Author Topic: Custom Systainer Labels  (Read 106129 times)
Offline mike68au
« on: August 12, 2013, 11:14 AM »
Since becoming a massive Systainer Fan and completely converting my tool collection into Systainers I've been frustrated by my labelling system.
First i tried the Dymo labels... nah
Then i used the Festool style ones we can print out but hey were to limiting on what i wanted to do, yes they suited the Festool Tools but what about all my other stuff.... makita, Bosch, Knipex, Fein...etc
Well I got sick of them and started playing around trying to come up with a better design, I discovered that i could open the festool .pdf's in Adobe Illustrator.  And in doing this also discoverd that i could modify them to how i wanted them.
Now my extremely limited knowledge of Illustrator stopped me from creating a template like Festools,  but i was able to create a Template that I could keep changing a saving.
Anyways I got what i wanted and I'm happy to share here.   Feel free to use the ones i have created so far for your own use, I'll upload more as i create them.
if i have this uploaded correctly they should be a .pdf  and in the correct size if printed.
The first image is the style i have gone with. The Festool and Blue Line remain constant all the changes are above this.
91044-0
« Last Edit: August 18, 2013, 09:11 AM by mike68au »
Offline promark747
Re: Custom Systainer Labels
« Reply #1 on: August 12, 2013, 11:36 AM »
Thanks...though you might want to check the spelling on your Rotex labels.
Offline SRSemenza
« Reply #2 on: August 12, 2013, 11:46 AM »
Nice labels Mike.  [thumbs up]
Offline mike68au
« Reply #3 on: August 12, 2013, 07:25 PM »
Thanks for pointing out my mistake... i have since corrected it and now they reflect the correct spelling.
If anyone would like me to make one for them to suit a specific tool please let me know. Happy to help out.
Note to Mods:  this was the second time i had to upload the pdf's as my first thread kept coming up as a blank page, if the Mods are able to delate that thread they " My Custom Systainer Labels" they can as it's effectively the same as this one.
Mike
« Last Edit: August 12, 2013, 07:28 PM by mike68au »
Offline Kevin D.
« Reply #4 on: August 13, 2013, 03:45 AM »
Your Festool Labels are great.  Thanks for your generosity in posting.  I have saved your files for when I need to polish up my setup when I have time.  Much appreciated!
Kapex, CT-SYS, SYS-Cart, Pro 5 Sander, CT36AC, TS75, MFT 1080, MF-SYS/2, PS300 EQ-Plus, Parallel Guides Set, LR32 SYS, RO 150FEQ-Plus, OF1400 EQ Plus, DOMINO 500 Q-Plus,  Domino XL, MFK 700 EQ-Set, FS-SYS/2, CT22 w/hose storage, D36HW-RS-Plus, FS 1900/2, FS 3000/2, FS 1080/2-LR32, FS 1400/2-LR32, Gecko, Festool Floor Mat, Festool Stein, Multi-Tool, tape measure, large and small Festool floor mats (foam rubber).
Offline mike68au
« Reply #5 on: August 13, 2013, 10:29 AM »
Your  Welcome Kevin... if there is anythiing you would like made up let me know and I'll do it.
I've also re-done the Fein labels and also added a corded version.
In regards to personal details or Business details i choose to keep that off these labels, as on the left side of my systainers i insert one of my business cards, the right and sides are for the labels.
91099-0
Offline boost13
    • AV Solutions
« Reply #6 on: August 15, 2013, 11:06 AM »
Nice work buddy. Did you print them on card int the end? I put mine into glossy business card holders.
Too much festool.......
TS55 OF1010 OF1400 DF500 Domino
RO90 RO150 ETS150/3
T15 TI15 T12 CSX(x2)
Carvex PS400 Kapex120
Syslite Vac-sys ......... sure theres more i have forgotten!
MFT3 (x2) CS50
CT MIDI & CT36 (x2)
Offline amt
« Reply #7 on: August 15, 2013, 11:14 AM »
These are really neat.  Would be very cool if we could get a library of images for every tool available.
BTW, are you printing this on to "peel and stick" paper, or just regular paper and sticking to the systainer by some other method?
Offline RL
« Reply #8 on: August 15, 2013, 11:17 AM »
Thanks for this, they are very useful.
Regarding other card ideas, like probably several other people I have a systainer full of router accessories (CMS parts etc.).
« Last Edit: August 15, 2013, 11:19 AM by RL »
Offline mike68au
« Reply #9 on: August 15, 2013, 12:05 PM »
My intention is to do one for every Festool in a Systainer as i do them i up load them here.  I also will be doing up some for Parts and Accessories as need then myself also.  Clamps , MFT parts,  Surfix, etc
As for how i print them what i choose to do was print them on 250gsm Photographic paper, this way i could get 4x6 pieces of paper and also achieve a good print quality.  (100 pieces was around $20) not a cheap way to go but i like the results.
After i printed 3 of each, i would laminate them all together, and then trim them to suit with a paper trimer so as to get a clean straight cut. After this i would put a piece of  very thin double sided tape on the back of them... and then just put them into the slots in  the systainer.
