Bob Marino
Festool Dealer
Online
« on: June 07, 2011, 05:46 PM » |
Ok, after checking around a bit, looking at demos, speaking with Apple staff, I decided to take a bite out of the Apple for myself. Got the 27" IMAC. I also bought the MC Office for MAC. iBeautful graphics, lots of whiz, but - at this point in time, am regretting the decision. Got it home Sunday AM after getting my files and docs loaded up from my PC and getting a 1 hour introduction. Froze up about 3 times that night and had login issues with passwords and had to make a few calls to Apple-care. Festool has a simple Excel sales order form used for dealers to place their Festool orders and am unable to get past the Excel error message, even after long calls to Apple support and talking with the Apple in store help. I am going to have to speak with MC about resolving this issue. My warehouse uses a Citrix based login system and was unable to log on - due to error messages - even Apple staff were unable to get on. Finally a friend got me logged on, but the F9 key (the most used key for me to check inventory) does not work properly (even after holding the fn and command key). So at this point am using my older PC to check inventory. Now, I totally understand that there is a learning curve from PC to Apple - and a huge learning curve for older, untechy guys like me; but the 2 most important/most used areas - using Excel for Festool ordering and checking inventory have yet to be accomplished - this after almost a dozen service calls and hours spent on work arounds.
I so do understand why some people like the MACS, and I want to like it too, but right now, it ain't working for me. Soooo, I will continue to muddle through, go to the classes and call that help line, but unless things change 180, I'm going to return it.
Bob
fidelfs
Offline
Houston, TX
« Reply #1 on: June 07, 2011, 06:18 PM » |
Bob,
I am not at home (working in Albany, NY) and I have a crappy PC (windows) with me, If I remember correctly you don't have to press cmd key, only Fn and F9.
Could you map the F9 to another key?
Fidel
There is never a situation where it can't be done with the right hand tool - even though it may be a lot more work.
fidelfs
Offline
Houston, TX
« Reply #2 on: June 07, 2011, 06:29 PM » |
Bob,
What happen whey you press F9?
Fidel
Peter Halle
Global Moderator
Offline
« Reply #3 on: June 07, 2011, 06:56 PM » |
PM sent.
pugilato
Online
« Reply #4 on: June 07, 2011, 06:58 PM » |
That doesn't sound right... Apples generally work right out of the box. Excel files not opening even though you got Excel installed? No. Something is not quite right.
Alan m
Offline
« Reply #5 on: June 07, 2011, 06:59 PM » |
i dont know anything about apple or the mac but i got a shock when i read the title . imac(probably immac) is a womans hair removal cream scraper thingy
pugilato
Online
« Reply #6 on: June 07, 2011, 07:01 PM » |
... and with that, I declare I have nothing further to add.  ) too funny.
jmbfestool
Offline
« Reply #7 on: June 07, 2011, 07:01 PM » |
I hated My iMac but love it now! Not working seems odd like mentioned should work fine out of the box. Never had problems with mine runs super fast with solid state hard drive 4core love it!
Jmb
GPowers
Offline
Metric convert
« Reply #8 on: June 07, 2011, 07:24 PM » |
We have both Macs and winPCs in the office. We have one application that does not work on the Macs so we to use the Windows version of Cirtrix. Which is basically just a dumbed down version of Citrix. It works great, no problems. Even with all the Apple WWDC hype (lion, iOS5 and iCloud) I still feel that Apple is a much better computer for the home and personal use. When is comes to business and the business environment Windows seams to be to goto operating system and applications. OK, duck for cover and keep the flak jacket on....
« Last Edit: June 07, 2011, 07:59 PM by GPowers »
Greg Powers Size:XL
GhostFist
Offline
« Reply #9 on: June 07, 2011, 07:42 PM » |
I refuse to post in this thread
fdengel
Online
« Reply #10 on: June 07, 2011, 08:03 PM » |
Bob,
F9 is assigned to one of the Exposé functions by default, so the OS is intercepting that particular key before the application gets to see it.
Try changing the key assignment to something else to free up F9 and see if that fixes the problem:
Under the Apple menu, open System Preferences.
Click on Keyboard, then select the Keyboard Shortcuts tab.
Select "Exposé and Spaces" from the list on the left, and either turn off the "All Windows" option (which is assigned to F9 on my Mac -- probably on yours as well, as this is the default), or double-click on the "F9" in the list and assign a different key for that.
See if that fixes your issue with accessing that feature under Citrix.
I had to take a similar approach to moving the Dashboard button from F12 to F13 because of needing F12 for use within Blender...
Also, another tip: on the "Keyboard" tab, there is a checkbox "Use all F1, F2, etc. keys as standard function keys", which inverts the behavior of the "fn" button -- if you check that, then the Fn keys act as Fn keys by default, and you hold the "fn" button to get the pictured behavior, instead of the other way around.
I just found that one myself and turned it on; pleased to have done so, as I would rather have the Fn keys easier to access -- I believe I will wind up using them more often.
You certainly shouldn't be experiencing freezes or anything of that nature; is everything up-to-date from Software Update? You can choose that from the Apple menu to check; also, try opening Disk Utility (open the hard drive, then the Applications folder, then the Utilities folder; should be in there), select your hard drive from the list on the left, and click on the "Repair Disk Permissions" button. See if that comes up with anything; sometimes a rogue installer (even Apple's software updates on occasion) or will mess up permissions on something important somewhere; that feature of Disk Utility will usually be able to find and correct that in the event it comes up.
I don't use Excel on my mac, but I've opened some Excel files with other programs before and never really had trouble with the limited use I needed to get out of them. OpenOffice.org has a free version out that seems to handle the majority of them fairly well... regardless, what error are you getting?
