jonny round boy
Offline
« on: August 11, 2007, 03:20 PM » |
I saw an air compressor based on a systainer on ebay.de (the German site) a few weeks ago. I've just tried searching for it again but the listing has presumably been deleted. I think it was a homemade one rather than a commercial product, but I couldn't check as I don't speak German. Since then I've been toying with the idea of cannibalising my small 6 litre compressor & trying to fit it into a sys 4 (or possibly a 5). Has anyone out there tried something similar?
I was thinking of mounting the tank in the bottom, with a small cut-out in the side to access the drainage valve, with the compressor itself above that, and (hopefully) an area at the top in which to store a coiled air hose. The main issue I can see (apart from fitting it all in!) would be dissipating the heat from the compressor.
Any thoughts/ comments/criticisms welcome!!!
TS55R EBQ saw - CTL26 - CTL Mini - OF1400EBQ router - KS120 Kapex SCMS - ETS150/3 sander - RO90 sander - DF500 Domino - T12 drill - PS420 jigsaw - OFK500 trimmer
Greg in Memphis
Offline
« Reply #1 on: August 11, 2007, 04:35 PM » |
Just a thought Jonny How about a soffit vent grill to dissipate heat next to your compressor? You could cut a good sized hole in the plastic systainer and screw that grill right were it needs to be. It should look pretty good if you make it straight and even first. I'm sure the fins on a metal grill would dissipate heat (and ventilate) better than some plastic with holes in it.
hope this may help
Greg
« Last Edit: August 11, 2007, 04:36 PM by Greg in Memphis »
SRSemenza
Global Moderator
Online
« Reply #2 on: August 11, 2007, 04:45 PM » |
You could even rig a small fan to move air through. The type are used in elctronics cabinets, etc. I have a compressor that almost fits in a Sys - IV with out modifying I was really hoping I could just drop it in ( the tank is about an inch too long). Oh well. It could go in a Maxi Systainer if the maxi was taller.
Festool Service 800-554-8741
Brice Burrell
Offline
Remodeling Contractor
« Reply #3 on: August 11, 2007, 04:52 PM » |
I found this video on youtube, this guy put a compressor in a systainer, pretty cool.
« Last Edit: August 11, 2007, 06:26 PM by Brice Burrell »
SRSemenza
Global Moderator
Online
« Reply #4 on: August 11, 2007, 05:35 PM » |
Hey, Brice! Thats the same compressor I wanted to just drop in. O.K. so you removed the frame? that way the tank fits? and added a leader hose to your opening. Does that power cord just get stuffed back in or is there a self winder hidden in there? Any other mods? supports underneath? How about ventillation? Looks like you have it in a Sys -V, but I think it would go in a - IV. P.S. Nice Private Ryan style camera work  Seth
Brice Burrell
Offline
« Reply #5 on: August 11, 2007, 06:24 PM » |
Seth, I forgot to add the description to the video in my first post, I found this video on youtube, I didn't make it. Sorry for any confusion.
jonny round boy
Offline
« Reply #6 on: August 11, 2007, 06:43 PM » |
Brice, Thanks for that! It's obviously possible to do, and relatively easy. He didn't seem to have issues with heat, there wasn't even a vent cut in the systainer! Looks like I have a project to work on over the coming weeks.... Edit: I found some manufacturer's data for the one I saw on eBay.
« Last Edit: August 11, 2007, 06:51 PM by jonny round boy »
Eli
Offline
A Yankee in Kangaroo Court
« Reply #7 on: August 11, 2007, 06:49 PM » |
We've been talking about it this week. Here's the one you saw maybe. The big question for us was: would the smallest most robust compressor that would fit in a systainer be able to keep up with a nail gun if you added another systainer with a reservoir? http://www.prebena.com/Products/index.php?Language=EN&PrebenaID=KOMP_30
Do nothing, stay ahead.
jonny round boy
Offline
« Reply #8 on: August 11, 2007, 06:52 PM » |
You beat me to it!!! The picture at the bottom of the PDF page in my previous post does show an additional reservoir systainer, exactly as you describe...