They have given me a very organised and clean result this way. They won't fall out and i realtivley protected from damage, plus i can remove them if needed.
Offline P2P
« Reply #10 on: August 18, 2013, 09:52 PM »
Really nice labels Mike!
Would you add a label for the Compact Cleaning Kit and one for the SysLite to your list?
I'm going to be purchasing a second SysLite and plan to put them both in their own Systainer with the charging cables.
Thanks!
Offline Locky
  • Festool Dealer
« Reply #11 on: August 19, 2013, 04:10 AM »
Great work Mike, i can see alot of people using them from the forum, including me  [big grin]
Offline mike68au
« Reply #12 on: August 19, 2013, 11:25 AM »
Thanks for the Comments guys.
@ P2P i have made the up the labels you have requested.
I have also added a few new ones to my original post.
« Last Edit: August 19, 2013, 11:56 AM by mike68au »
Offline boost13
    • AV Solutions
« Reply #13 on: August 19, 2013, 11:50 AM »
Nice work mate. Very clean.
RO90 RO150 ETS150/3
MFT3 (x2) CS50
CT MIDI & CT36 (x2)
Offline P2P
« Reply #14 on: August 19, 2013, 03:32 PM »
Thanks much Mike!  I appreciate it!
Offline Cellule
« Reply #15 on: September 08, 2013, 02:38 PM »
Can you make one for the older model of track saw: festool TS55 EBQ-PLUS And the C15
Its so a great idea that you had that i bought some photo paper to make cards for all of my festool systainers  [tongue]
Offline bwiele
« Reply #16 on: September 11, 2013, 05:20 PM »
These are awesome!  Any chance you could work up a C12 and an LR32 label?  I used to have Adobe Illustrator but it was on an old computer that I don't have any more!
Offline mike68au
« Reply #17 on: September 13, 2013, 11:42 AM »
As per requests above:
I've updated the TS55EBQ to reflect the correct picture.... it was late and i was tired. ( well thats my excuse...lol )
« Last Edit: September 13, 2013, 08:04 PM by mike68au »
Offline mike68au
« Reply #18 on: September 13, 2013, 11:45 AM »
Plus a few Domino ones:
Offline neeleman
« Reply #19 on: September 13, 2013, 11:57 AM »
Picture on the TS 55 label is the wrong one, it's of the latest TS 55 REBQ.
BTW in the US there only a REQ version.
Here is my version, left and right one, just like Festools does.
They match the ones on the original T-Loc systainers also.
Festoolian since 1998.
FESTOOL:
CTL MIDI I | SYSROCK BR10 | SYSLITE KAL II | SV-SYS D14 | DSC-AG125FH | CDD9.6 | SYSLITE DUO | DF700 | HKC55 | TXS2.6 | CTL SYS | CXS2.6 | DWC18 | CTWings | BHC18 | CS50 | CMS-OF | MFT/3 | MFT/3-VL | KS120 | TS55 R | PSC420 | PS420 | BS75 | RAS115 | RO90 | RO150 | RS400 | RTS400 | RS300 | LS130 | DX93 | ETS150/5 | ETS150/3 | OF1010 | OF1400 | OFK500 | MFK700 | T18 | EHL65 | CTL26 | CTL22 | WCR1000 | D27-AS Plug-it | D36 UNI-RS | D36x7 | D50x2.5 | FS800 | FS800/2 | FS1080/2 | FS1400/2 (2x) | FS3000/2 | FSK250 | FSK420 | Gecko Dosh | Toolie | CE-SYS-2010 | RB-SYS CART (2x) | LEV1400 | LEV350 | SYS-MFT
PROTOOL:
Offline Festoolian
« Reply #20 on: September 13, 2013, 12:05 PM »
I have two Domino accessories; a Domi-plate and an SCG (self centering guide) fitted in foam together in a T-Loc.  Would it be possible to develop a label picturing one or both of those items?
Offline bwiele
« Reply #21 on: September 13, 2013, 02:20 PM »
Mike -
You are very kind to spend your time doing this for all our benefit.  Thank you!
Brian
Offline neeleman
« Reply #22 on: September 13, 2013, 02:28 PM »
Something like this?
Or don't you want the Festool logos?
Both companies don't have their own logos or brand names.
FESTOOL:
PROTOOL:
Offline mattdh
« Reply #23 on: September 13, 2013, 03:18 PM »
neelemen makes some of best looking labels out there. coming from one happy customer!
Offline bwiele
« Reply #24 on: September 13, 2013, 03:24 PM »
Neeleman - have you posted a whole variety of custom labels somewhere also (similar to this thread)?  You both do some impressive work...
Offline neeleman
« Reply #25 on: September 13, 2013, 03:38 PM »
Here are some examples.
I do make labels for Classic, Mini, Maxi and T-Loc systainers.
Mainly Festool/Protool and of course for other brands too.
I also make the right side labels which normally contains the Wattage, rpm for the machine and the bar code besides a few extra logos and Made in xxx.
FESTOOL:
PROTOOL:
Offline Festool Fishy
« Reply #26 on: September 13, 2013, 05:50 PM »
I can highly recommend Neelemans labels I have had them from him for Mini,Maxi, Classic & Tanos systainers.