Kevin D.
Online
« Reply #11 on: June 07, 2011, 08:12 PM » |
Every so many years, I tinker with the idea of going to Apple for my PC's. But I always stop dead in my tracks when I speak to software support people who provide me with proprietor software for the business I'm in, who all seem to advise that they will not support Mac issues running their software, and are aware that Macs don't work well or at all with them. Guess I'll have to wait until I retire.
TS75, MFT 1080, MF-SYS/2, PS300 EQ-Plus, Parallel Guides Set, LR32 SYS, RO 150FEQ-Plus, OF1400 EQ Plus, DOMINO 500 Q-Plus, MFK 700 EQ-Set, FS-SYS/2, CT22 w/hose storage, D36HW-RS-Plus, FS 1900/2, FS 3000/2, FS 1080/2-LR32, FS 1400/2-LR32, Gecko, Festool Hat, Festool T-Shirt (2), Festool Floor Mat, Festool Stein.
Wish List: Kapex, and more sanders.
b_m_hart
Offline
« Reply #12 on: June 07, 2011, 09:27 PM » |
Get bootcamp. Set it up to dual boot Windows and osx - and you'll be happy as a clam.
TS 55 EQ, ETS 150/5, RO 150 FEQ, OF 1010 EQ, DF 500 Q, C12, CT Midi, OF 2200 EB, MFT/3s, DTS 400 EQ, parallel guides, and seemingly growing by the day...
GhostFist
Offline
« Reply #13 on: June 07, 2011, 09:30 PM » |
Resisting!
Ken Nagrod
Restricted
Offline
« Reply #14 on: June 07, 2011, 09:37 PM » |
PeterK
Offline
« Reply #15 on: June 07, 2011, 10:15 PM » |
Sure sounds like there is a hardware defect to begin with. I think you really need to return it for an exchange or have them troubleshoot it at the shop if you can duplicate the issue in their presence. Would not surprise me at all if this is not caused by defective memory. A couple "manufacturers" currently are having a rash of problems with defective memory boards from China for the Macs as I have experienced. Crucial admitted lots of defective memory over the last few months.
I have several Macs all working fine. No issues with MS Office. If you get the Mac running solid, open the Apple Help and search for Bootcamp. If you have a new full-install version of Windows, you can set a dual-boot as mentioned earlier. A little clumsy to set up but works great. You can if desired never use the Mac OS and always run it as a Windows machine. I have found the Apple hardware to be very reliable with the 4 machines I am using. Pete
NuggyBuggy
Offline
Location: Toronto, Ontario, Canada Member Since: Mar 2010
« Reply #16 on: June 07, 2011, 10:22 PM » |
Something is definitely wrong with that computer, and like the previous poster suggested, it sounds like bad RAM. Take it back to where you got it, and exchange it for a new one. I bet all your problems go away. Don't resign yourself to the purgatory that is the world of Windows just because of one bad stick of RAM.
“I am on a drug. It’s called Charlie Sheen.”
WarnerConstCo.
Offline
« Reply #17 on: June 07, 2011, 10:32 PM » |
Get a bigger hammer Bob.
Bob Marino
Festool Dealer
Online
« Reply #18 on: June 07, 2011, 10:40 PM » |
Why would you say bad RAM?
I just may bring this into the store next week. Lots of quirky things - like right here on the FOG; when I scroll down to the last post, the screens shoots right back up to the top of the page, I mean like ? I will give it more time as I see some of the beauty of the beast, but right now, there's more beast than beauty.
Bob
Ken Nagrod
Restricted
Offline
« Reply #19 on: June 07, 2011, 10:42 PM » |
Bad RAM can cause a computer to freeze up.
pugilato
Online
« Reply #20 on: June 07, 2011, 10:57 PM » |
I'm telling you... there's something wrong with that particular unit. Apple would not be where its at selling defective equipment.
djwong
OfflineMember Since: Sep 2008
« Reply #21 on: June 08, 2011, 01:56 AM » |
Bob,
I don't think there is enough information about your problems to diagnosis the situation. From your general descriptions, it would seem to me to be more likely a software problem and not bad RAM. Unfortunately it takes a lot of effort and time to isolate a computer problem. Since time is money, you may not be able to afford the time right now.
If you want to go through the exercise, you must isolate the problems by eliminating any add-on hardware or software on your machine. Try to uninstall any applications you added and see if you are still having browser problems (jumpy screen). Are you using Safari or something else? If your log on problems are problems logging onto your iMac, then there is a system software problem and you should bring it back, or reinstall the system software from the system DVD's (WARNING - this will wipe out your data so don't do unless you have a certain backup). I kind of assume your log on problems are logging onto web sites through the browser. As another poster said, keyboard mapping may be playing a roll in the confusion. Go to the apple menu and select "System Preferences", then click on the "Keyboard" icon. There is a list of all system assigned keyboard shortcuts.
Expect to spend a few hour to isolate the issue. I have never had a debugging session go quickly. Of course you can schedule a session with an Apple help person to go through this under your warranty. There are many of us on FOG who can also help. Unfortunately for meaningful help, a lot more detail is necessary on what you installed and when problems started occurring.
-David
NuggyBuggy
Offline
« Reply #22 on: June 08, 2011, 09:24 AM » |
Intermittent and impossible to predict lockups and freezing problems are often indicative of bad RAM. In the build-your-own PC world, it could also be the result of things like overheating or a too-small power supply, but you probably don't have to worry about those issues. I'd probably run a memory test utility like memtest (Mac version available here: http://osxdaily.com/2011/05/03/memtest-mac-ram-test/) to check it. Let us know or PM me if you have trouble figuring out how to run it. It probably wouldn't explain your login issues, though.
