 2017, 10:13 PM »
I have tried multiply times to post some good face shots as Seth requested but for some reason I can't post photos. I've been using  this for about two years with great results I usually go through about two units a month. We only do high residential cabinets and we were having a lot of problems from Columbia forest products once they changed there adhesive formula to meet new CARB compliance we were dealing with a lot of core de-laminations and veneer splits. Garnica has none of these issues and it's lighter.
« Reply #28 on: May 06, 2017, 10:15 PM »
It's a product of Spain not China so you don't have to worry about all the foreign objects that can be found in that Chinese crap.
Online kevinculle
« Reply #29 on: May 07, 2017, 08:34 AM »
My supplier also stocks Garnica and my experience with it has been similarly positive.  I think for the last purchase I made this year for a cabinet build the 3/4" maple prefinished both sides was around $90 a sheet and the 1/2" maple prefinished one side was in the mid-$60's a sheet for small orders.
