Author Topic: CMS-TS 75 Maxi-Systainer storage solution  (Read 2854 times)
Offline dwillis
« on: May 29, 2018, 02:09 PM »
Several years ago a friend from the UK brought a CMS-TS 75 (NAINA) to the US so that I may use my TS 75 as a portable table saw in my CMS-GE table. Normally my CMS-GE is configured as a router table, so I needed a place to store the CMS-TS 75 when not in use. Fortunately the retaining panel (the table saw top) just fits into the Maxi-Systainer with a minor modification. There are reinforcing ribs on the sides of the Maxi-Systainer with small tabs on top of the ribs which hold the retaining panel too high. Simply grasp the tab with pliers and snap them off, leaving a support for the retaining panel to rest on at the correct height to allow the lid to close (see photos for before and after tab modification).
For the remainder of the CMS-TS 75 components I cut a piece of 30 mm thick Kaizen foam from FastCap (https://www.fastcap.com/product/kaizen-foam) to fit into the bottom of the Maxi-Systainer. Each component was used as a template to trace around and the foam was cut out, leaving a thin layer on the bottom of the foam to protect the Maxi-Systainer bottom. Foam panels were also added to the inside of the Maxi-Systainer lid to protect the retaining panel.
My next project will be to build a similar storage solution for the CMS-GE router retaining panel and components for storage in a different Maxi-Systainer.
« Last Edit: May 29, 2018, 06:54 PM by dwillis »
Remember that the only scientist to walk on the moon was a geologist.  Dr. Harrison Schmitt - Apollo 17 - Valley of Taurus-Littrow - 11 to 17 December 1972.
Online TinyShop
Re: CMS-TS 75 Maxi-Systainer storage solution
« Reply #1 on: May 29, 2018, 06:50 PM »
Wait for it... Wait for it....
ETS 150/5 EQ (DE) [PO], TS 75 EQ (DE) [PO], OF 1400 EQ-F (DE) [N], CXS (DE) [N], CMS-GE [DE], CMS TS 75 (DE) [N], LA-CS 50/CMS (DE) [PO], VB-CMS (DE) [N], MFT/3 (CZ) [N], DF 700 EQ w/Seneca Small Mortise Kit (DE) [PO], FEIN Multimaster 350 QSL (DE) [N], Bosch 1274DVS w/dust collection, sanding frame,  stand & fence (CH) [N], BOSCH 1590EVS w/dust collection (CH) [N], CS Unitec CS 1445 HEPA extractor <re-branded Starmix ISP 1435 H> (DE) [N], CT SYS (DE) [PO], Milwaukee 0302-20 (US) [N], Two (2) Porter Cable 862 (TW) [N], Porter Cable 447 (US) [N], Zyliss Vise (CH) [N], Hitachi C 8FB (JP) [H]
[PO] Pre-owned   [N] New   [H] Heirloom   (XX) country of origin
Offline jobsworth
  • Festool Baby.....
« Reply #2 on: May 29, 2018, 09:56 PM »
Great idea. If i have to pack mine up and move it thats perfect.
Offline abates
« Reply #3 on: September 07, 2018, 09:57 PM »
I really this.  I also change between the router table and ts75 module and find trying to store all the bits and pieces is a bit of a cluster *%$.  If I could find a maxi systainer, I would probably try this.  Cheers for being creative.
Offline Naildrivingman
« Reply #4 on: September 09, 2018, 07:59 AM »
I used a maxi SYS to store the miter gauges and misc small parts for my Erika table saw.  I custom made some kaison foam inserts. It works well and was fun to do on a cold evening last winter up here in the frozen north.
Dance with who brung ya...
