Author Topic: How many Canadians are swapping their Mini/Midi for CT 26?  (Read 22330 times)
Offline hockey_magnet
Just curious what others are doing regarding the CSA situation.
Chris
Offline Jeff Zanin
Re: How many Canadians are swapping their Mini/Midi for CT 26?
« Reply #1 on: August 09, 2013, 08:03 PM »
I have a CT22 which is equipped with handle and boom arm, so it is great is the shop but awkward to transport.
So I have been considering a second DC and going back and forth between the MIDI and CT26, but it seems the CSA issue has taken that decision out of my hands.
Jeff
Offline Rustbucket
« Reply #2 on: August 09, 2013, 08:31 PM »
Just curious.  I'm not from Canada, but what is the CSA situation?  What makes the Mini/Midi not comply?  Is it similar to the RRP here in the states?
Online Peter Halle
  • Another Avatar Coming Soon
« Reply #3 on: August 09, 2013, 08:51 PM »
The issue as I understand it - remember I am not in the official loop - is that three Festool tools were discovered to not have the equivalent Canada approvals to the UL listing here.
Insurance requirements for companies may have a clause that mandates the use of tools having the CSA listing in Canada.
Offline CarolinaNomad
« Reply #4 on: August 09, 2013, 10:13 PM »
Considering that I have the CT-36, another big vacuum doesn't make sense to me.  I doubt I'll make the swap.  I mean, how many inspectors are going to notice the CT Midi is not in compliant?
Jeff
resides in NAINA
Offline Brice Burrell
  • Remodeling Contractor
    • The Green and Dark Blue blog
« Reply #5 on: August 09, 2013, 11:09 PM »
Like Peter, I don't know the particulars regarding the CSA listing for Canada and I assume this is a issue for some insurance companies for professional contractors.  So I don't think you need to be concerned about inspectors but rather your insurance company (if you're a professional).  If it makes you guys feel any better we have the same issue here with insurance companies and UL/CSA approved equipment in the States.
Offline GRegghead
« Reply #6 on: August 10, 2013, 12:12 AM »
I'm still on the fence about switching. The MIDI suits my needs much more than the CT26 does though.
What are the risks for a hobby woodworker using a non CSA compliant vacuum? My MIDI is only 3 months old; if I need warranty work I'm sure Festool will force the switch at that time. What about vacuum bags? It may be that Festool stops Canadian dealers from selling bags as a way to force the compliance with the recall.
I would prefer to keep my MIDI, but it may become a hassle to do so in the long run.
Offline Peter Durand
« Reply #7 on: August 10, 2013, 10:43 AM »
If it becomes a hassle, you are close to Bellingham. I hope it doesn't though because we have great dealers in the Vancouver area.
« Reply #8 on: August 10, 2013, 11:05 AM »
For me, being a hobbyist, I thought it would be no brainer to switch. I'll be honest. I bought the Mini mainly because of the price considering it has the same suction, Hepa, etc. and I didn't think capacity would be a big deal as a non pro user for my small home renos for myself and friends,.I have a Kapex, TS 55, 2 sanders and a 1010 (used rarely) that I use the vac for.  Thinking a bit more about it since although the weight empty is no issue at all, I've emptied a very full CT 26 and I know that the weight can be a lot more when full or nearly full compared to the Mini or Midi. My Mini is just a year old. If it was going on 3 years, that would be more of a factor. I'm still leaning to the CT 26 even though since I store it in a spare room - no workshop - my wife thinks smaller is better  [big grin].
Does anyone know on these types of recalls if Festool's warranty "starts over" for the new tools?
Thanks,
Chris
« Reply #9 on: August 10, 2013, 11:28 AM »
Thanks,
Chris
Chris, you guys up North need to consider future support of the Mini/Midi as GRegghead brought up.  Unless you absolutely need the smaller size vac I wouldn't risk holding onto the Mini/Midi without knowing Festool will support the products long in the future.
« Reply #10 on: August 10, 2013, 11:30 AM »
Thanks,
Chris
Thanks Brice, I kind of "assumed" that support would be available since I thought the vac is identical to the USA model which they are still selling, but you  and GRegghead raise a good point.