The Classics labels really stick well, the printing and colours are first class on both the plastic and card type labels
Great job keep up the good work KN
Offline Peter Halle
« Reply #27 on: September 13, 2013, 07:03 PM »
 [sad]
Offline mike68au
« Reply #28 on: September 13, 2013, 08:10 PM »
They are great labels Neeleman.... especially the way you keep them along the same theme with all the different brands. Well Done!
Thnaks for adding to the thread, gives all the members an expanded choice
Personally i wanted a simpler format, I don't need all the text, just the name of the Product and a Picture ( be it much larger ) on all 3 sides -  I grab my systainers from my van by a quick glance at the label and having them all bolder and larger makes it easier.
Note: i have updated the TS55EBQ
Offline andvari
« Reply #29 on: September 15, 2013, 07:54 PM »
Hey thanks for the great labels guys.
I found the free Linux program Inkscape does a great job importing the pdfs and images here, and it has very useful tools for laying out the images on a page of labels.
Since I normally store my Systainers in edgewise to save linear shelf space the side labels are very helpful.
TS55, Domino 500, Domino Assortment, OF1400, CT36+Boom Arm, T12+3, FS3000, Parallel Guides, RO 90, ETS 150/3, Domino XL, Domiplate, LS130, RTS Guide Stop, CMS-GE, Carvex 420
Offline elimelech12
« Reply #30 on: September 15, 2013, 11:03 PM »
Can you post pics of your storage?
Sold my tools but kept a few Fes-tools...just in case.
Offline andvari
« Reply #31 on: September 15, 2013, 11:21 PM »
Uhh that would be very embarrassing to me. [embarassed]
All it is are wire shelves with systainers stacked on them.
Offline mirec242
« Reply #32 on: September 30, 2013, 04:54 PM »
I would also like to show you few of my labels. I was making them in CorelDraw and after printing I was laminating them, they are harder, so they are better holding in the
label holder and of course they are more resistant to dirt and humidity.
http://imageshack.us/a/img707/8427/alh0.jpg
« Last Edit: November 27, 2015, 09:27 AM by mirec242 »
Offline briankb
« Reply #33 on: November 06, 2013, 11:01 AM »
This is great!!! Thanks for making these labels and saving me a ton of time.
Could you make one for the Domino Tenon Assortment (498899)?
here is a link to detail page and a photo http://www.festoolusa.com/power-tool-accessories/joiners/tenon-assortments/domino-tenon-assortment-498899
I have a Systainer with just the various MFT style clamps as well if you are feeling super generous with your time :-)
Thanks again!
Offline Tom10
« Reply #34 on: December 22, 2013, 07:55 PM »
Just want to say thanks to Mike for making all the labels.  I put them on all of the on my systainers.  Then of course I need labels for my mini systainers so I found this app called iDraw.  Wasn't to hard to figure out and soon I had labels for the minis.  I attached one of them that I made for a wera ratchet set.
Offline SRSemenza
« Reply #35 on: December 23, 2013, 12:14 AM »
Hi mirec and Tom,
Welcome to the FOG!  [smile]
Offline Charles959
« Reply #36 on: December 26, 2013, 02:33 PM »
TANOS has PC-only label software, which you can find by searching for:
Tanos label software
Offline Cellule
« Reply #37 on: December 26, 2013, 02:39 PM »
I downloaded it and it is in deuch only, I can't do anything..
Offline Charles959
« Reply #38 on: December 26, 2013, 04:26 PM »
Thanks for letting us know.
Offline SRSemenza
« Reply #39 on: December 26, 2013, 07:00 PM »
Welcome to the forum, Charles.
Here is the link to the label creator on the UK Festool site  http://www.festool.co.uk/service/t-loc-custom-labels/pages/create-your-label.aspx
Offline Charles959
« Reply #40 on: December 27, 2013, 10:55 PM »
Seth,
Thank you.
The pdf files should be much more useful to me than PC-only software.
I remember thinking when I first had a few Systainers on a SYS-Cart, "From stone age to Star Trek in minutes".
Offline Greg Powers
  • Metric convert
    • Stargate Unofficiial
« Reply #41 on: March 17, 2014, 01:22 PM »
Any additions to this set of labels, like a makita grinder. 90mm sandpaper, laser level...
Greg Powers
Offline gkaiseril
« Reply #42 on: March 17, 2014, 04:28 PM »
If you download and install Adobe Reader XI you will be able to import image files of the type Jpeg, Png, Bmp, and Gif. So you can use your cell phone camera to take an image of your stuff and inset it into the label.
Reader XI has added the ability  to import an image file into a PDf form.  This is not possible with older versions of Reader.
George Kaiser
TS 55 REQ, RO 90, RO 150, CT 26, PSB 420, MFT/3
Offline Df1k1
« Reply #43 on: April 28, 2015, 03:37 PM »
Just found this and was exactly what I was looking for (MFT Accessories label).
