Author Topic: Honda EU2000i in Systainer?  (Read 3892 times)
Offline Slartibartfass
  • How'ur'duin'......
    • The Accidental NAINA Store Email List
« on: October 05, 2017, 07:31 AM »
Hi all, It’s been a while since I posted....
Has anyone ever tried to put a Honda EU2000i in a Systainer?
Cheers
Offline kevinculle
Re: Honda EU2000i in Systainer?
« Reply #1 on: October 05, 2017, 08:23 AM »
No but I think the carry handle on the EU2000i would be considerably better to lug it around than a systainer.
« Reply #2 on: October 05, 2017, 08:38 AM »
I thought about putting it on a Sys-Roll on the bottom and stack more Systainers on top with tools so I have a mobile power source to run tools/recharge batteries....
Offline RKA
« Reply #3 on: October 05, 2017, 11:33 AM »
I haven't measured mine, but off the top of my head, I'm 95% sure the case for the 2000 is too large.  You could probably build something to accomplish what you want (make sure the exhaust can get out and allow room so you don't burn any surrounding materials).  If you could remove the requirement to power higher amp tools, maybe the 1000 would be a better choice?  I'm not sure if that improves your options or only reduces the weight though.
-Raj
« Reply #4 on: October 05, 2017, 12:44 PM »
Already got the 2000... Sys 5 would require large scale cut-outs at both end as far as I can tell to fit it. Not sure if you take the cover off the genny if that changes. Maybe there is a way to just modify a Systainer lid and put it on stilts in all 4 corners to achieve what I am thinking about....? How to make it stable and connect it to the Sys-roll is the question....? Thx for responding and brainstorming with me. Appreciate it!
Offline kevinculle
« Reply #5 on: October 05, 2017, 12:54 PM »
I wouldn't remove the cover on the EU2000 as that is where much of the engineering that makes it quiet resides.
« Reply #6 on: October 05, 2017, 02:30 PM »
Good point....And I want to be able to lift the genny out the Systainer for stand-alone use too....
Gotta think about the stilts.....
Offline JimH2
« Reply #7 on: October 05, 2017, 02:49 PM »
I doubt the EU2000i is designed to be run from inside of any container with heat and ventilation being the biggest concerns.
« Reply #8 on: October 05, 2017, 02:56 PM »
There are containers with proper openings for RV use out there.....
Offline six-point socket II
  • aka @the_black_tie_diyer
« Reply #9 on: October 05, 2017, 03:01 PM »
Brainstorming is always great, I'd like to offer 2 ideas.
Please correct me if I'm wrong, but what you basically want to do/have is that generator sitting on a SYS-Roll and the ability to stack a couple of Systainer on top. Right?
Have you thought of building a base and a top plate for the generator?
If you take a T-LOC SYS-1 and cut it at any desirable length. Partly fill bottom with epoxy to give it additional strength and build a structure/baseplate that is hold in place by the epoxy and to which the generator will be mounted. Find a solution to mount the Systainer Lid on top of the generator.
Another Idea would be to build a "skeleton systainer" - Same principle. Cut a SYS-1 so you get top and bottom. Some aluminum rods... I guess you get the idea. :)
Kind regards,
Oliver
Kind regards,
Oliver
« Reply #10 on: October 05, 2017, 03:08 PM »
Oliver, Yes, thats the general idea.... Good thoughts. Actually was thinking about angle iron for the corners.... We are getting somewhere here.....Appreciate the input....
Offline RobBob
« Reply #11 on: October 05, 2017, 03:11 PM »
Here's what I did for a compressor.  Used two shelf brackets, some T-bolts to hold it on the front up-rights of the sys-roll and a Sys-cart base.
269734-0
« Reply #12 on: October 05, 2017, 03:16 PM »
And to give the reasoning behind this I need a mobile workstation when I do work at my boat at the dock that require power tools....Obviously setup works for a job site as well.....
« Reply #13 on: October 05, 2017, 03:21 PM »
(Attachment Link)
That is even better with the shelf brackets.....they might be in the way though with the Honda...Hmmmm
