Author Topic: Moving my shop - A tale of many Systainers in motion  (Read 3609 times)
Offline dwillis
« on: October 04, 2017, 04:24 PM »
Several weeks ago I moved my household across country using a professional moving company. But I rented a 15 foot U-Haul truck to move my most precious items, among them all of my Festools. Because of my undiagnosed medical condition, well okay, addiction to plastic boxes with green labels and great tools, I had a lot of Systainers to move. So I was looking for a way to secure the Systainers to survive a 2,000 mile drive. I came up with what I thought was a really clever way to secure everything, boy was I wrong.
Along one side of the truck I stacked all the Systainers against the side wall, but did not lock them together (this is a key oversight). Then I placed sheets of 3/4 EPS foam sheets against the Systainers and then two 4x8 sheets of 3/4 inch melamine coated boards against the EPS foam sheets. The idea here was to give a little padding to protect the Systainers. Then I used wide straps with a ratchet to secure the whole sandwich to the truck wall. Because the Systainers were over four feet high I added another two foot wide melamine board above the 4x8 sheet.
I wish I took a photo of my work, but I now have a stack of Systainers eight feet long and six feet high (told you I have a problem). Everything was securely fastened and I was positive that nothing would move. That was a poor assumption. Basically the truck acts like a large vibrating paint mixer when rocketing down the interstate at 70 mph, and amateurs like me have no business packing for a long haul. On my first day I only got down the road 200 miles before I called it a night and pulled into a hotel. My suitcase was in the back of the truck and when I opened the door I found my carefully planned and well executed packing job had exploded. In fact I could have just tossed the Systainers into a heap in the back of the truck instead of carefully packing them.
It appears that two things happened, one the strap loosened from the vibrations (yes, portions of the interstate system is in need of repairs), but since the stacks of Systainers were not connected they just cascaded down towards the back of the truck and half of them ended up in all sorts of positions all over the truck. But it was late, I was tired from moving, my back hurt, and it was raining and storming, so I grabbed my suitcase, closed the door, and went to bed.
Next morning I thought about repacking, but given all the other items I was moving the back of the truck was inaccessible, so I drove on, gritting my teeth for the next 1,800 miles. By the time I got to my destination the mess had gotten only slightly worse, and it was with a great deal of trepidation that I started to unload the truck, fully expecting to have to replace quite a few broken Systainers, and maybe even some tools.
Now the good news. Other than one latch popping off, not one Systainer or their contents were damaged, not one. Not too bad for throwing all my precious tools into a cement mixer for three days!
« Last Edit: October 05, 2017, 02:58 PM by dwillis »
Remember that the only scientist to walk on the moon was a geologist.  Dr. Harrison Schmitt - Apollo 17 - Valley of Taurus-Littrow - 11 to 17 December 1972.
Offline SRSemenza
Re: Moving my shop - A tale of many Systainers in motion
« Reply #1 on: October 04, 2017, 08:42 PM »
Well at  least you know how to mix several five gallon buckets of paint.  [big grin]
Incredible that none of them were cracked!
Offline DB10
« Reply #2 on: October 04, 2017, 09:18 PM »
  I think you may have overthought it,  My method for a long journey or one that involves going off road is to stack the boxes latched together on a old piece of carpet, heavy items at the bottom and accessories on top and maybe a tie down through the top handles. In my experience if you pack them in tight they can't go anywhere even travelling off road.
Offline Bohdan
« Reply #3 on: October 04, 2017, 09:39 PM »
This just goes to show how hard couriers try to ensure that your parcel arrives in a suitably reconfigured condition.
Offline PreferrablyWood
« Reply #4 on: October 05, 2017, 07:12 AM »
Seems like a form for chaos theory i practise. I like that nothing was broken against the odds. Still a nerve racking experince I can imagine.
RO 150, 850 HL E Planer rustic head standard head angle fence, MFS 400x2, MFS extensions MFS VB 700 x 1 MFS VB 1000 x 2 . CMS GE, sliding fence, VB and 2x VL extension tables, OF 2200, Accessory Set ZS OF 2200 M,36mm 5m antistatik hose, CMS OF+ CMS TS 75 insert modules. SYS-MFT Fixing-Set,  3.5m sleeved hose, Syslite duo, Sys 4 sort 3 x3, Sys Roll, Sys 1 Box x2 , classic Sys 3-Sort 4, classic Sys 3 Sort 6 x2, Sys Cart x3 Systainer 4 x2  as toolbox with selfmade inserts Systainer 5 as toolbox with insert.
Festool 18V HKC 55 Li 5.2 EB Plus FSK 420,FSK 250, Extra blade for the HKC 55 W32.TI 15, CXS 2.6 Ah version, RO 90 DX, PDC 18/4 plus DC UNI FF depth stop chuck,AD 3/8 square socket holder FF chuck, Centrotec Bits; -->Bit holder and bit selection BHS 65 CE TL 24x, ,Bradpoint DB WOOD CE SET ,Zobo (Forstner) D 15-35 CE-Zobo SET ,Masonary/stone bits DB STONE CE Set,Extender BV 150 CE, Countersink QLS D2-8 CE Hook turner HD D18, end centrotec<--.  TS 75 EBQ, PSC 420, OF 1010, RS 300 EQ, CTL Midi, MFT 3, Parf dogs x2pair +Bench dogs x2pair, FS 1080, FS 1900 .  will get Domino DF 700 XL,  CMS insert BS 120 Belt sander.