Thanks for taking the time to post
Offline jdm5
New Custom Systainer Labels
« Reply #44 on: April 10, 2016, 02:32 PM »
Resurrecting an old thread...thanks to @mike68au for his work on these labels.  I wasn't feeling great today, so rather then spending time in the shop I worked on additional labels I had a need for.
These included:
Festool Domino 500 Guides
Festool Domino 500 Tenon Assortment
Festool Domino 700 Tenon Assortment
Festool ETS EC 150_3 Sander
Festool HL850 E Planer
Festool MFK700 Trim Router
Festool OF2200 Router Accessories
Festool RTS 400 EQ Sander
Festool VAC SYS Pads
Festool VAC SYS PUMP
Festool VAC SYS SE1
Festool VAC SYS SE2
Grex 23 ga pinner
Magswitch Featherboards
Mirka Deros 125mm Sander
Mirka Deros 150mm Sander
OF2200 Plunge Router
Omer Brad Nailer
Porter Cable Spindle Sander 121
Push Sticks (Bench Dog logo, I have a couple and the logo is cool)
Router Bits (Used the Whiteside logo because I primarily have/use them)
True Position Drill Guide
I'm attaching the PDF's here as well as making the PDF, Photoshop, and source images available from my Dropbox.  I want to stress I'm not a graphic artist - some are pretty good, some are eh, but you get what you pay for...
JDM5's Systainer Labels
Let me know if you find any mistakes or have feedback.
« Last Edit: April 10, 2016, 02:40 PM by jdm5 »
Drank the green Kool-Aid...gave up counting long ago.
Offline neeleman
« Reply #45 on: April 10, 2016, 02:43 PM »
Nice labels indeed.
But I don't think some of them can have two brandnames on it.
Like the Fein MM with the Festool logo beneath it.
It's Fein or Festool but not both.
Other labels don't have the Festool logo beneath.
Here's my Fein version also.
FESTOOL:
PROTOOL:
Offline Lou in DE
Re: New Custom Systainer Labels
« Reply #46 on: April 10, 2016, 03:07 PM »
Thanks very much - these are great and I can use quite a few of them. It never occurred to me to put a nicer label on the Festool tool systainers but the original labels are kind of difficult to identify from a distance with older eyes  [embarassed].
Lou (kind of a label nut)
In theory, theory and reality are the same. In reality, theory and reality are different - especially in woodworking!
Offline waterloomarc
« Reply #47 on: April 12, 2016, 09:20 PM »
I'm using the link above to the UK website for their PDF's. Can somebody tell me how to change the font size, or if it's even possible?
I'm on a Mac but downloaded the acrobat reader. I can change out the picture etc. but the default font is pretty small.
Thanks!
Offline neilc
« Reply #48 on: April 13, 2016, 01:33 PM »
@jdm5 - thanks for sharing these.  They are excellent.  I've used many of them.
Do you have labels for any of the drills?  The CXS or T15 would both be welcome!
Also the 1010 Router!
neil
Offline jdm5
« Reply #49 on: April 13, 2016, 03:32 PM »
@neilc here you go (now that I have the templates setup they are pretty quick).  I'm also keeping all of them in my Dropbox folder (much easier).  If anyone is aware of a Festool central file site let me know, happy to centralize them somewhere else.
1010
CXS
T15
Offline neilc
« Reply #50 on: April 13, 2016, 06:22 PM »
Fantastic!  Thank you!
Offline jdm5
« Reply #51 on: April 14, 2016, 06:16 PM »
Some additional labels
MFS 400 and 700
Lamello Cantex Ergo
Lamello Zeta P2
Bosch JS572EL
Offline jdm5
« Reply #52 on: April 14, 2016, 06:24 PM »
Lamello Zeta P2
Zeta P2 Connectors
Offline swag
« Reply #53 on: April 15, 2016, 12:55 PM »
Hello!
I missing these labels.
Thanks!
  • T18 / 3 Li 3 Plus
  • DWC 18-4500 SET
  • ZH-SYS-PS 420
  • CENTROTEC-Systainer SYS
  • Hole Saw-Systainer
Offline jdm5
« Reply #54 on: April 16, 2016, 08:35 AM »
T18 / 3 Li 3 Plus
DWC 18-4500 SET
ZH-SYS-PS 420
(I don't have any of these tools, let me know if these are the right images).
What do you mean hole saw systainer?  Just a picture of hole saws?  Does Festool make this?
Offline swag
« Reply #55 on: April 16, 2016, 01:36 PM »
T18 / 3 Li 3 Plus
DWC 18-4500 SET
ZH-SYS-PS 420
Looks perfect! thank you!
Sorry, i mean a Festool systainer with my random hole saws, like this
Is it possible to change some label something on my own ? Which program can i Use if I want to add my name somewhere in the label or something like that. I use Gimp (program) alot.
If i open it, something happends.. https://i.gyazo.com/b87ddbd470189dc168c402cb252dc35b.png
« Last Edit: April 16, 2016, 01:53 PM by swag »
Offline jdm5
« Reply #56 on: April 16, 2016, 09:17 PM »
Gimp can open the Photoshop files I've generated, and I've stored them all in my Dropbox:
https://www.dropbox.com/sh/nl1rdr00qn55zhp/AADrezuRUzpBKzmH55IrOESSa?dl=0
I've not used Gimp but from what I read you should be able to modify them that way.