« Last Edit: August 11, 2007, 06:59 PM by jonny round boy »
Brice Burrell
Offline
« Reply #9 on: August 11, 2007, 07:20 PM » |
I have a Senco mini compressor like the one in the video. I can tell you it takes a long time to fill it's small tank, and you don't get many 16 ga. finish nails before the compressor fires again. With a separate reservoir the motor would run even longer to fill both tanks. That could shorten it's life considerable. I bet it will stand up to lite use with no problem. Forget about hard everyday use with that kind of setup.
woodshopdemos
Inactive Member
Offline
« Reply #10 on: August 11, 2007, 10:25 PM » |
First thought: the camera person must have finished off the nitrous oxide. (how cattie of me)
I don't have shop air. I have two compressors...all are too noisy. I think I will concentrate my efforts of getting one outside or as far away from me in the shop as possible.
In memory of John Lucas (1937 - 2010)
Eli
Offline
« Reply #11 on: August 11, 2007, 10:45 PM » |
I had to watch the video in two sittings. I got seasick even though I'm a sailor. My obvious choice for a shop compressor would be a two stage that was in a soundproof shed outside. But it needs to go with me. So for me, this discussion is definitely about the best way to stick one in a systainer. I was considering not even getting a compressor . I found a guy that makes a high pressure tank setup that fits in a backpack, refills from a scuba tank, and gets 1500 shots a refill. I'm trying to find the link.
SRSemenza
Global Moderator
Online
« Reply #12 on: August 11, 2007, 11:32 PM » |
I just did some more measuring on my Senco compressor. It will go into a Systainer - IV . The handle needs to be cut off at the bottom of the vertical portion. Or removed and the tank motor remounted on something like a piece of plywood. Either one is pretty easy and then it will fit right in. I will probably keep it simple and just coil the hose and cord right on top. This should work well if I put my guns in Systainer - I s and II s . I could then just attach what ever gun i need to the compressor and go. BTW this will not be for heavy use. Just light install work.
jonny round boy
Offline
« Reply #13 on: August 12, 2007, 12:09 PM » |
OK, well based on the positive responses here, I've decided to take it a stage further. I would say I've decided to actually make it, but this has the makings of one of those projects I never quite get round to carrying through to the end! Anyway, here's the donor machine, along with size 4 and 5 systainers:  As you can see, fitting it into a 4 would be much more of a sqeeze than a size 5... In the pictures below, it's clear that the width of both the compressor & tank is considerably less than the width of the systainer:   Which gives me lots of scope for adding one of these self-retracting hose reels behind the tank:  Thanks to Brice for posting the vid that gave me the idea for this! With a retractable hose in there, and a mains connector in the side too, there would be no real need to open the systainer except for maintenance. This means that a Sys 1 or 2 could live permanently on top to hold the air tools.
Matthew Schenker
Offline
« Reply #14 on: August 12, 2007, 12:30 PM » |
I don't have shop air. I have two compressors...all are too noisy. I think I will concentrate my efforts of getting one outside or as far away from me in the shop as possible. I agree! One of the charms of YouTube is the rough edges of the videos. However, I was feeling dizzy watching this. Also, um, how about the soundtrack? Still, I'm happy to see the concept, and glad someone took the time to share it. Matthew
Corwin
Online
« Reply #15 on: August 12, 2007, 05:00 PM » |
Matthew
Yep, cannot complain about the quality of a presentation when the concept carries the day!
Shirt Size: L
SRSemenza
Global Moderator
Online
« Reply #16 on: August 13, 2007, 12:45 AM » |
[ ERROR: SPECIFIED ATTACHMENT MISSING ]
[ ERROR: SPECIFIED ATTACHMENT MISSING ] [ ERROR: SPECIFIED ATTACHMENT MISSING ]
Hi, It looks like the compressor might be a little too tall for the Sys five even without the handle. There is an extender made for systainers. It ads about four inches to the top of any size. It looks like a sytainer - one with no top and is bottomless. but the latches are in place to connect right on. Festool doesn't have it but I know it is available from www.kofferfunshop.de And other places in Europe. You could use it to make the Sys five taller. Seth
Eli
Offline
« Reply #17 on: August 13, 2007, 03:22 AM » |
I still can't find the email from the guy who makes them *darn*. But basically the alternative I'm talking about is a two tank high pressure setup with custom regulator. The Jacpac does something similar, the difference being the jacpac is a CO2 system, which may or may not be good for the seals of the gun, and may or may not be environmentally friendly. The two tank one is refilled off a scuba tank, which is in turn filled at a dive shop or with a high pressure compressor. Supposedly in the range of 1500 shots for a brad gun. Lightweight, making only the noise of the gun embedding the nail, refillable. Expensive of course, but that doesn't deter us in our quest for tools, does it? I'll keep trying to find it.