Bob Marino
Festool Dealer
Online
« Reply #23 on: June 08, 2011, 09:47 AM » |
Well, I will give Apple a call today or tomorrow and may even bring my IMac into the store. But what I am not going to do, is start running a bunch of tests or installing and reinstalling discs and software and try to patch it up myself. I will see what they have to say as they have been very helpful - but i learened more here on the FOG than in 3 phone calls! of this could be a learning curve too, but the freezing has me concerned.
Thanks all again.
Bob
pugilato
Online
« Reply #24 on: June 08, 2011, 09:50 AM » |
good luck with that... let the experts do their thing.
Tom Bellemare
Festool Dealer
Online
« Reply #25 on: June 08, 2011, 10:24 AM » |
like right here on the FOG; when I scroll down to the last post, the screens shoots right back up to the top of the page I have a wrist pad in front of my keyboard for comfort. Sometimes I rest my coffee cup on it. Occasionally, when reading a thread, I can't get it to stop scrolling to the bottom of the thread. It's because my coffee cup is pressing the space bar. Tom
RL
Online
« Reply #26 on: June 08, 2011, 10:33 AM » |
Bob,
I have the same 27" IMac as you and I remember when I first got it that the Nikon software I was running would freeze from time to time, unlike on my previous generation 24" IMac. In time, Nikon released a fix and now it runs fine.
I also have the Microsoft office software on my IMac and it generally runs fine. Updates are being released all the time, however, so run a "Check for Updates" and see if you have the latest version.
All the best Richard.
I like green.
NuggyBuggy
Offline
« Reply #27 on: June 08, 2011, 11:10 AM » |
Running memtest would not require you to open up your computer, it's dead simple and would allow you to simply walk into the store, tell them your memory is bad, and they'll fix it for you. It might actually save you time. But if you're not willing to do that, you could also just pick up your computer, take it to the store, and ask them to check the RAM.
djwong
« Reply #28 on: June 08, 2011, 12:55 PM » |
The mac ships with a hardware diagnostic you can run. It should be on one of the install DVD's that came with your computer. When you find it, insert the DVD and restart your computer. Hold the 'D' key down on restart. 'D' stands for "diagnostics". See this link for the Apple Support page for details. An error code will be reported if there is a problem.
justinmcf
Offline
Location: Gold Coast, Queensland, Australia Member Since: Nov 2008
Queensland Builder
« Reply #29 on: June 08, 2011, 05:00 PM » |
i bought the 20 inch mac last year and love it. i cannot understand why you are having so many problems bob. with regards to running tests. i am very low tech and have no interest in spending time trying to fix something that should work out of the box. it should be running smooth for you, the fact it is not, means something is wrong. just bring it back and get a new computer. problem solved, and you will be much happier once you get going properly.
justin.
pugilato
Online
« Reply #30 on: June 08, 2011, 05:05 PM » |
justin.
What he said... life is so much simpler when you dont feel compelled to personally repair every little thing. It takes too much time, and costs more money than letting the guy who knows how to do it, do it.
Don T
Offline
Phoenix, Az
« Reply #31 on: June 08, 2011, 11:26 PM » |
Bob
Bob did you buy it from an Apple store or online? I bought mine online and the seller put crappy RAM it and I had all sorts of problems. Bring your computer to Apple and they will take care of the problem, I got a whole new computer before they found the problem.
RO150, C12, DF 500 Q, CT33, TS75, MFT3, Kapex 120, MFT3/Kapex, MFK 700, RO 90, ETS150/3, CT22, Centrotec Installers Kit
Bob Marino
Festool Dealer
Online
« Reply #32 on: June 09, 2011, 07:13 AM » |
Bob
Bob did you buy it from an Apple store or online? I bought mine online and the seller put crappy RAM it and I had all sorts of problems. Bring your computer to Apple and they will take care of the problem, I got a whole new computer before they found the problem. No, I bought it at the Apple Store; and am bringing it in today. It froze up again last night and I had to restart it. Bob
Bob Marino
Festool Dealer
Online
« Reply #33 on: June 09, 2011, 07:16 AM » |
like right here on the FOG; when I scroll down to the last post, the screens shoots right back up to the top of the page I have a wrist pad in front of my keyboard for comfort. Sometimes I rest my coffee cup on it. Occasionally, when reading a thread, I can't get it to stop scrolling to the bottom of the thread. It's because my coffee cup is pressing the space bar. Tom [/quote Tom, Nope, nothing on the keyboard - I only wish that was the answer. Equally as concerning is the fact that it seems to be random - as in it isn't doing it right now and I didn't do anything different. Bob
fdengel
Online
« Reply #34 on: June 09, 2011, 07:39 AM » |
If you have the so-called "magic mouse", the whole finger-swipe thing evidently takes some practice. I'm using one right now because it came with my Mac Pro and I'm still in the process of getting things switched over from my iMac, but my Wacom tablet will eventually replace it.
I find that it can be tricky to manage the scrolling and such with that mouse, particularly when just getting started with it.
I suspect there are some other gestures involved too, because I occasionally find that I jump back a web page (as if hitting the "back" button on the browser) depending on how my finger manages to swipe the mouse (often by accident), though I haven't been able to nail down the actual gesture yet.
I'm not taking time to work it out though; like I said, the Wacom will be replacing it soon anyway...
Peter Halle
Global Moderator
Offline
« Reply #35 on: June 09, 2011, 07:41 AM » |
Good luck Bob! Ironically yesterday Apple released a fix for imacs locking up. http://reviews.cnet.com/8301-13727_7-20070210-263.html?tag=mncol;1nPeter
Bob Marino
Festool Dealer
Online
« Reply #36 on: June 09, 2011, 08:12 AM » |
Thanks Peter, I'm going in at 11 am today and will let them see what's up I just did a diagnostic test with the disk and it shows no problems with the hard drive. No more testing or playing with the disks, keys or programs; I'll let the guys at Apple take over. Bob
Ken Nagrod
Restricted
Offline
« Reply #37 on: June 09, 2011, 08:39 AM » |
Bob, If everything is fixed today, does the title of this thread change?  I'm happy I'm somewhat happy screw it, I'm a PC
« Last Edit: June 09, 2011, 10:38 AM by Ken Nagrod »
BlueMaxx
Offline
« Reply #38 on: June 09, 2011, 11:31 AM » |
Bummer Bob...
Bought my big iMac three years ago to get away from PC and have never had an iota of trouble from it...so I am betting it's just an unfortunate lemon....
I think once you get past the slight learning curve you will really like it...
Either way do tell what the resolution is..
Cheers,
Mike
Frank-Jan
Online
« Reply #39 on: June 09, 2011, 11:52 AM » |
... Either way do tell what the resolution is..
Since it's a 27" imac, my guess is 2560 x 1440.
Bob Marino
Festool Dealer
Online
« Reply #40 on: June 09, 2011, 12:09 PM » |
Am at the Apple store and it froze up here and they are setting up a new IMac.
BlueMaxx
Offline
« Reply #41 on: June 09, 2011, 12:22 PM » |
pugilato
Online
« Reply #42 on: June 09, 2011, 01:30 PM » |
Sweet... it has always been my experience that when I take something that's broken to the guy who can fix it, it always works. Its not fixed, of course, and its why people who fix things think that those who dont are morons.
Ken Nagrod
Restricted
Offline
« Reply #43 on: June 09, 2011, 01:37 PM » |
Just in my experience over maybe the last couple of years, Apple's first line of tech support people are morons knowing maybe slightly more than the people calling in and reading off of a computer screen to give you answers. It's finally when they transfer you up the line to the second level of tech support that you get real technically knowledgeable individuals that solve your problem.
Tim Raleigh
Offline
« Reply #44 on: June 09, 2011, 01:43 PM » |
Bob: You are a much more patient man than I. I would be furious. Sorry this is happening. I would have thought problems would have started to appear after about year or so... Tim
Bob Marino
Festool Dealer
Online
« Reply #45 on: June 09, 2011, 01:54 PM » |
Tim, If there is a problem and people are responsive to that problem I tend to give them the opportunity to correct the situation. Apple is not where it is by providing bad products more poor service. Was it frustrating having the computer freeze several times within the first hours of use? Yep, and the after about the third call in as many hours, the service rep at Apple Care got an earful from me. Hopefully it will work out soon. Bob
Tom Bellemare
Festool Dealer
Online
« Reply #46 on: June 09, 2011, 02:37 PM » |
Bob:
A good friend of mine that lives about a mile from here got a new iphone recently. He was using it to demonstrate some mobile app's for publishing and decided to upgrade the operating system Saturday morning to the latest and greatest.
Saturday, Veronica and I were taking her nephews to the farmer's market and my phone rang. It was my buddy's mobile number calling but nobody would answer so I hung up. Very soon after, it rang again. It was him and 'same thing, no answer. This went on several times and I decided to go to his house, which was sort of on the way and ask him to stop calling.
He saw us pull up and came out of the house with his phone in hand laughing. He quickly explained that when he upgraded the OS, the phone started dialing my number (the last dialed number) over and over. I told him to call the Apple store and let it call them over and over instead of me. He couldn't get to it to dial anyone else because it was too quick.
He finally turned it off and went to the Apple store. They argued with him and said what appeared to be some really stupid things like, it's impossible to revert to the prior OS (which worked). He explained to the guy that they could wipe out the phone and start over and they insisted that they couldn't install the previous OS.
Anyway, they gave him a "new" phone - it had the older, working OS and now everything is fine.
Apple is a good company but the mystique around them is a little overblown. They are certainly not perfect.
pugilato
Online
« Reply #47 on: June 09, 2011, 03:07 PM » |
This is true of just about every company in existence.
tms0425
Offline
« Reply #48 on: June 09, 2011, 03:30 PM » |
Bob, I sure hope you can get this worked out. We've converted to 3 macbooks over the past several years and recently added an iMac for my wife, who was a staunch holdout. I bought my iMac just before the changeover to the new one you have. Overall we've had very few problems other than the typical crummy Apple power cords and batteries. Occasional flakyness is usually solved by a software update which is easy. My daughter's Macbook Pro we bought her for college survived 4 years of undergrad and 2 years of med school and is still going strong with no issues! If you're running some of the typical "corporate apps" like Citrix, you might consider the boot camp option or what I use which is VMWare Fusion running a very small Windows7 instance. Just for those occasions where the applications you buy aren't so friendly to OSX. It is very seamless to do though it opens up that whole malware/virus thing with the Windows partition. Best of luck. Once you get there you won't turn back  Tom
Peter Halle
Global Moderator
Offline
« Reply #49 on: June 09, 2011, 03:47 PM » |
I didn't realize that you were a Mac owner. Go Ken! Peter
Ken Nagrod
Restricted
Offline
« Reply #50 on: June 09, 2011, 04:11 PM » |
 Not yet, Peter. Soon! I bought the ipod touch when it first came out, then upgraded (or got sucked into) to the iphone. That's as Apple as I am so far. Funny thing is I called them today for tech support and had the same crappy experience plus got hung up on while waiting to be transferred to a higher level of tech support.
tms0425
Offline
« Reply #51 on: June 09, 2011, 04:15 PM » |
I've had AppleCare and support has been great. Granted, at the prices they charge, basic care should be great too.