Chris
Offline nanook
« Reply #11 on: August 10, 2013, 01:07 PM »
I am switching to a CT26.
I actually was not going to return my Midi.
In the end I decided to keep my CT Midi,  however it was a bit over a year old and the front plug was not keeping the power cords in (it just falls out all the time).
My issue with the recall (I actually talked with a few people at Festool who told me on the phone that "there is a recall on the CT Midi in Canada") has been that the CT26 is not a comparable replacement to the CT Midi or Mini in terms of size and portability.
Reportedly I have been told by Festool representatives that the only option is to exchange my CT Midi for a CT26.
However, when I offered to bring them to small claims court - they did offer to refund my Midi w/ receipt.   Fair enough.   I would like to know why that is not a standard option as it was for the TS55 recall that is also currently happening?
In the end a stock CT26 was not a good replacement for me - and since I had a minor issue with the CT Midi (see above), I decided to get that fixed under warrantee and to just keep the unit for personal use.
When I tried to warrantee the plug, I was told that Festool can not preform any work on the Midi in Canada - after explaining why the CT26 was not a suitable replacement b/c of mobility issues and that their not being able to make warrantee repairs was a problem, we were able to resolve the issue and Festool is replacing my CT Midi with a CT 26 and their including the rear accessory handle at no charge to maintain that mobility. Bags will be refunded or replaced with receipt.
Just received my UPS label yesterday and will get the unit in the mail Monday.
We will see how this goes, but 'cautiously' optimistic that Festool may have gotten their ducks in a row.
At this point, I'm cautiously happy with the resolution to the issue.
« Last Edit: August 10, 2013, 01:12 PM by nanook »
« Reply #12 on: August 11, 2013, 11:48 AM »
Nanook - did you have any discussion around what the warranty on the new CT 26 would be?
Chris
Offline Saskataper
« Reply #13 on: August 11, 2013, 01:06 PM »
This whole thing really sucks for me, I am starting a big contract on Monday repairing water damage in a condo complex. It's been on the books for months and I had planned on picking up a mini just for it as there are 65 units spread over 20 2 and 3 story buildings that need repairs ranging from small water stains to removing and replacing large sections of drywall, all in occupied units so dust containment is a huge issue. Lugging my 36 AC up 3 flights of stairs for the 5 or 10 minutes it will get used would be a big pain, the mini would have been perfect. I guess I'm stuck with my noisy little ridgid toolbox vac.
Offline Frank-Jan
« Reply #14 on: August 11, 2013, 07:38 PM »
After I got my ctl26, I purchased a boom arm for my old CT22.
So when I'm not using the boom arm, the CT22 has the "Accessory handle", and the "mobility" hasn't improved at all.
« Reply #15 on: August 11, 2013, 08:03 PM »
Furthermore, the handle makes the CT26 vac so much larger I can't see how this could be a suitable replacement for the Mini/Midi in regards to small size.
Offline nanook
« Reply #16 on: August 11, 2013, 11:10 PM »
really, thats a problem for me then.
It looked OK at LV.
My issue is not space in the truck, its navigating narrow stairways in old Victorians.    Seems w/ the handle you can just pull it like a cart up the stairs?
I know the CT26+ is too wide (esp w/hose) to easily carry sideways up the stairs (and too long and awkward to hand carry the other way).
I like being able to use the vac to roll systainers into sites - so the accessory handle may be my best compromise.
I'd just like my Midi certified though
« Last Edit: August 12, 2013, 12:05 AM by nanook »
« Reply #17 on: August 12, 2013, 09:23 PM »
It looked OK at LV.
Not sure where you are in Canada but in Winnipeg I can get any electrical device approved by the department of labour for a fee, if there is anything wrong with it they will let me know.
Offline nanook
« Reply #18 on: August 12, 2013, 11:41 PM »
sent it back, but thanks there.
IMO Festool really should have taken care of it if that is the case.
thanks though!
