Author Topic: Sharpening Station Systainer setup  (Read 1686 times)
Online Slartibartfass
  • How'ur'duin'......
    • The Accidental NAINA Store Email List
« on: December 13, 2017, 12:06 PM »
Need to learn how to properly sharpen chisels. Whipped this little sharpening station up... I still need to apply some epoxy coat to make it water tight....
Offline Master Carpenter
Re: Sharpening Station Systainer setup
« Reply #1 on: December 14, 2017, 12:31 AM »
I like it. I've always had a vague idea in my head to build something similar, just too many projects in line first.
Ts 55, Ts 75, of 1010, lr 32, mft, mfs 700, RO 150 x2 + paper asort, RO 90 + paper asort, pro 5, df 500 + dom asort, hl 850 e, ti 15, cxs, centrotec set, ct48, ct sys, vac sys, 32;55x2;118 tracks, a stack of sys and an og festool first aid kit. Kapex
Offline SRSemenza
« Reply #2 on: December 14, 2017, 09:33 AM »
Sharpening equipment stored inside?
Offline grobkuschelig
« Reply #3 on: December 14, 2017, 09:38 AM »
 That’s what I thought first, but it looks like the „base“ is covering the complete Systainer, so it might be too big to fit inside.
I might steal this idea with the slight adaptation of the smaller plate, if possible. [emoji41]
« Reply #4 on: December 14, 2017, 09:51 AM »
Initially I thought about making the plate smaller but I have the sharpening guide etc. in the systainer. Guess could use a bigger Systainer to fit everything inside.... Food for thought..... The sharpening stones go in the systainer when not in use....
« Reply #5 on: December 14, 2017, 10:17 AM »
@Smartibartfass, how do you engage those green cleat in the second pic with both rows pointing out.
Does the panel that sits on top slide in from the side?
« Reply #6 on: December 14, 2017, 10:24 AM »
The cleats in the front (is the backside) lock like a systainer in the back of the systainer below.
The cleats in the back (front if turned upside) provide the lateral stability and everything gets locked down with the little wood nub when you turn the systainer lock....
« Reply #7 on: December 14, 2017, 10:53 AM »
Thought about it some more and making the plate smaller prevents it from locking on top.....The whole point of the exercise for me... Nothing rocks while sharpening...And the systainer stack with the Starrett plate for honing is quite heavy. The stack lifts the whole thing up to a nice work height if you put it on a MFT.... (at least for me, rather tall....).
Here are picks of the content:
« Reply #8 on: December 14, 2017, 10:58 PM »
Interesting idea.  Not clear how the systainer doesn't move around on your table?  Do you have bench dogs behind the systainer?
« Reply #9 on: December 15, 2017, 07:28 AM »
No, the Starrett granite plate in the lower Systainer for honing/lapping is heavy enough tp prevent movements....
« Reply #10 on: December 15, 2017, 10:37 AM »
Switched the upper Systainer to next larger size to fit in water spray bottle and misc stuff....