Ken Nagrod
Restricted
Offline
« Reply #52 on: June 09, 2011, 04:20 PM » |
I always pay extra for the Apple Care. It's definitely worth it in my opinion, when you get the right level of support.
Bob Marino
Festool Dealer
Online
« Reply #53 on: June 09, 2011, 11:31 PM » |
Bob:
Well said, Tom and basically I agree with your assessment - admittedly my experience is not the norm for the overwhelming majority of Apple customers. But, while I was waiting to be taken care of, there were plenty of others with machine issues. Bob
NuggyBuggy
Offline
« Reply #54 on: June 10, 2011, 01:02 AM » |
Although the OP seems to have had a hard time with his Mac, I suggest we imagine what his experience would have been if he had bought a PC. Would he be expecting a higher level of service ? Does Dell or HP or Best Buy or WalMart or Staples or wherever he buys his Windows machine from even have a place that he could take his computer to for semi-knowledgeable help ? Every time I've ever had to go to the Apple Store for service, I have been surprised at how well they have handled things.
I have mentioned before that I had a Macbook Pro with a display problem. I brought it in, they quickly diagnosed and confirmed the problem, took my computer. They called me the next day to tell me it was ready. They had already replaced the display. What kind of turnaround could I have expected if I had bought a Windows laptop ? The best I would expect is that I would have received a courier box the next day, probably after running the types of diagnostics that the OP doesn't really want to run anyways. Then the box would be in transit for at least another day, then I'd expect one or two weeks turn around time before the box would be on its way back again. That is the best case scenario of Windows support I can possibly imagine, ( unless I purchased next-day onsite service) and I have lived in the Windows world a long time.
Finally, why argue with differing levels of tech support ? Why not just bring it back and get a new one ? You've already established that you're not interested in doing any sort of diagnostic work. Fair enough. Just return the lemon and start anew.
Ken Nagrod
Restricted
Offline
« Reply #55 on: June 10, 2011, 01:11 AM » |
Nuggy, to be fair, and I hate giving any credit to them, Dell XPS tech/warranty support had parts or parts and a repair technician if I wanted, overnighted next day. I only let a tech replace things once and never again as he did more damage and left screws out plus took the magnet home that puts the computer in sleep mode when the cover is closed.
Also, Bob posted that they gave him a new iMac.
fidelfs
Offline
Houston, TX
« Reply #56 on: June 10, 2011, 09:58 AM » |
I was not able to convince my son to get an apple instead of a pc laptop for college. He gave me the tired reasoning that apple charges you more and you can get a cheaper pc. I told him to compare apples to apples ( not pun intended). Use the same components from a mac book pro to have a similar windows pc, you know what happend. Prices were similar or higher than apple. He didn't take it.
He got a toshiba laptop for college, that laptop broke in April this year, he called toshiba and he has given the turn around and the laptop is not fixed yet. We finally sent it to toshiba instead of waiting for the parts. That was 3 weeks ago.
I will always buy festool for quality and good customer service, same as apple. I know machines can failed or have a lemon, but I need a company to stand behind their products and not just say "sorry for your inconvenience" crap andget some help from them.
Bob Marino
Festool Dealer
Online
« Reply #57 on: June 10, 2011, 12:46 PM » |
Well, I'm that OP and would agree with you that I would have been more frustrated initially if I had to make a long series of prompts and what nots to try and diagnose and fix the freeze ups and non functioning Function keys. I did do a diagnostic test and it did not show anything amiss. At that point, I felt further testing on my part was not something I wanted to do as it is only 2 days old and needs a qualified tech person to do what they are expert at, not a newbie like me doing tests. I would say flat out that the people at APPLE were very helpful. When in the store, they ran some other tests and nothing showed up - until the computer froze right there. At that point, they swapped out a new machine and all looks good so far. Bob
GPowers
Offline
Metric convert
« Reply #58 on: June 10, 2011, 01:09 PM » |
Bob
And that is what make Apple service so great! You get a real , flesh and blood, person to fix your problem. No some phone center on the other side of the world that talks English in a way you can NOT understand them and they keep patronizing you. And I'am basically a Windows PC user (home and office), BUT Over the last two years I have converted my home network to a Apple network products with a mini-mac music server.
« Last Edit: June 10, 2011, 05:27 PM by GPowers »
Greg Powers Size:XL
Bob Marino
Festool Dealer
Online
« Reply #59 on: June 10, 2011, 01:21 PM » |
Bob
And that is what make Apple service so great! You get a real , flesh and blood, person to fix you problem. No some phone center on the other side of the wold that talks English in a way you can NOT understand them and they keep patronizing you. Agree 100% with you and others on this.
Peter Halle
Global Moderator
Offline
« Reply #60 on: June 10, 2011, 01:29 PM » |
Does this mean that you are using it to interact with us right now?
Bob Marino
Festool Dealer
Online
« Reply #61 on: June 10, 2011, 01:59 PM » |
Yep!
joraft
Offline
Location: SoCal (San Fernando Valley) Member Since: Feb 2008
« Reply #62 on: June 10, 2011, 02:07 PM » |
I'm glad the problem showed up in the store, Bob, intermittent problems can be really tough to troubleshoot. I hope things go well from this point on. Reading through this thread has me puzzled though. I've been using PCs extensively for thirty years (business and personal) and haven't had a fraction of the technical and service problems being reported here. I'm feeling kinda left out.
John
Ken Nagrod
Restricted
Offline
« Reply #63 on: June 10, 2011, 02:17 PM » |
John, Want to trade computers? I have a Dell Xtra Personal Stressor craptop.
