Author Topic: 6 Festools in a MAXI systainer  (Read 7657 times)
Offline festoolviking
« on: May 27, 2013, 12:11 PM »
Hi
I got tired of dragging lots of systainers to small and quick jobs. After I got the beltsander BS75 that comes in a maxi my systainer just been sitting on a shelf. Since I've got the sander mounted on the bench-unit in my shop all the time I came up with this use for my Maxi. It's actually waiting for the sixth tool which is a RTS400 but the spot is there for it. The tools inside is:
RO90
PS300
ETS125
OF1010 with accessories
OFK700
"RTS400 to come"
https://www.dropbox.com/s/if1dnobxe289h1a/Photo%202013-05-27%2017%2055%2022.jpg
https://www.dropbox.com/s/uiqjy76brxlavom/Photo%202013-05-27%2017%2055%2033.jpg
Festoolviking
Festoolviking
Offline Peter Halle
Re: 6 Festools in a MAXI systainer
« Reply #1 on: May 27, 2013, 12:31 PM »
What size Maxi is that?  I have been toying with the same idea as I am trying to work more out of a smaller vehicle.
Offline SRSemenza
« Reply #2 on: May 27, 2013, 12:36 PM »
Nice idea  [thumbs up]
Though not as large I bet the new Midi Systainers will take three or four tools and maintain the regular stacking.
« Reply #3 on: May 27, 2013, 12:58 PM »
Hi Peter and Seth
It's the larger of the two maxis (not Maxi 2). Worth to note is that the router is fully plunged without a bit in it. The jigsaw doesn't have a blade in it when stored in the systainer. In the lid I have fixed a CD box with double sided tape to store paper for the sanders in. The right side is a piece of laminated masonite with a piece of 35x35mm with 8,5 mm holes drilled for the bits. I still have to work on how to fix the accessories to keep them from moving around when I carry the systainer, since the handle is on the front.
Festoolviking
« Last Edit: May 27, 2013, 04:55 PM by festoolviking »
Festoolviking
Offline builderbob
    • RJP Remodeling
« Reply #4 on: May 27, 2013, 09:19 PM »
I have been thinking of doing this for some time with all of my sanders when I need to take them in the field. Given the release of the midi systainer, I may go that route so it works better into the system!
Great job on yours!!!
Kapex, TS55, CMS GE, Carvex 420, Domino DF500, MFK 700, OF 2200, OF 1400, OF 1010, EHL65, RAS 115, RTS 400, RO150, ETS 150/3, ETS 125, CT 22 (2), CXS (2), C-15+3, T-12+3, PSB 300 & more MFT's than i can count!
Offline skids
« Reply #5 on: May 27, 2013, 09:21 PM »
Kids' a genius I tell ya....
The funniest thing about this particular signature is that by the time you realise it doesn't say anything it's to late to stop reading it
Offline Peter Halle
« Reply #6 on: May 27, 2013, 09:49 PM »
The suitcase handle approach and turning it on its side when carrying has always been an added thing to think about for me.  You have handled that so darn well!
Offline Frank Pellow
  • Toronto, Ontario and Lake Pivabiska, Ontario
« Reply #7 on: May 27, 2013, 10:06 PM »
I like it!  [thumbs up]
Cheers,
               Frank (Festool connoisseur)
« Reply #8 on: May 28, 2013, 01:34 PM »
Thanks for your replies.
Thanks to the position of the handle it's easier to carry the weight then if the handle would be in the lid like ordinary systainers.
For you who are considering the MIDI for a similar approach it might be worth finding out if the extra handle that is available for the T-loc 497856 will fit the MIDI.
My plan if I need to bring more systainer on site is to put the Maxi in the bottom of a stack placed on a (non Festool) trolley/cart. Since it's the heaviest systainer I'm less likely to move it around to much even if it's still possible. I still have to place it on a scale to check the weight, I'll get back on that.
As for the accessories I'm considering Velcro straps stapled to the dividers to keep the bits in place when the systainer is tilted on it side. One of my biggest concerns is to keep the weight down but feel free to come up with ideas.
One day I'm also going to upgrade from the pink kaizen-foam to a more neutral color, but hey it was for free.
Festoolviking
Festoolviking
Offline Brice Burrell
  • Remodeling Contractor
    • The Green and Dark Blue blog
« Reply #9 on: May 28, 2013, 07:13 PM »
Interesting idea Bob.  I'll have to think about that one.
« Reply #10 on: May 28, 2013, 07:16 PM »
.....For you who are considering the MIDI for a similar approach it might be worth finding out if the extra handle that is available for the T-loc 497856 will fit the MIDI......
The T-Loc side handle is only for the size one Systainer.  I don't think the attachment points could take much weight and on the bigger Systainers the handle would be off center.
« Reply #11 on: May 29, 2013, 10:07 AM »
Hi Brice
I had a browse on Tanos website and found this in their 2013 catalogue (pdf) page 8:
http://www.tanos.de/admintool4/upload/csdownload3.aspx?id=552&org=000&key=73f5c68ad4ed0caeec9c5356bacfbe9b21eb3c572a95bdc6be1fae116a0ea24d&dlan=En
"Additional front handle |
The systainer® T-Loc I + II and MIDI-systainer®
T-Loc II can also be carried upright by sliding
an additional handle into the two front slots."
It seems like the extra handle works fine for the MIDI aswell.  [smile]
Festoolviking
Festoolviking