Offline Holmz
« Reply #57 on: April 16, 2016, 09:49 PM »
@jdm5 - Thanks, you got most of the what I can use.
(Do you happen to have a DEROS one too?)
@mike68au - Thanks M8
I have some DIY ones out of card stock with marker on them, but half the time they pop out.
Is there any special lamination deal? Or just bring them in and the lamination is standard?
Or do I need to say some specific "???" lamination (like heavy duty, or 10#)?
Offline jdm5
« Reply #58 on: April 16, 2016, 10:23 PM »
Deros - yes look above in this thread
Offline Holmz
« Reply #59 on: April 17, 2016, 12:47 AM »
And I stumbled out and it already has one on each side... just with writing on clear.
<another cup of coffee in the paw now>
Offline jdm5
« Reply #60 on: April 17, 2016, 07:42 AM »
I've been printing them on reasonable quality office paper, then using 3 or 5mm heat laminating pouches with an electric laminator - I think I have this one:
http://www.amazon.com/Scotch-Thermal-Laminator-Roller-TL906/dp/B00CLV8ZIU/ref=sr_1_5?ie=UTF8&qid=1460893158&sr=8-5&keywords=scotch+laminator
And then just the business card size pouches:
http://www.amazon.com/Scotch-Thermal-Laminating-Pouches-TP5900-20/dp/B0018NDH4Y/ref=sr_1_5?ie=UTF8&qid=1460893279&sr=8-5&keywords=3m+laminator+pouch
I trim them to size, and they work fine.
Offline Billy stray
« Reply #61 on: April 20, 2016, 09:51 PM »
Has anyone seen or used the guy on YouTube who prints them on hard plastic cards?
Billy
Offline swag
« Reply #62 on: May 03, 2016, 11:22 AM »
How do i print 4 labels on one paper? My printed labels are always in the middle of the paper (a4) I want to print 4 or maybe more on one paper.
« Reply #63 on: June 09, 2016, 04:52 PM »
Would you mind making some for the new sanders please.
Offline jdm5
« Reply #64 on: June 09, 2016, 05:05 PM »
What new sanders?
Offline RockstarRemodel
    • Rockstar Remodel
« Reply #65 on: June 09, 2016, 06:39 PM »
It took a while to find the card stock I wanted to use for this. I called around and looked online to order plastic cards, but they all wanted to do large runs of a single image. I looked for printable plastic but mostly those were for laser printers, or transparencies for projectors and too flimsy.
Eventually I looked up "waterproof paper" and found my solution. I got a 10 pack of this: Inkjet Teslin Synthetic Paper - 10 Sheets https://www.amazon.com/dp/B004PX7ZTC/ref=cm_sw_r_cp_awd_CZk4wb1GET0VW
I printed these in my inkjet printer on Matte Photo Paper setting.
After a few months of not-gentle usage, they're holding up great, wet and dry.
Keep Rocking
Brendan with RockstarRemodel.com
Offline Mr_Mod
« Reply #66 on: August 09, 2016, 04:03 AM »
I have had a go at producing labels in Excel, I have managed to get 8 lables per A4 page. Have enclosed the Excel template for you all
Offline Trevin
« Reply #67 on: August 12, 2016, 02:12 AM »
Does anyone have a label for the C18 + 3 Drill or the DTS 400 sander?
Thanks,
Trevin
Festool: MFT3 (x2), OF1010, OF1400, LR32, Domino DF500, Domino XL DF700, Kapex KS120, TS-75, Carvex 420, CXS, C-18, Vecturo OS 400, DTS 400, Pro 5, Rotex 125, VAC-PMP, VAC-SYS-1, VAC-SYS-2, CT-26 (x2), CT-SYS, SYS Light DUO, SYS-ROCK
Other: Minmax FS41, Sawstop PCS (3HP, 52"), Laguna BX14, Jet 17" Drill Press, Rikon 70-220VSR Lathe, Incra LS Router Station, Laguna P/Flux 3 Dust Collector
Offline ThReM
« Reply #68 on: August 12, 2016, 03:15 AM »
(Attachment Link)
Superbe !!
I'm impressive, it's really pretty, i think i will do it for my systainer  8) 8)
CXS Li 2,6 Set + PDC 18/4 Li 5,2-Set/XL + Centrotec SYS1 CE SORT | BHC 18 + D27-BSD | TS-55 R-EBQ + FS SYS/2 | OF 1400 + SYS OF | PS 420 EBQ Set + ZH-SYS-PS 420 | CTM 36 E AC + Kit Artisan + CT Wings | EHL 65 EQ-Plus | Planex LHS 225 EQ-Plus/IP + SYS-STF D225 | DSC-AG 125 Plus-FS | DSC-AG 125 FH | SYSLITE KAL II - Set | SysRock BR-10 | MFT/3 + accessoiries | Some Systainer & Sys-Roll & Sys-Cart | Mirka Deros 5650 CV + Mirka SYS3 for abrasives | Fein Multimaster 350 Systainer Edition
Offline Trevin
« Reply #69 on: August 12, 2016, 12:47 PM »
Also,
Has anyone seen a label for the Vecturo tool?
