Pages: [1]   Go Down
  Print
Author Topic: workshop tv  (Read 1018 times)
Alan m
Online Online
« on: July 05, 2012, 07:05 PM »
hi there.
i am thinking of putting a tv in my workshop for watching matchs or formula 1 . you know thinks that you follow but dont have to be glued to.
i have a corner in my shop  where my dc system (not in yet ) will use 45 * fittings to do the90*. there will be a 2' 45* section of presses (full run not done yet but started a while back).
i was thinking of putting a sheet of toughened glass across the front   to keep the dust out (turning , non festool tools etc) .
i was thinking of drilling 2 holes (2")in the wall ,top and bottom ,so that the tv wont overheat due to no circulating air.
i am also a small bit worried about the dust catching fire on something inside
does this seem overkill.
now
wish list
PaulMarcel
Offline Offline
WWW
« Reply #1 on: July 05, 2012, 07:38 PM »
If the TV is a modern flat-panel LCD, you shouldn't have to worry about sparks igniting dust.  Old CRTs had a lot of voltage that could arc and ignite dust in the past.  If you are putting a plasma display in there (Mr Fancy Pants...) then there is high-voltage in there.
I'm typing this on my shop computer and it is 96F in here now.  The computer itself is in a closet in the house with a long HDMI cable to this wall-mounted monitor.  It works fine (my webcam, however, shuts off audio once it gets over 102F... regrettably, I know!)
Covering the TV to protect from dust likely won't work well and may not be good for it.  Dust will find its way behind the cover and drive you nuts.  Leave the screen as is.  If you want to protect against projectiles, put the screen away from the TV a bit for access to clean the screen.
I rarely clean my screen out here.  Your turning won't generate dust.  Wipe the screen down with some eyeglass cleaner as most have anti-static chemicals added so it won't attract dust.
Just no pay channels in the shop; too distracting.  Tongue Out
Shirt size: L Cool
Twitter: @HalfInchShy
Steve R
Offline Offline
« Reply #2 on: July 05, 2012, 10:40 PM »
Allen,
When I lived in Ireland for a year..back in 2002  I never saw more than 74 degrees and then for four hours.... Heat is not an issue in Ireland... unless global warming has picked up... I don't think heat is every going to be an issue.
If you have a compressor ...just blow it off, out...
If you put in behind glass you might get some issues with heat.... but if you put in one or two "computer fans" that pull outside air by it... no issue...
I loved the F1 coverage, while I lived there... Here..... most of the time all we hear is yea someone one an F1 thing... Ahhhhhh!
Cheers,
Steve
Alan m
Online Online
« Reply #3 on: July 06, 2012, 03:28 AM »
i was planing on buying a small cheap flat screen (probably lcd) and a free to air  satalite recever. nothing to stimuulating.
i wouldnt be doing anything major  with the tv on but it would be nice to be out there  organising or thinking  about a project ect while watch  a match etc.
there is a shocking amount of dust sanding on the lathe and it is very hard to extract.
now
wish list
Pages: [1]   Go Up
  Print
Jump to:
