woodguy7
Offline
« on: November 16, 2009, 03:15 PM » |
I tried doing a search but to no avail. A few months ago someone put a picture on a thread of a compressor, hose & a couple of nail gun's inside a systainer. I really like this idea & would like to know the size & make of the compressor. I did come across the "PREBENA AEROTAINER 200 compressor in a Systainer" which looks really cool also. Anyone used the Prebena system & what do you think of them.
Thanks in advance, Woodguy.
If its made of wood, i can make it smaller. Shirt size medium p.s- ive started reading these too
Steve-CO
Offline
« Reply #1 on: November 16, 2009, 03:51 PM » |
Not sure, if this is the thread you're thinking of or not. It's a couple years old but might help.
« Last Edit: November 16, 2009, 03:52 PM by Steve-CO »
woodguy7
Offline
« Reply #2 on: November 16, 2009, 04:10 PM » |
Hi Steve, no this is not the one but there is some good points in there, thanks for finding. The thread i am thinking about wasn't necessarily about a compressor in a systainer but i think it wandered a bit, which happens & someone posted a pic with all the gear in it.
Cheers, Woodguy.
Brice Burrell
Offline
Remodeling Contractor
« Reply #3 on: November 16, 2009, 04:19 PM » |
jvsteenb
Offline
« Reply #4 on: November 16, 2009, 04:24 PM » |
I looked into it a while ago, for I wanted a nice and neat portable compressor for on-site use - lugging around a 3 Hp 100 litre belt driven beast gets old VERY fast. But the Prebena is rather steeply priced, and if you want it to be any useful you'll have to buy the additional systainer with the ( small! ) buffer tank - the extra tank is 10 litres, there's a 3 litre tank in the Aerotainer. That's two big systainers ( sys IV or sys V, I don't know for sure ) for a huge amount of money, and it's not very powerful ( 1,5 Hp, and not particularly efficient ) . I've used Prebena tackers, and wasn't impressed - not very bad, but certainly not up to festool standard ( the good news is they aren't very expensive either ). The systainers are a nice gimmick, and if you absolutely need all your gear to be systainer-compatible, I guess it's a nice option. I ended up with a nice compact dual tank ( 22 litres total ) 2,5 Hp compressor with two thick rubber wheels and a foldable handle AND a nice 100' hose on reel for just about half of what the Prebena set would have cost me, and have been very pleased with it since. I will swap the PVC airhose for a rubber one in the foreseeable future, but that's just because I'm a spoiled brat  Regards, Job
TS55, OF1010, RO150, RTS400, PS300, T15+3, CTL22E, CMS-TS55+Basis5A (OF1010), MFT/3, MFS400/700, FS800-1080-1400-1900, Centrotec-SYS 09, DF 500 full set, some accessories
woodguy7
Offline
« Reply #5 on: November 16, 2009, 04:30 PM » |
I can see that this is not a new idea. I do have a Bostitch compressor but for occasional use i would like one in a systainer. Loads of good ideas out there.
Cheers, woodguy.
Neill
Offline
« Reply #6 on: November 16, 2009, 04:40 PM » |
Woodguy,
Check for JacPac CO2 cartridges. Comes in a plastic container. Not a compressor but serves somewhat the same purpose. Nickao had a thread on this that looks pretty good. Might be this is what you were thinking about.
Neill
Kapex, Domino, MFT/3, Rotex 150 FEQ, CT 22E, TS 55, C12 Drill, 1400 Router, Rotex 90 DX, Rotex 125 FEQ, LS 130 EQ Linear, Parallel Guide Set, Deltex 93 E, Trion 300 Barrell Grip, ETS 150/3 EQ, ES125 EQ, Guide Rail Accessory Kit, Sanding Block, various rails, systainers, sortainers, vacuum hoses and accessories for various tools.
woodguy7
Offline
« Reply #7 on: November 16, 2009, 04:45 PM » |
Na, that ain't it either. I understand these canister type nail gun's are quite common in the states, but i have not seen them on this side of the pond. I will look into it though, i like the idea.