Thanks,
Trevin
Offline Trevin
« Reply #70 on: August 13, 2016, 01:02 AM »
Hi All,
So I gave making labels a try and it was not that bad once I figured it out.  Here is a label that I am going to use on my systainers as an "Owner" ID label.
Trevin
Offline neeleman
« Reply #71 on: August 14, 2016, 06:00 AM »
Also,
Thanks,
Trevin
Like this, it's simply downloadable from Festool.com.
FESTOOL:
PROTOOL:
Offline jdm5
« Reply #72 on: August 30, 2016, 08:31 PM »
I've been working on reorganizing my shop / Systainers - realized I had a bunch of Systainer labels to make and wasn't thrilled with my method of printing custom labels (posted above, basically printing on paper, trimming, laminating, then trimming again to fit...too time consuming and imperfect).
I found this thread:  http://festoolownersgroup.com/festool-and-tanos-systainers/my-systainer-label-printing-process/ (complete credit to @dbroere ) and wanted to point that thread out here...
I purchased a Canon MG7720 (about $110 on Amazon), the 'J tray' for the Canon inkjects ($18 on Amazon), and a package of 100 PVC CR80 cards (~$14 for the 100...0.14 each).
I've since been converting my original Photoshop images to the CR80 format - and I have to tell you this is absolutely the way to go if you're willing to spend the money.
They look ABSOLUTELY professional, and are a definite time saver - I print them directly from Photoshop onto the PVC card and they are ready to go (ok, I let them dry for a little bit).
I'm uploading my converted 'J tray' / PVC card Photoshop files to my Dropbox account; I'm not converting them to PDF as the formatting has to be exact and I'm not confident it will be converting to PDF and then printing them.  They are here if you're interested:
https://www.dropbox.com/sh/qjgmudu7ji070hm/AACvVHA29PBUv-sVVAYLjgU_a?dl=0
Thank you @dbroere for pointing this out...I'm thrilled with the results!
Online vkumar
« Reply #73 on: August 31, 2016, 07:50 PM »
I looked at the CR 80 cards. They say that these should be printed on the Zebra printer not inkjet printers, but I was looking at the 500 pack not the 100 pack you were referring to. Could you please post the link to the CR 80 cards you are using with the inkjet printer? Thanks.
Vijay Kumar
Offline jdm5
« Reply #74 on: August 31, 2016, 09:27 PM »
I'm using the 'Brainstorm ID' cards specifically for printing using inkjets:
Link
I chose Brainstorm ID as the seller - Brainstorm ID had the templates for Photoshop (and a ton of other stuff) plus instructions on how to use them, so I went with them.  Looks like the price dropped down to $12.81 as I post this.  (absolutely no affiliation with them, but if they went through the trouble to provide free templates and instructions I'd reward them).
I've done about 75 cards over the last couple days (3 per Systainer) and am still thrilled.
The printer is a "$100 printer" - the print quality for this is excellent, but the build of the printer is very plasticky - I would be gentle with it.  The other caveat is I wanted to have the ink run all the way to the edge of the card - which means that a small amount of ink prints onto the J tray...I'd recommend cleaning the tray every 4-5 cards so it doesn't build up and eventually smudge either your hand or the card.
« Last Edit: August 31, 2016, 09:37 PM by jdm5 »
Offline 2ooladdict
« Reply #75 on: September 06, 2016, 10:22 AM »
These labels are awesome. I have a few empty Classic Systainers used to store my Microfence Edge Guide and Circle Jig, Foredom TXH, LR32, Drill Bits etc. Have been thinking about making labels for them but don't seem to find a template for the Classic labels anywhere.   It is not too difficult to start from scratch but if one exists, would be a great help.
Offline gms002
« Reply #76 on: October 19, 2016, 11:05 AM »
Few non-Festool labels I've made - the older ones are for the classic sys
I always laminate them after printing - perfect solution for T-loc labels.
Labels for sys classic tend to peel off. I don't fight it, just print new ones as needed.
I've designed a small MS Access application to make them. Happy to share if anybody interested.
All attached pdfs are A4.
* SYS_TLOC_Label_WS_DISCS.pdf (77.27 kB - downloaded 242 times.)* SYS_TLOC_Label_WS3000_4.pdf (73.7 kB - downloaded 163 times.)* SYS_TLOC_Label_WS3000_3.pdf (72.13 kB - downloaded 113 times.)* SYS_TLOC_Label_DDSB.pdf (53.46 kB - downloaded 122 times.)* Systainer_Classic_labels_laminated.pdf (1794.68 kB - downloaded 169 times.)* Systainer_Classic_Label.pdf (1663.52 kB - downloaded 163 times.)* Systainer_Classic_Panasonic EY7202.pdf (135.23 kB - downloaded 111 times.)* Systainer_Classic_Panasonic PAN-CH01.pdf (73.77 kB - downloaded 104 times.)* Systainer_Classic_Mujingfang_Taiwan_Style_PLanes.pdf (163.01 kB - downloaded 111 times.)* Systainer_Classic_Mujingfang_Rabits.pdf (108.99 kB - downloaded 103 times.)* Systainer_Classic_Mujingfang_Convex_PLanes.pdf (210.43 kB - downloaded 114 times.)* Systainer_Classic_Mujingfang_Concave_PLanes.pdf (236.12 kB - downloaded 118 times.)