SRSemenza
Global Moderator
Online
« Reply #19 on: August 13, 2007, 10:09 AM » |
Hi, I was just looking at this. Anyone interested in using CO2 for pneumatic guns on a regular basis should consider getting there own refill set up. I used to play paintball and had a set up to refill the small tanks for my team because of the cost savings. The transfer valves were under $50 at the time. You can get big 80# cylinders from a weld shop. I don't remeber the exact cost but it was much less than paying for refills. And much more convenient than having to go somewere to buy CO2 fills. Refilling them is quite easy if you do it properly and watch a couple safety issues. Getting the regulator of course would be the expensive part. This is an intruiging idea compared to a copressor for small jobs. Seth
SRSemenza
Global Moderator
Online
« Reply #20 on: August 13, 2007, 10:13 AM » |
Another air source when you don't need a lot of shots is a portable air tank. I have a five gallon that gives me 75 good shots with an 18ga brad gun. On the other end I can get about ten with the framing nailer. It won't fit in a systainer, but it is pretty handy to carry from place to place with a coil hose on it.
Eli
Offline
« Reply #21 on: August 13, 2007, 05:41 PM » |
I've also been considering a Coke style CO2 tank. My friend has a bar, so it would be an easy swap out. HPA is a more desirable option for me than CO2 though. A carbon fiber 4500 psi tank is going to give you far more shots than any other option except a compressor. CO2 is a liquid in tanked form, shooting a series of shots can chill the internals of a paintball gun and freeze it up, I don't want to know what it'll do to the seals on a pneumatic nailer. The pressure varies depending on how full the CO2 tank is, because it needs to expand from liquid to gas. Palmer Stabilizer seems to be the best regulator option I've found, they're in the $100 range http://www.palmer-pursuit.com/online-catalog/stabilizer.htmand a tank like one of these: http://search.ebay.com/search/search.dll?from=R40&_trksid=m37&satitle=HPA+tank&category0=
SRSemenza
Global Moderator
Online
« Reply #22 on: August 14, 2007, 12:10 AM » |
I've also been considering a Coke style CO2 tank. My friend has a bar, so it would be an easy swap out. HPA is a more desirable option for me than CO2 though. A carbon fiber 4500 psi tank is going to give you far more shots than any other option except a compressor. CO2 is a liquid in tanked form, shooting a series of shots can chill the internals of a paintball gun and freeze it up, I don't want to know what it'll do to the seals on a pneumatic nailer. The pressure varies depending on how full the CO2 tank is, because it needs to expand from liquid to gas. Palmer Stabilizer seems to be the best regulator option I've found, they're in the $100 range http://www.palmer-pursuit.com/online-catalog/stabilizer.htmand a tank like one of these: http://search.ebay.com/search/search.dll?from=R40&_trksid=m37&satitle=HPA+tank&category0=Hi, Yes, I don't know if the CO2 is necessarily a good idea. I just wanted to let people considering it know about a filling option. In the long run a compressor is probably the best all around option. I have used my regular portable air tank on quite a few occasions. Seth
Eli
Offline
« Reply #23 on: September 01, 2007, 07:22 AM » |
So, FWIW, I made the jump today and bought the OZITO CO2 system, just released in Australia. Ozito is like a Black and Decker brand, not really super quality, but there's no other company offering CO2 at this time, so limited choice. The NA equivalent would be the Jacpac. The package comes with hose, regulator, fittings (they use Nitto fittings here, had to swap all the guns over, thread same), and a little backpack about the size of a camelback, a bit smaller. It was $150 and two spare tanks were $15 each, swappable at Bunnings, the HD equivalent. Guns both 16 and 18 gauge, the tank and pack, the hose, a plastic divider box with spare fittings, tire inflator, etc., four ratchet straps, and all my spare plug-it cables fit into one SYS IV. I'll let you know how it goes. If I can deal with not having a compressor, I'm going to go ahead and upgrade to an HPA system, for even more compressorless shots.
Trevor H
Offline
web man for www.festooljunkie.com
« Reply #24 on: September 01, 2007, 03:55 PM » |
Here's a pic of the Jac Pac. with this 10 ounce co2 container they claim you can shoot 250 brads. If you disconnect a lot then i would say you get about 175 brads. I refill the cans at any sporting good store or paintball store for $2 dollars. The kit in the picture is the regulator, hose and cannister and it runs around $93. It easily fits in a systainer and you can use bigger cannisters if you have a bigger job. After i am done installing a floor I use this jac pac to tack up base shoe if it's a small job. Or you can use it for patch type jobs. They also make a kit that comes with a gun that is made to run off the Co2. The gun is an 18 gauge brad and staple combo. You don't have to buy the gun however, just use your normal gun. I have found no problems using c02 or air running through a pneumatic nailer, as long as you keep it oiled I don't see how the co2 would mess up your gun? If you buy the regulator, hose, cannister and gun it's around 150. Sometimes I use a 20 oz cannister and that only costs me $3 0r $4 to fill. Now you have 300 to 500 shots easily. The jac pac regulator fits easily onto your belt and is so light. and the components do fit in a small systainer because i just tried it!  I do however recommend a 10 oz container if you are actually going to hook it to your belt. If your skinny like me the 20 oz can when full has the tendency to give me a bit of plumbers crack! Just a tad heavier! My question is also this...... If you have a full blown compressor in a systainer, you still have to lift it out all the time to release the air pressure if you use it on a daily basis so that the water build up doesn't rust out the tanks. Plus, loud, loud, loud is all i think of when you put a compressor in a systainer. If you are looking for ease of use wouldn't this be a pain? And yes the video, although cool, made me feel like i was stuck in a horrible 80's video with that soundtrack! But i guess it gives you something to believe in eh! Cheers
« Last Edit: September 01, 2007, 04:27 PM by Trevor H »
Eli
Offline
« Reply #25 on: September 01, 2007, 05:59 PM » |
I think I must have 20 ouncers then. My concern with the gun was that if you fired enough shots fast enough you could get the seals cold enough to stick. But that would have to be a lot of shots I guess. I'm stoked, it's going to be hard not to waste that first canister just messing around with the gun. Maybe I'll hook the framer up to it.
greg mann
Offline
« Reply #26 on: September 02, 2007, 01:02 PM » |
Eli, Regular compressed air also gets cold when it expands at point of use. This happens at expansion and mostly upon exit from the tool. Heat is the usual enemy to most tools. As long as you oil at proper intervals I don't see the CO2 being any worse on a tool. My $.02.
« Last Edit: September 02, 2007, 01:06 PM by greg mann »
Greg Mann Oakland, Michigan
SRSemenza
Global Moderator
Online
« Reply #27 on: September 02, 2007, 09:33 PM » |
Does anyone know if the Jac Pac or similar system is avialable as the regulator only? Prices? I don't really need a case. I have hoses. And I also have two 7 oz. and three 3.5 oz. CO2 bottle sfrom my days as an avid paintball player. I think the 3.5 oz would be truly compact and portable!
Trevor H
Offline
« Reply #28 on: September 03, 2007, 01:59 AM » |
Right now i know the jac pac is selling a regulator kit, but don't know about buying just the regulator. The kit comes with everything you see in my previous post pic and is about 53 bucks. You then get a hose, one ten ounce cannister, regulator and it comes in the kit. Hope this helps a little bit. have a good one my friend.
Eli
Offline
« Reply #29 on: September 03, 2007, 06:51 AM » |
Hey Seth, you can get a regulator only, or a regulator 'remote' kit (which is basically a tight curl hose and regulator) from Palmer Pursuit. The one below they recommended to me for an HPA tank, but I'm not sure if CO2 connection is different. They replied quickly to my inquiry though, so ask them. http://www.palmer-pursuit.com/cart/index.php?main_page=product_info&products_id=245When you say you have hose already, I'm sure you mean a short paintballer's hose. A regular air hose would use up the whole canister just to fill it and fire the gun a few times. I had another thought on the way to work. I bought huge cans of paint for the job I'm doing now. A hand blower with the regulator set on low pressure should be able to fill the open can of paint with CO2 before I close it. No oxygen would make the paint last longer, no? http://www.bloxygen.com/data.html