Peter Halle
Global Moderator
Offline
« Reply #64 on: June 10, 2011, 02:34 PM » |
Reading this thread about the problems and then mentally comparing it to threads about tool issues, the one thing that comes to my mind is that: the more complex things become, the more likely there will be an issue. No matter how much care and testing the manufacturers perform, things will slip by and not work. As demand increases, the numbers of issues will increase, but that does not necessarily mean that the quality has gone down - just that more are being produced and put into use. Successful, painless rectification of the issues at hand is the difference between those companies that have a vibrant repeat business and product referral scenario and those that are stagnant and fighting for growth.
Just my 2.5 cents.
Bob Marino
Festool Dealer
Online
« Reply #65 on: June 10, 2011, 04:12 PM » |
Just my 2.5 cents.
Well said, Peter. Bon
joraft
Offline
« Reply #66 on: June 10, 2011, 04:35 PM » |
John, Want to trade computers? I have a Dell Xtra Personal Stressor craptop.  If you're having problems with it, no thanks. I'd rather feel left out.  By the way, I've had a Dell XPS 1530 laptop for a couple years (now running Win 7) and it has performed flawlessly. However I did have another Dell laptop many years ago with a display that failed. I called Dell and within two hours it was picked up by a courier, and I got it back the next day. I was blown away by the speed with which the problem was handled. I do not recall any other time I've had to take or send any computer to anyone for repair. I did get a disabling virus once long ago, but that was due to my own carelessness. I have never let that happen again. All in all, PCs have served me well for decades, and I have no complaints. I do hope that Bob's new Apple serves him just as well. I know that that OSX's (or Boot Camp's) Windows emulation is not always flawless, and I have had problems with running some software on my MacBook Pros. I hope that Bob does not have that experience with any software he needs to run his business.
John
jmbfestool
Offline
« Reply #67 on: June 10, 2011, 05:49 PM » |
Have you got the Magic mouse or Magic Pad?
If you have not got the Magic Pad then get one! Throw the Magic mouse away Rubbish! I love the Magic Pad AMAZING! I never use the mouse any more! I never want to use a mouse ever again!
JMB
Peter Halle
Global Moderator
Offline
« Reply #68 on: June 10, 2011, 06:43 PM » |
JMB,
Let Bob just get used to the iMac working first. Go for the concept first and then go for the "system". Where have I experienced that before?
Bob Marino
Festool Dealer
Online
« Reply #69 on: June 10, 2011, 07:29 PM » |
John, Want to trade computers? I have a Dell Xtra Personal Stressor craptop.  If you're having problems with it, no thanks. I'd rather feel left out.  By the way, I've had a Dell XPS 1530 laptop for a couple years (now running Win 7) and it has performed flawlessly. However I did have another Dell laptop many years ago with a display that failed. I called Dell and within two hours it was picked up by a courier, and I got it back the next day. I was blown away by the speed with which the problem was handled. I do not recall any other time I've had to take or send any computer to anyone for repair. I did get a disabling virus once long ago, but that was due to my own carelessness. I have never let that happen again. All in all, PCs have served me well for decades, and I have no complaints. I do hope that Bob's new Apple serves him just as well. I know that that OSX's (or Boot Camp's) Windows emulation is not always flawless, and I have had problems with running some software on my MacBook Pros. I hope that Bob does not have that experience with any software he needs to run his business. Good to hear John. Sounds like excellent service to me. Did you any type of "upgraded" service plan? Actually, my software needs are as simple as they come - Excel for orderding from Festool and reading a few spreadsheets, logging onto my warehouse site - (uses Citrix). I will need to call Microsoft regrading Excel and have gotten the Citrix thing to work though not nearly as well as even on my old PC. Also, emailing (OUTLOOK) seems to have been easier on my PC - could be me though. I think I should be ok as I get to find the workarounds. I have one more week until I can return it if I need to, but I don't think that will be the case. I'm wiling to relearn a few things from my PC thinking to use my IMAC proficiently - like redoing the Function keys - again. BTW, had to place another quick call to AppleCare - my CAPS light on the keyboard stopped working. Rebooted the computer and all is well; although I must say, out of the box, I never had to call for a PC issue and am hoping that I won't have to be that familiar with the techs at AppleCare or the Apple Store.  Bob
GPowers
Offline
Metric convert
« Reply #70 on: June 10, 2011, 07:43 PM » |
. BTW, had to place another quick call to AppleCare - my CAPS light on the keyboard stopped working. Rebooted the computer and all is well; although I must say, out of the box, I never had to call for a PC issue and am hoping that I won't have to be that familiar with the techs at AppleCare or the Apple Store.  Bob Maybe this is a sign of Apple growing so FAST and so BIG (larger the Microsoft) that they are having some production, quality, and support problems. Just like all the other big guys?
Greg Powers Size:XL
NuggyBuggy
Offline
« Reply #71 on: June 10, 2011, 08:57 PM » |
Reading through this thread has me puzzled though. I've been using PCs extensively for thirty years (business and personal) and haven't had a fraction of the technical and service problems being reported here. I'm feeling kinda left out.  John, You and I have danced this dance before. You must be extraordinarily lucky because while DOS-based PCs were quite stable, since its advent Windows has long been a cruel joke, so much that it spawned a host of Windows-related jokes - long before Mac OS X became fashionable - and the widely understood acronym BSOD. Two hands are not enough for me to count the number of Windows-based POS terminals I've seen at gas stations that have crashed, for instance. Windows 7 may be more stable but it is a useability nightmare, IMO. You've never experienced as many technical problems under Windows as Mac problems have been listed here ? How many times have you had to debug IRQ conflicts, re-assign DMA addresses, hang out on technical support forums to debug driver incompatibility issues, or edit the registry ? How many times have you had a few hours on the phone with outsourced, overseas tech support ? If not that many, your definition of extensive PC use differs from mine. And I don't even work in tech support, where a common solution to pervasive problems or performance issues is simply to reinstall Windows. Have you ever won the lottery ?