« Last Edit: October 19, 2016, 11:11 AM by gms002 »
Offline gms002
« Reply #77 on: October 19, 2016, 11:19 AM »
If you have pictures, I can make the labels for you.
« Reply #78 on: October 19, 2016, 06:22 PM »
I'm still trying to find labels for the ETS 125 EC, RAS 115, and DTS 400 if you can help help a chap out. All T-loc
Offline thudchkr
« Reply #79 on: October 19, 2016, 10:05 PM »
I'd be interested in seeing your MS Access application. I use Access a lot and have set up quite a few programs in it. AND, I really need todo some labels on my old Classis systainers.
Clint
Clint
TSC 55, TS 55, TS 75, HKC 55, DF 500, DF 700, Kapex 120, UG Ext. Wings, MFK 700, OF 1010, OF 1400, OF 2200, CT 22, CT 26, ETS 150/3, ETS EQ 150/5, PRO 5, DTS 400, RO 90, RO 150, CXS, DWC 18-4500, MFT Kapex, MFT 3 (2), MFT 800, MFT 1080
Offline 2ooladdict
« Reply #80 on: October 19, 2016, 11:46 PM »
@gms002 Thanks for the offer. I was able to make them using Microsoft Publisher and printed them on Avery transparent Labels. The look even better than the original Festool labels in my opinion on the Systainers.
Offline gms002
« Reply #81 on: October 20, 2016, 03:49 AM »
Clint
Can you handle Access 2000?
Offline thudchkr
« Reply #82 on: October 20, 2016, 10:01 PM »
Clint
Am currently using 2003. Should convert it if it needs to.  Have another unit with 2000 on it if I had to go with it.
Clint
Clint
Offline gms002
« Reply #83 on: October 21, 2016, 10:31 AM »
Clint
Zipped  application attached (systainerLables.zip) + few pictures, so you can see how it works.
All reports printing labels are data driven - no embedded pictures.
Open the mdb. Edit table Labels_Systaiiner (spelling, I know) and change data
in columns:pic_nm, logo_nm and Side_Picture to point to wherever you keep yours. Try not to change the sizes of objects in reports. The reports will automatically size any pictures you use to correct systainer label dimensions.
Other reports there - rulers, scrollsaw layouts for  my japanese style boxes, etc . Let me know what you think. If you don't like them - delete them. The VB code in some of them is very ugly, but works. I didn't write it for sale. As I get older I keep forgetting things - this acts as my external RAM. Comes handy.
All reports are set to print on A4 paper.
Any problems - let me know. "we have no problems - we have solutions :)"
Good luck
George
Offline gms002
« Reply #84 on: October 21, 2016, 10:35 AM »
Clint
What glue are you using on the classic sys labels?  I laminate the labels and use double sided tape, but it doesn't hold too well. Don't want use superglue.
Offline Xoncention
  • Build a bridge and get over it...
« Reply #85 on: October 21, 2016, 07:56 PM »
Clint
The laminate you are using may hinder the effectiveness of your double sided tape to adhere.  There are different grades of double sided tape too.  You may want to check with your supplier and choose a tape better suited for the surface you are connecting.
Offline Billy D
« Reply #86 on: May 02, 2017, 03:21 PM »
Made some from those found here and a few extra - put em all on a single sheet for printing -
Writing Tools :)
SPAX Screws
SNAPPY Hex shank bits
Rulers/Measuring
12v Milwaukee
Makita - BO900V Sander
FastCap Power Head screws
DEWALT DWP611PK Router
262765-0
[ Specified attachment is not available ]
« Last Edit: May 04, 2017, 10:21 AM by Billy D »
Offline thudchkr
« Reply #87 on: May 03, 2017, 12:56 PM »
Clint
I have yet to make and attach new labels to my classic Systainers.  I'd like to keep them from sticking out much, but want them to stick well.  I've been attaching Avery Weatherproof Labels to blank PVC plastic ID cards for my t-loc Systainers. I may try attaching some of those ID cards to the classic Systainers using double stick tape.  If I find a decent double stick tape that will hold without being too thick.
Will post here if I find an acceptable solution.
Clint
Clint
Offline Gwerner
  • They call me George...
« Reply #88 on: May 03, 2017, 01:27 PM »
These are the labels I've made for my systainers, even redid the Festool ones to make them easier to identify when I send my wife to grab one from the shop.
I made the template in power point and if I cut right on the lines, they fit perfectly.
« Reply #89 on: May 03, 2017, 01:43 PM »
Excellent idea & execution...the standard Festool labels are tough to see and tell apart.  [thumbs up]
That's the reason I went to different colored latches but trying to remember what color equals what tool is also an annoyance.
