Author Topic: Custom Systainer Labels  (Read 100342 times)
Offline mike68au
« on: August 12, 2013, 11:14 AM »
Since becoming a massive Systainer Fan and completely converting my tool collection into Systainers I've been frustrated by my labelling system.
First i tried the Dymo labels... nah
Then i used the Festool style ones we can print out but hey were to limiting on what i wanted to do, yes they suited the Festool Tools but what about all my other stuff.... makita, Bosch, Knipex, Fein...etc
Well I got sick of them and started playing around trying to come up with a better design, I discovered that i could open the festool .pdf's in Adobe Illustrator.  And in doing this also discoverd that i could modify them to how i wanted them.
Now my extremely limited knowledge of Illustrator stopped me from creating a template like Festools,  but i was able to create a Template that I could keep changing a saving.
Anyways I got what i wanted and I'm happy to share here.   Feel free to use the ones i have created so far for your own use, I'll upload more as i create them.
if i have this uploaded correctly they should be a .pdf  and in the correct size if printed.
The first image is the style i have gone with. The Festool and Blue Line remain constant all the changes are above this.
91044-0
« Last Edit: August 18, 2013, 09:11 AM by mike68au »
Offline promark747
Re: Custom Systainer Labels
« Reply #1 on: August 12, 2013, 11:36 AM »
Thanks...though you might want to check the spelling on your Rotex labels.
Offline SRSemenza
« Reply #2 on: August 12, 2013, 11:46 AM »
Nice labels Mike.  [thumbs up]
Offline mike68au
« Reply #3 on: August 12, 2013, 07:25 PM »
Thanks for pointing out my mistake... i have since corrected it and now they reflect the correct spelling.
If anyone would like me to make one for them to suit a specific tool please let me know. Happy to help out.
Note to Mods:  this was the second time i had to upload the pdf's as my first thread kept coming up as a blank page, if the Mods are able to delate that thread they " My Custom Systainer Labels" they can as it's effectively the same as this one.
Mike
« Last Edit: August 12, 2013, 07:28 PM by mike68au »
Offline Kevin D.
« Reply #4 on: August 13, 2013, 03:45 AM »
Your Festool Labels are great.  Thanks for your generosity in posting.  I have saved your files for when I need to polish up my setup when I have time.  Much appreciated!
Kapex, CT-SYS, SYS-Cart, Pro 5 Sander, CT36AC, TS75, MFT 1080, MF-SYS/2, PS300 EQ-Plus, Parallel Guides Set, LR32 SYS, RO 150FEQ-Plus, OF1400 EQ Plus, DOMINO 500 Q-Plus,  Domino XL, MFK 700 EQ-Set, FS-SYS/2, CT22 w/hose storage, D36HW-RS-Plus, FS 1900/2, FS 3000/2, FS 1080/2-LR32, FS 1400/2-LR32, Gecko, Festool Floor Mat, Festool Stein, Multi-Tool, tape measure, large and small Festool floor mats (foam rubber).
Offline mike68au
« Reply #5 on: August 13, 2013, 10:29 AM »
Your  Welcome Kevin... if there is anythiing you would like made up let me know and I'll do it.
I've also re-done the Fein labels and also added a corded version.
In regards to personal details or Business details i choose to keep that off these labels, as on the left side of my systainers i insert one of my business cards, the right and sides are for the labels.
91099-0
Offline boost13
    • AV Solutions
« Reply #6 on: August 15, 2013, 11:06 AM »
Nice work buddy. Did you print them on card int the end? I put mine into glossy business card holders.
Too much festool.......
TS55 OF1010 OF1400 DF500 Domino
RO90 RO150 ETS150/3
T15 TI15 T12 CSX(x2)
Carvex PS400 Kapex120
Syslite Vac-sys ......... sure theres more i have forgotten!
MFT3 (x2) CS50
CT MIDI & CT36 (x2)
Offline amt
« Reply #7 on: August 15, 2013, 11:14 AM »
These are really neat.  Would be very cool if we could get a library of images for every tool available.
BTW, are you printing this on to "peel and stick" paper, or just regular paper and sticking to the systainer by some other method?
Offline RL
« Reply #8 on: August 15, 2013, 11:17 AM »
Thanks for this, they are very useful.
Regarding other card ideas, like probably several other people I have a systainer full of router accessories (CMS parts etc.).
« Last Edit: August 15, 2013, 11:19 AM by RL »
Offline mike68au
« Reply #9 on: August 15, 2013, 12:05 PM »
My intention is to do one for every Festool in a Systainer as i do them i up load them here.  I also will be doing up some for Parts and Accessories as need then myself also.  Clamps , MFT parts,  Surfix, etc
As for how i print them what i choose to do was print them on 250gsm Photographic paper, this way i could get 4x6 pieces of paper and also achieve a good print quality.  (100 pieces was around $20) not a cheap way to go but i like the results.
After i printed 3 of each, i would laminate them all together, and then trim them to suit with a paper trimer so as to get a clean straight cut. After this i would put a piece of  very thin double sided tape on the back of them... and then just put them into the slots in  the systainer.
They have given me a very organised and clean result this way. They won't fall out and i realtivley protected from damage, plus i can remove them if needed.
Offline P2P
« Reply #10 on: August 18, 2013, 09:52 PM »
Really nice labels Mike!
Would you add a label for the Compact Cleaning Kit and one for the SysLite to your list?
I'm going to be purchasing a second SysLite and plan to put them both in their own Systainer with the charging cables.
Thanks!
Offline Locky
  • Festool Dealer
« Reply #11 on: August 19, 2013, 04:10 AM »
Great work Mike, i can see alot of people using them from the forum, including me  [big grin]
Offline mike68au
« Reply #12 on: August 19, 2013, 11:25 AM »
Thanks for the Comments guys.
@ P2P i have made the up the labels you have requested.
I have also added a few new ones to my original post.
« Last Edit: August 19, 2013, 11:56 AM by mike68au »
Offline boost13
    • AV Solutions
« Reply #13 on: August 19, 2013, 11:50 AM »
Nice work mate. Very clean.
RO90 RO150 ETS150/3
MFT3 (x2) CS50
CT MIDI & CT36 (x2)
Offline P2P
« Reply #14 on: August 19, 2013, 03:32 PM »
Thanks much Mike!  I appreciate it!
Offline Cellule
« Reply #15 on: September 08, 2013, 02:38 PM »
Can you make one for the older model of track saw: festool TS55 EBQ-PLUS And the C15
Its so a great idea that you had that i bought some photo paper to make cards for all of my festool systainers  [tongue]
Offline bwiele
« Reply #16 on: September 11, 2013, 05:20 PM »
These are awesome!  Any chance you could work up a C12 and an LR32 label?  I used to have Adobe Illustrator but it was on an old computer that I don't have any more!
Offline mike68au
« Reply #17 on: September 13, 2013, 11:42 AM »
As per requests above:
I've updated the TS55EBQ to reflect the correct picture.... it was late and i was tired. ( well thats my excuse...lol )
« Last Edit: September 13, 2013, 08:04 PM by mike68au »
Offline mike68au
« Reply #18 on: September 13, 2013, 11:45 AM »
Plus a few Domino ones:
Offline neeleman
« Reply #19 on: September 13, 2013, 11:57 AM »
Picture on the TS 55 label is the wrong one, it's of the latest TS 55 REBQ.
BTW in the US there only a REQ version.
Here is my version, left and right one, just like Festools does.
They match the ones on the original T-Loc systainers also.
Festoolian since 1998.
FESTOOL:
SYSROCK BR10 | SYSLITE KAL II | SV-SYS D14 | DSC-AG125FH | CDD9.6 | SYSLITE DUO | DF700 | HKC55 | TXS2.6 | CTL SYS | CXS2.6 | DWC18 | CTWings | BHC18 | CS50 | CMS-OF | MFT/3 | MFT/3-VL | KS120 | TS55 R | PSC420 | PS420 | BS75 | RAS115 | RO90 | RO150 | DTS400 | RS400 | RTS400 | RS300 | LS130 | DX93 | ETS150/5 | ETS150/3 | OF1010 | OF1400 | OFK500 | MFK700 | T18 | EHL65 | CTL26 | CTL22 | CTL MIDI | WCR1000 | D27-AS Plug-it | D36 UNI-RS | D36x7 | D50x2.5 | FS800 | FS800/2 | FS1080/2 | FS1400/2 (2x) | FS3000/2 | FSK250 | FSK420 | Gecko Dosh | Toolie | CE-SYS-2010 | RB-SYS CART (2x) | LEV1400 | LEV350 | SYS-MFT
PROTOOL:
Offline Festoolian
« Reply #20 on: September 13, 2013, 12:05 PM »
I have two Domino accessories; a Domi-plate and an SCG (self centering guide) fitted in foam together in a T-Loc.  Would it be possible to develop a label picturing one or both of those items?
Offline bwiele
« Reply #21 on: September 13, 2013, 02:20 PM »
Mike -
You are very kind to spend your time doing this for all our benefit.  Thank you!
Brian
Offline neeleman
« Reply #22 on: September 13, 2013, 02:28 PM »
Something like this?
Or don't you want the Festool logos?
Both companies don't have their own logos or brand names.
FESTOOL:
PROTOOL:
Offline mattdh
« Reply #23 on: September 13, 2013, 03:18 PM »
neelemen makes some of best looking labels out there. coming from one happy customer!
Offline bwiele
« Reply #24 on: September 13, 2013, 03:24 PM »
Neeleman - have you posted a whole variety of custom labels somewhere also (similar to this thread)?  You both do some impressive work...
Offline neeleman
« Reply #25 on: September 13, 2013, 03:38 PM »
Here are some examples.
I do make labels for Classic, Mini, Maxi and T-Loc systainers.
Mainly Festool/Protool and of course for other brands too.
I also make the right side labels which normally contains the Wattage, rpm for the machine and the bar code besides a few extra logos and Made in xxx.
FESTOOL:
PROTOOL:
Offline Festool Fishy
« Reply #26 on: September 13, 2013, 05:50 PM »
I can highly recommend Neelemans labels I have had them from him for Mini,Maxi, Classic & Tanos systainers.
The Classics labels really stick well, the printing and colours are first class on both the plastic and card type labels
Great job keep up the good work KN
Offline Peter Halle
  • Another Avatar Coming Soon
« Reply #27 on: September 13, 2013, 07:03 PM »
 [sad]
Offline mike68au
« Reply #28 on: September 13, 2013, 08:10 PM »
They are great labels Neeleman.... especially the way you keep them along the same theme with all the different brands. Well Done!
Thnaks for adding to the thread, gives all the members an expanded choice
Personally i wanted a simpler format, I don't need all the text, just the name of the Product and a Picture ( be it much larger ) on all 3 sides -  I grab my systainers from my van by a quick glance at the label and having them all bolder and larger makes it easier.
Note: i have updated the TS55EBQ
Offline andvari
« Reply #29 on: September 15, 2013, 07:54 PM »
Hey thanks for the great labels guys.
I found the free Linux program Inkscape does a great job importing the pdfs and images here, and it has very useful tools for laying out the images on a page of labels.
Since I normally store my Systainers in edgewise to save linear shelf space the side labels are very helpful.
TS55, Domino 500, Domino Assortment, OF1400, CT36+Boom Arm, T12+3, FS3000, Parallel Guides, RO 90, ETS 150/3, Domino XL, Domiplate, LS130, RTS Guide Stop, CMS-GE, Carvex 420