WarnerConstCo.
Offline
« Reply #72 on: June 10, 2011, 10:08 PM » |
I am holding out for the humancentipad.
joraft
Offline
« Reply #73 on: June 10, 2011, 11:23 PM » |
... You and I have danced this dance before. You must be extraordinarily lucky because while DOS-based PCs were quite stable, since its advent Windows has long been a cruel joke, so much that it spawned a host of Windows-related jokes - long before Mac OS X became fashionable
Nuggy, I think "fashionable" is a very appropriate word, as it applies to the Apple "genre". And luck has little to do with it as it applies to the PC world. I think of it more as knowledge and skill in what you're doing.
John
Tim Raleigh
Offline
« Reply #74 on: June 11, 2011, 11:25 AM » |
Reading through this thread has me puzzled though. I've been using PCs extensively for thirty years (business and personal) and haven't had a fraction of the technical and service problems being reported here. I'm feeling kinda left out.  While I have not used PC's for as long a John, (I am not that old  ) I have used them extensively for at least the last 29 years I have not had these problems either. That is not to say others I have worked with haven't had problems with them because they do. The shear number of users with PC's vs Macs (7%) increases the probability of increased problems occurring. Previous to that I only used Apple machines. In our home we have 4 working PC's networked wireless to the internet and to a printer and after each Microsoft update they need to be reconnected to the printer. I fairly certain that this wouldn't be a problem if I had an apple. We may soon add an apple to the stable. My son who is going of to university next year is contemplating getting an apple so if will be interesting if he does indeed get a Mac how the integration into the existing network goes...that is if he ever comes home again  Because we use computers so much, whether you use a Mac or PC a porter cable or a Festool it's really infuriating to have these problems. Tim
GhostFist
Offline
« Reply #75 on: June 11, 2011, 12:10 PM » |
In relation to firmware upgrades and compatibility to your network, there is bound to be problems with third party peripherals regardless of the OS. If said peripheral is designed to be used with both mac and pc you can bet your bottom dollar that that devices firmware will be upgraded for pc first for the sole reason that there is more pc users out there. of course if the product is designed specifically for apple, you would expect the company to be in tune with any changes apple makes. I will point out that apple doesn't really make that many system wide upgrades....well apart for the new $30 firmware upgrade they're about to release (Lion)
joraft
Offline
« Reply #76 on: June 11, 2011, 01:10 PM » |
(I am not that old  ) Few people are.  In our home we have 4 working PC's networked wireless to the internet and to a printer and after each Microsoft update they need to be reconnected to the printer. I fairly certain that this wouldn't be a problem if I had an apple. We may soon add an apple to the stable. My son who is going of to university next year is contemplating getting an apple so it will be interesting if he does indeed get a Mac how the integration into the existing network goes...
Tim, we have two PC desktops and a network printer hard-wired in our system, plus a centrally located wifi hub for our Dell laptop and two MacBooks. And when our daughter and son-in-law visit, they always bring their MacBooks. We have had no problems with any of these devices working together on the network. In fact, the machines sometimes get along better than their owners.
« Last Edit: June 11, 2011, 01:13 PM by joraft »
John
joraft
Offline
« Reply #77 on: June 11, 2011, 01:19 PM » |
Good to hear John. Sounds like excellent service to me. Did you have any type of "upgraded" service plan?
It's been a while, Bob, but as I recall the machine was still under warranty. And I've never had an upgraded service plan. However, I do have a pretty good service plan now, if anything goes wrong with my PCs I fix it myself, and if anything goes wrong with my Macs I just give it to my son-in-law.
John
vidkid26
Offline
Location: East Bay Northern Cali (US) Member Since: Oct 2009
« Reply #78 on: June 11, 2011, 03:10 PM » |
I'm glad the problem showed up in the store, Bob, intermittent problems can be really tough to troubleshoot. I hope things go well from this point on. Reading through this thread has me puzzled though. I've been using PCs extensively for thirty years (business and personal) and haven't had a fraction of the technical and service problems being reported here. I'm feeling kinda left out.  I have been using Apple products since before the Mac. After, let me count, 23 machines from an Apple II to a Mac Pro and a number of phones and ipads, I have had ONE machine that died or needed tech assistance. In my book, that's a pretty good track record. But then again It's just my experience.
TS-75,RO90,Domino,CT-26
Holzhacker
Offline
« Reply #79 on: June 11, 2011, 03:51 PM » |
I started with an Apple II or IIe, can't remember for sure. Before that it was a Tandy? Radioshack job with a tape drive. I vaguely remember I may have taken one of mine in for service, not sure. That's far less than the years of complaints from DOS and windows users I hear.
joraft
Offline
« Reply #80 on: June 11, 2011, 05:03 PM » |
... That's far less than the years of complaints from DOS and windows users I hear.
That's why I took the time to mention my good experiences. Unhappy people generally make the most noise. There must be millions of users like me with little to complain about, so we're seldom heard from.
John
pugilato
Online
« Reply #81 on: June 11, 2011, 07:04 PM » |
this is too funny... every apple/PC thread becomes a back and forth. Its almost worth it to start something every month or so just to see the sparks fly.
joraft
Offline
« Reply #82 on: June 11, 2011, 07:38 PM » |
I thought it was funny too. Bob posts about a problem with his new Apple, the first page or so of posts is mostly disbelief that an Apple could even have a problem, then it moves onto the assertion that his problems would have been much worse if he had bought a PC. So, even when it's an Apple that breaks down it's the PC that gets the criticism.