Offline thudchkr
« Reply #90 on: May 03, 2017, 05:34 PM »
Here is something I created for my T-Loc Systainer labels. I got some of the PVC plastic ID cards, https://www.amazon.com/gp/product/B005H5W0YM/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1, which slide perfectly into the slots on the Systainer.  I bought Avery Weatherproof labels, (15513).  The label is the correct height for the ID cards, but needs to be trimmed for the correct length.  I created a PDF to create the labels, allowing you to enter your text, an image for the contents and an image for the brand.
Attached you will find an example of a full sheet of labels, ready for printing and trimming.
And also a copy of the blank form, ready to insert your items.
I just downloaded my tool images and cropped them to where they look good in my PDF.  You can change the image over-and-over until you get it right, then send it to the printer.
I use a color laser and so far, my labels have held up nicely.
Clint
« Last Edit: May 03, 2017, 05:59 PM by thudchkr »
Clint
Offline ben_r_
« Reply #91 on: May 08, 2017, 12:14 PM »
Is there a label template for the Mini Systainers? I haven't seen one, but I probably missed it.
Offline iekoch@comcast.net
« Reply #92 on: May 09, 2017, 05:35 PM »
These labels are great, thanks for providing them,  I could use a few more I have not seen here, if it is not too much trouble.  With everything being monetized I am surprise you have not set up a month subscription for labels.
Plumbing,
Electrical
Drywall / Tile
Prep Box
Milwaukee 18V Sawzall
Nail Guns
Painting
thanks
Offline DOZERBUILDS
« Reply #93 on: June 06, 2017, 11:05 PM »
Hey. Very cool labels and very pro.
I dont mind sending you a few bucks for the vector file so i can add some of my own tools that are non festool but in systainer boxes.  Im assuming you used illustrator or photo shop?  I would love to use your labels. But also need to customize.  I will post my versions also for others to take advantage of... lmk. Thanks
Offline ben_r_
« Reply #94 on: June 07, 2017, 11:50 AM »
Does photoshop do vectored graphics? I thought it just "rasterized" everything.
Offline Ebuwan
« Reply #95 on: September 18, 2017, 11:38 AM »
Hi all,
First post here.
Started to make my labels and get organized with Systainers, and have become obsessed.
Here is my first shot; for all my Leigh Dovetail jig accessories. I've also gone as far as to spray paint the T-Loc latch for the Leigh color. It would bother me to have a drawer full of Blue T-Loc latches, and paint has held up.
For Leigh i used Rustoleum Rich Jade (http://www.rustoleum.com/product-catalog/consumer-brands/stops-rust/protective-enamel-spray?ls=312816&lc=Rich%20Jade)
Sanded T-Loc with 240 lightly, 2 light coats of Rustoleum primer, 3 light coats of Rich Jade, 2 light coats of Satin clear coat.
Also made a label for my Kreg K4 Master set.
Thanks for the label help!
Ev
« Last Edit: September 18, 2017, 11:43 AM by Ebuwan »
Offline Holmz
« Reply #96 on: September 18, 2017, 05:25 PM »
Plumbing,
Electrical
Drywall / Tile
Prep Box
Nail Guns
Painting
This is what I was also needing...
It is all the small misc stuff that becomes a scavenger hunt.
Offline Ebuwan
« Reply #97 on: September 18, 2017, 06:43 PM »
Hey Holmz
I need those ones too!
I'll try and whip them up tonight
Ev
Offline Ebuwan
« Reply #98 on: September 18, 2017, 10:18 PM »
Hey Holmz (and everyone),
Got those labels you wanted. Not sure what you meant by "Prep" though?
Also some Veritas ones i have for woodworking hand tools, drywall anchors, fastners, etc.
Thanks!
Ev
Offline Holmz
« Reply #99 on: September 22, 2017, 03:33 AM »
Thanks!
Ev
OK These are really starting to seem slick now.
Offline AndyMan1
« Reply #100 on: September 20, 2018, 04:14 AM »
Hi all, new here to the FOG.
Mike, a sterling job on the labels, after much searching and head scratching i cannot, for the life of me, find left and right TLOC labels for the EHL65E (non Q) planer.
Does anyone have them ?
« Last Edit: September 21, 2018, 02:17 PM by AndyMan1 »
Offline AndyMan1
« Reply #101 on: September 21, 2018, 01:12 PM »
Anyone have a Triton TGEOS Label?
Offline fyme
« Reply #102 on: September 30, 2018, 05:53 AM »
These are my custom labels :)
Offline Hempstalk
« Reply #103 on: October 02, 2018, 03:58 PM »
I too have become bored of looking at those paper labels on the systainers so I took a shot at some custom labels.  I noticed most like pictures on theirs but the name seems to be good for me.  Although I may play around with some icons or something.  I did these in brushed aluminum but these can be lasered in a ton of different colors.
285491-0
Offline fyme
« Reply #104 on: October 03, 2018, 01:51 PM »
Very nice  [smile]
Offline ben_r_
« Reply #105 on: October 04, 2018, 05:03 PM »
(Attachment Link)
Nice! What laser do you have? Think thats going to be my major purchase for next year. Had my eye on the Epilog Mini 24.
