Author Topic: MFT Systainer (Not MFT Lid Systainer)  (Read 3598 times)
Offline Samo
« on: April 01, 2017, 04:25 PM »
OK!
Has anyone made an MFT Systainer insert with Kazain foam and liked the end result?  I need to protect the settings of the brackets and would like to have everything in the same place each time I need to set up.  Hopefully, make me faster and less frustrated by the mess of my current setup that is a cardboard box.
I'm doing a FOG search and need a storage solution for the MFT fence and rail as well.
Thanks, Sam
« Last Edit: April 01, 2017, 04:29 PM by Samo »
Offline T. Ernsberger
Re: MFT Systainer (Not MFT Lid Systainer)
« Reply #1 on: April 02, 2017, 07:57 AM »
I have not made one for the mft but I have used kiazen  foam a lot and like the out come.   It's pretty easy to use. I make all the outside cuts on the bandsaw and use Fast caps marker and knife to do the inside work.
Offline grobkuschelig
« Reply #2 on: April 02, 2017, 12:28 PM »
I have not tried Kaizen foam for anything yet.
I did some inserts with thin plywood lined with automotive carpet, since I had both laying around.
Am quite happy with the results. :)
Please share your progress here, I'm eager to see the results. My MFT-Stuff is currently residing in a Systainer, bubble-wrapped...
Offline Vondawg
« Reply #3 on: April 03, 2017, 08:50 AM »
Offline Samo
« Reply #4 on: April 05, 2017, 09:21 PM »
Like this ?
http://festoolownersgroup.com/festool-and-tanos-systainers/new-tanos-t-loc-sortainer-and-combi-systainers/90/
Magpal - reply #101 ( new tanos combi systainers))
Thanks, Von!
That is Sweet and had not thought of the Sortainer......
Offline Samo
« Reply #5 on: April 05, 2017, 09:35 PM »
My latest thought (Yes, I lie awake thinking of this crap at night) is a mobile cart like I built for our CMS setup.
We use two MFT/3's that I'm trying not to trash and a bakers rake is what we built for the CMS setup.  Like in this link but in wood.
https://www.festool.co.uk/accessory/451975---mt-1600
So, my thinking is to build a rack and it would except two MFT's and the rail, fence, and brackets etc. hanging off it.
« Last Edit: April 05, 2017, 09:50 PM by Samo »
Offline Samo
« Reply #6 on: April 05, 2017, 09:48 PM »
@grobkuschelig
Yes, thanks.
I have done the same, thanks mostly to Seth.  Kaizen is not easy to master and I think it is overpriced for what it is.
I do like the Systainer inserts I got from Kaizeninserts.com but again price?  They are computer cut and depending on the thickness, are at the very edge of the box for whatever thickness you order.
Cheers, Sam
« Reply #7 on: April 11, 2017, 05:28 PM »
If you look for Systainer inserts, I'd rather go with the two-color foam versions you can find on eBay etc.
They have a black top layer and colored base foam. In Germany they are cheaper that the kaizen foam inlays, from what I've seen.
You get these pre-cut for systainer size and are able to route out the cut-outs with your plunge router.
But I also have not tried these...  [embarassed]
Offline Samo
« Reply #8 on: April 13, 2017, 06:34 PM »
@grobkuschelig Thanks.  This sounds promising, hope you decide to try them and report back.  I may do the same as I like the contrasting color to really make it obvious something is missing and its rough outline.
Offline Samo
« Reply #9 on: April 13, 2017, 07:01 PM »
Checked Ebay but did not see the two color foam inserts.  I did see some cool custom wood ones that I like.   [big grin]