Offline nanook
« Reply #19 on: September 18, 2013, 01:38 PM »
Just to wrap this up - despite being told they were reimbursing Midi bags twice by Festool reps (and incl receipt) - I just received my box of bags back, well over a month later. No note, nothing.  Festool?!
Offline Frank Pellow
  • Toronto, Ontario and Lake Pivabiska, Ontario
« Reply #20 on: September 18, 2013, 02:05 PM »
I'm certainly keeping my mini.  I don't want to tote around anything larger.
(p.s I also have a CT 22 hooked up to a Festool WorkCentre but it stays in my workshed).
« Last Edit: September 21, 2013, 08:32 AM by Frank Pellow »
Cheers,
               Frank (Festool connoisseur)
Offline GhostFist
« Reply #21 on: September 18, 2013, 02:19 PM »
I still have to find an appropriate time where I won't need the thing for a week. plus I have to box it up somehow in order to ship it. Not happy with this. The midi is a good vac (was)
Offline nanook
« Reply #22 on: September 18, 2013, 09:07 PM »
FYI it was closer to two weeks for me.   I had some jobs scheduled and it was a real pain to get an estimate of when I'd see it back once the unit had arrived.    Actually I never heard back on that one really despite calling - the dang things just showed up one day.
Handle showed up a few days later.   It was a real pain not knowing when the unit would arrive back and it being out closer to two weeks them the one week I was estimating.    Shipping wise it was delivered/received the next day - so it was a hold up at Festool's end.
Offline Dogwood
« Reply #23 on: September 19, 2013, 01:17 AM »
The only other model I'd want other than my midi is the 36ac. Doug think festool would allow me to pay the difference between the 36ac and the 26 they are offering for my midi?
Offline nanook
« Reply #24 on: September 19, 2013, 02:28 PM »
I did ask about just that Dogwood.   I was told that was not an option
Offline nanook
« Reply #25 on: September 20, 2013, 11:52 PM »
I am no longer able to post in this thread - any comments I make regarding Festool's service are being removed by the Moderators.
Offline SRSemenza
« Reply #26 on: September 21, 2013, 12:32 AM »
None of your comments about Festool service have not been removed. The posts that were removed did not contain any content related to Festool service or your experience with Festool.
         One was removed because you posted a PM.
         Another was removed because you posted information contained in said PM , paraphrased to skirt the rule and privacy of said message.
         And another was removed because you  insist on continuing to make posts such as the above to get a reaction and stir up a flame  war in this and the other related thread.
         The duplicate postings of those posts were removed also.
     Again none of the removed posts contained anything of value to add to the conversation. And all of your comments and experiences with Festool service are intact in this and other threads for everyone to read.
Further postings to continue this dialogue and turn it into a useless argument will be removed.
SRSemenza   FOG Moderator
« Last Edit: September 21, 2013, 01:07 AM by SRSemenza »
« Reply #27 on: September 21, 2013, 10:49 AM »
OK, silly question here: what is a PM?
« Last Edit: September 21, 2013, 10:52 AM by Peter Durand »
Online Peter Halle
« Reply #28 on: September 21, 2013, 11:19 AM »
A PM is a personal message - the contents of which are to be kept private and between the parties involved in the message.
Online Kevin D.
« Reply #29 on: September 21, 2013, 12:28 PM »
Looks like there is an official recall/release page now on the Festool website, but there is a typo/error that is kinda comical.
http://www.festoolusa.com/service/ESA/
http://www.festoolusa.com/service/ESA/questions/
Kapex, CT-SYS, SYS-Cart, Pro 5 Sander, CT36AC, TS75, MFT 1080, MF-SYS/2, PS300 EQ-Plus, Parallel Guides Set, LR32 SYS, RO 150FEQ-Plus, OF1400 EQ Plus, DOMINO 500 Q-Plus,  Domino XL, MFK 700 EQ-Set, FS-SYS/2, CT22 w/hose storage, D36HW-RS-Plus, FS 1900/2, FS 3000/2, FS 1080/2-LR32, FS 1400/2-LR32, Gecko, Festool Floor Mat, Festool Stein, Multi-Tool, tape measure, large and small Festool floor mats (foam rubber).