Woodguy
Peter Halle
Global Moderator
Online
« Reply #8 on: November 16, 2009, 05:13 PM » |
I will swap the PVC airhose for a rubber one in the foreseeable future, but that's just because I'm a spoiled brat  Regards, Job I will assume that you have access to polyurethane air hoses. If you haven't looked into them, you might want to before you buy rubber hose. Peter
jeffinsgf
Retailer
Offline
« Reply #9 on: November 16, 2009, 05:15 PM » |
If I were working interior trim by myself (no framing nails to shoot) and looking for something "Systainer-able", I'd give this compressor a close look: http://www.senco.com/con_rem/ViewTool.aspx?toolid=175I had one that came bundled with a stapler. My brother-in-law needed a small compressor, and since I had a couple good (but larger) pancakes, I gave him the Senco. I've kicked myself a dozen times for giving him that one instead of one of the larger ones. That little Senco was one of the quietest compressors I've ever seen, and shooting staples as fast as I could go, it kicked on infrequently and recovered quickly.
Brice Burrell
Offline
« Reply #10 on: November 16, 2009, 05:16 PM » |
I agree, it's just as flexible but more resilient.
Dan Rush
Offline
Trim carpenter
« Reply #11 on: November 16, 2009, 05:18 PM » |
Are you thinking of this? It's a 1 hp Senco. I just cut off the handle. I holds a 15 ga., 18 ga., and 23 ga pinner. 50ft of hose, the compressor, and I took the attic lid from my t 15 sys 2 and put it on this sys 5 for nails. Completely self contained. I think the thread started out about the attic lid on the drill sys 2's.
Dan
« Last Edit: November 16, 2009, 05:25 PM by Dan Rush »
Brice Burrell
Offline
« Reply #12 on: November 16, 2009, 05:25 PM » |
Jeff, I have one of those compressors, love it. One of my better purchases and my back thanks me. Recovery time is just a bit on the slow side for trim work but its size and weight more than make up for that. I believe I saw a post where someone was able to put one of these in a Systainer.
EDIT: I knew I saw someone that had one of these, thanks for posting Dan.
« Last Edit: November 16, 2009, 05:26 PM by Brice Burrell »
woodguy7
Offline
« Reply #13 on: November 16, 2009, 08:04 PM » |
Dan, Thanks for that. That is the one i seen. I new someone would come forward. What size of a tank is on the compressor & is it a no 4 or 5 systainer ? Again, nicely done  Thanks, Woodguy. Edit - just noticed its an sys 5
« Last Edit: November 16, 2009, 08:05 PM by woodguy7 »
Dan Rush
Offline
Trim carpenter
« Reply #14 on: November 16, 2009, 08:29 PM » |
Woodguy, It's a 1 gal tank. It really is a great little compressor, especially for the price ( about 140.00 USD) I have been using them for years. As Brice said, it's really quiet. Recovery time is slow, but for me it's ok. I shoot mainly 23 ga. pins, 18 ga brads, and a very few 15 ga brads, pretty much all in crown and decorative trims. No production work here.
I don't know how they would hold up under heavy use ( meaning lots of recycles per work day, like on production trim jobs.) I only shoot maybe 3-400 brads per day.
I'd recommend it for the right use,
Dan
WarnerConstCo.
Offline
« Reply #15 on: November 16, 2009, 09:52 PM » |
Dan
400 brads in one kitchen??  Must be bigger than my house!!
bonesbr549
Offline
I'd rather be woodworking
« Reply #16 on: November 16, 2009, 09:59 PM » |
Is this what you are looking for.
Hate the music, but love the setup.
Dan Rush
Offline
Trim carpenter
« Reply #17 on: November 16, 2009, 10:12 PM » |
400 brads in one kitchen??  Must be bigger than my house!! Certainly bigger than mine!!! Actually, most of my crown build ups are 3-5pcs. Add backers, etc, and you get a lot of shots. But, compared to the big boys running miles of base and casings, a few hundred shots a day is nothing.
« Last Edit: November 16, 2009, 10:14 PM by Dan Rush »
Meezo
Offline
« Reply #18 on: November 16, 2009, 10:13 PM » |
I found the following on youtube couple month ago I wonder how he did the plate for connecting the compressor hose
Meezo
Tom Bellemare
Festool Dealer
Online
« Reply #19 on: November 16, 2009, 10:14 PM » |
400 brads in one kitchen?? Just how big is Bradley? Tom
« Last Edit: November 16, 2009, 10:15 PM by Tom Bellemare »