John
Peter Halle
Global Moderator
Offline
« Reply #83 on: June 11, 2011, 07:59 PM » |
Heck, I am waiting to see if he (Bob) is getting along. Although I love my Mac I have more non Mac computers in my house. I can get stuff accomplished with both, have never had real issues with any except software from Adobe which lead me to buying Macs. Bottom line to me - computers from any manufacturer can do certain things better and faster than I can. If they don't, then they are no good to me in their current state. If that can change - Great. If not - I will look for one that does within reason.
I might be alone here, but there are times I get tired of computers and the nano-second world and the expectations that are created for us non machine inhabitants of this globe.
joraft
Offline
« Reply #84 on: June 11, 2011, 08:55 PM » |
Some of you younger folks might not remember, but there was a time when we could take days thinking about what we wanted say in a letter, and then put more time and thought into actually writing it. Correspondence was a lot slower back then, as well as less frequent. But as I recall, it was usually a lot more meaningful and interesting to read.
John
Ken Nagrod
Restricted
Offline
« Reply #85 on: June 11, 2011, 10:04 PM » |
John,
It's funny to me how you and I have the same laptop (Dell XPS M1530) and you haven't had problems, yet I've had enough problems for several people including a rocky start with Windows 7 upgrade due to lack or close to a lack of driver and chipset support from Dell. I have the top components originally offered for build options so speed and memory shouldn't have been issues. I am running 64-bit though to speed things up and make full use of 8 gigs.
joraft
Offline
« Reply #86 on: June 12, 2011, 11:07 AM » |
John,
Ken, it sure does seem like some kind of luck is involved, either good luck for me or bad luck for you. I can't say which, I know there are a lot of 1530s out there, but I really don't know what their over all reputation is.
John
pugilato
Online
« Reply #87 on: June 12, 2011, 11:30 AM » |
Some of you younger folks might not remember, but there was a time when we could take days thinking about what we wanted say in a letter, and then put more time and thought into actually writing it. Correspondence was a lot slower back then, as well as less frequent. But as I recall, it was usually a lot more meaningful and interesting to read.  Too true... what is the hurry?
jmbfestool
Offline
« Reply #88 on: January 01, 2012, 03:05 PM » |
Woodguy,
About the Imac! YES YES YES AND.................... YES! I would buy it again! It craps all over a PC! I dont think ill ever go back to a PC their are 3 laptops next to me and another 2 some where else and a Macbook and a PC which is not setup any more and the only computers I use are the Imac Macbook Pro and Ipad! Reason! They run soooooo smoother they all start up and shut down SO fast they run extremely fast not had any crashes or faults or any signs of them slowing down no error messages or anything like that!
All 5 laptops and 1 PC all have had errors crashes faults all at some point and lets put prices for more comparison
Every Laptop here when bought where no less than £1200 the PC I built cost me £2000 in parts at the time.
So total of £8000 on laptops PC
Macbook Pro is £ 2000
Imac £2200 (with student discount)
Total £4200 so half the price but 10x better than than pc laptops mentioned above.
woodguy7
Offline
« Reply #89 on: January 01, 2012, 03:16 PM » |
Just had a look on the Apple web site & the top I Mac 27 is £1649 ? Did you spec yours up to be over £2200 ? I presume the 27 is the way to go
If its made of wood, i can make it smaller. Shirt size medium p.s- ive started reading these too
jmbfestool
Offline
« Reply #90 on: January 01, 2012, 03:18 PM » |
Just had a look on the Apple web site & the top I Mac 27 is £1649 ? Did you spec yours up to be over £2200 ? I presume the 27 is the way to go  I spec mine up to £2600 I think you get like £400 of student discount Yeah 27 is the way to go dude! The reason mine was alot more aswell is I added Solid State harddrive! Which I would highly recommend you add to be honest I wouldnt by an Imac without a solid state harddrive it would be a waste of power running a system on a normal harddrive. JMB
« Last Edit: January 01, 2012, 03:22 PM by jmbfestool »
jmbfestool
Offline
« Reply #91 on: January 01, 2012, 03:31 PM » |
Just lookin at the current iMac 27'' inch spec which is slightly different to mine cus I got mine a while ago they are always updating stuff!
The only thing I would upgrade would be
1TB Serial ATA Drive + 256GB Solid State Drive
AND
Magic Trackpad! forget the Magic mouse the Magic trackpad rules!
I got the Apple Magic Mouse + Magic Trackpad cus didnt know what the trackpad was going to be like but my magic mouse it still brand new only once it once I took it out of its case turned it on tried it and thats it never used it since just sitting their gathering dust.
woodie
Offline
« Reply #92 on: January 01, 2012, 07:03 PM » |
joraft - what happened to taking the time to write more meaningful responses. Oh, and repeatedly posting a  after your comments doesn't make them appear any less condescending. Happy New Year by the way!
Kev
Online
« Reply #93 on: January 02, 2012, 10:57 PM » |
I use both - why make a choice of A or B when there's option C.
fdengel
Online
« Reply #94 on: January 03, 2012, 10:05 AM » |
I don't use either one any more. Wacom tablet.
Kev
Online
« Reply #95 on: January 03, 2012, 10:08 AM » |
And "D" (none of the above)
Design work?
« Last Edit: January 03, 2012, 05:04 PM by Kev »
jmbfestool
Offline
« Reply #96 on: January 03, 2012, 04:42 PM » |
I have all of them including Wacom The only one I use out of them 3 is the Magic trackpad the rest lay dormant.
