Author Topic: Multimaster Systainer ... double decker  (Read 28341 times)
Offline SRSemenza
« on: August 10, 2013, 10:08 PM »
So I have had this for a  while and though I have mentioned it in a couple  I don't think I posted any pictures yet.  The  Tanos insert is too tall for a Sys - I and doesn't use all the space in a Sys - II.  A customized foam insert would allow  the MM to fit in a Sys - I,  but I went for the Sys- III  so that two inserts can be stacked  allowing  more room for accessories , and more sorting spaces.  I don't have a lot in it right now but I expect to be adding more blades and such as time goes on.  Orange Sys (couldn't resist) black latches , anthracite handle.
90978-0       90980-1
90982-2       90984-3
Offline tvgordon
  • Springfield, Ohio
Re: Multimaster Systainer ... double decker
« Reply #1 on: August 10, 2013, 11:14 PM »
Nice!
« Reply #2 on: August 11, 2013, 01:03 AM »
Very cool...didn't realize tanos makes orange....that systainers got swagger!!!  I traded the tile guy on a job, all my fein scraping/grout cutting & that rough gold triangle blade thing , for all his wood cutting blades. We were both happy.just thought I'd share that
Offline SRSemenza
« Reply #3 on: August 11, 2013, 01:14 AM »
Nice trade.
It was a BTI branded systainer. I used some PVC cleaner to remove the black BTI logo. The original latches were a medium gray color, that would fall in between the regular light gray and anthracite colors. Those latches went onto red systainers with my Milwaukee tools in them.
Offline at grimaldi
  • Toona, toona, toona
    • PacketLogix, Inc. - Committed to Your Network
« Reply #4 on: August 19, 2013, 09:04 AM »
Seth -
Thank you so much for posting this one.  I was just looking for something so similar.  any chance you could post the links to where you bought the inserts, systainer and latches?  I am in RI, USA FWIW.
 - ATG
Offline SRSemenza
« Reply #5 on: August 19, 2013, 10:43 AM »
The Systainer  is from  a German Ebay auction.   The latches were ordered from http://kofferfunshop.com/
The inserts and colored (T-Loc) latches are aavailable from --------------------
http://www.leevalley.com/US/Wood/Search.aspx?action=n
Or
http://www.woodcraft.com/search2/search.aspx?query=systanier%20insert
Offline Texas357
  • SCHLUTER SYSTEMS ASD, Bathroom Remodeler
« Reply #6 on: August 21, 2013, 02:49 PM »
I went with the sale woodcraft was having on the Multimaster sys2 set, and went ahead and threw in a orange catch just to trick it out a little bit [big grin]
« Last Edit: August 21, 2013, 05:52 PM by JD Sessler »
MFT/3, Domino DF500, OF 1400, TS 55 REQ, Carvex PS 420, CXS, ETS125, CT26, CT Mini and counting...
Offline Bhend18
    • Hendricks Construction
« Reply #7 on: August 28, 2013, 05:46 PM »
Did they discontinue the 8 compartment tray you used? I can't seem to find it on LeeValley or Woodcraft.
Domino DF 500, CT 36 E, Boom Arm Set, CT MIDI, OF 1400, LR 32, FS 2424/2-LR 32, FS 1400/2 LR32, TS 55 REQ, TS 75 EQ, HKC 55 EB, FS 800, FS 1080, FS 1900, FS 3000, FSK 250, FSK 420, Parallel Guide Set, MFT/3, Kapex KS 120, Kapex UG, CXS, PDC 18/4, Drilling Dust Nozzle, CMS-GE, Carvex PS 420 EBQ, Pro 5 LTD,RO 90 DX, RO 150 FEQ, RTS 400 REQ, RS 2 E, LS 130 EQ, RAS 115 E, HL 850 E-F Plus, MX 1200 E EF, CT Wings, Vecturo OS 400, SysLite KAL-2, SYSRock
Offline SRSemenza
« Reply #8 on: August 28, 2013, 11:15 PM »
Lee Valley shows the tray......   letter 'C' on this page.
http://www.leevalley.com/US/wood/page.aspx?p=64656&cat=1,43326,64664,64656
Edit. ooops looks like it is not available, no shopping cart symbol next to it.  But the five compartment tray would work the same way.  Also note the ones on that Lee Valley page are for Classic Systainers.
See about half way down this page for a new type with adjustable dividers for T-Locs.  http://www.woodcraft.com/search2/search.aspx?query=Tanos&pagesize=120
« Last Edit: August 28, 2013, 11:21 PM by SRSemenza »
Offline leakyroof
« Reply #9 on: August 30, 2013, 09:53 AM »
Seth, either your tools photograph/model really well, or that Fein MM is still in fairly pristine condition.. [wink]
Offline SRSemenza
« Reply #10 on: August 30, 2013, 10:52 AM »
Fairly pristine.   It hasn't seen much use yet.
Offline cnewport
« Reply #11 on: February 01, 2014, 09:25 PM »
Cool idea Seth!
Here's an odd thing I (think) discovered: If you leave the waxy/rubber coating that comes on the end of the multimaster blades - it melts through the tray! Either that or I left it in my trunk on too many hot North Carolina days - but only the blades with the coating still on them melted through. Anybody else notice this?
« Last Edit: February 01, 2014, 09:30 PM by cnewport »
Offline Benjamin
« Reply #12 on: February 01, 2014, 11:27 PM »
Really awesome set up Seth,
man I need to work something like this out for my MM
Offline ART at WORK
  • Buy less Recycle more
« Reply #13 on: February 01, 2014, 11:37 PM »
Super cool and i love the colour combi.
What is pvc cleaner. Do you have a chemical name for it.?
Nice job seth
Kapex 120 + UG Set, ETS 150/3, DF 500, RO 90, MFT/3, CTL 36 AC, RO 150, 0F 900, OF 2200, T15+3,  CDD 12, TS 55, A5 Router table, First Aid kit, LR 32 SYS, FS 800, FS 1400/2, FS 1400/2 LR32 FS2 3000, CTL Midi + Cleaning Set, Clamps, Parallel Guides, Centrotec drills, Zobo Forstner set and countersinks, Routers, Systainers, Sortainers, Sys Cart, Syslite
Offline SRSemenza
« Reply #14 on: February 02, 2014, 12:22 AM »
The PVC cleaner is basically a bunch of  chemicals. It is made to thoroughly clean PVC pipe before cementing it together.  Ketone, Acetone, Methly something or other........
That is pretty nutty .......   the blade coating melting through the tray. I better check mine and remove the coating.
« Last Edit: February 02, 2014, 12:32 AM by SRSemenza »
Offline wow
  • Inactive Member
« Reply #15 on: February 02, 2014, 03:36 AM »
That is way cool, Seth. Makes w me want to go buy some new systainers!
Offline joiner1970
Re: Re: Re: Multimaster Systainer ... double decker
« Reply #16 on: February 02, 2014, 03:52 AM »
Cool idea Seth!
(Attachment Link)
Yeah I had that with some ts55 spare blades, I had them sharpened and they came back with the protection on them. I put them in the systainer and exactly the same thing happened. They melted right through the insert.
Offline jobsworth
  • Does Anyone Know What Time It Is?
« Reply #17 on: February 02, 2014, 10:57 AM »
Seth,
It looks soooo clean. Do you use it or is it for display ppurposes ?
 [big grin] [big grin] [big grin] [big grin] [big grin] [big grin] [big grin]
Offline Holz-Her
« Reply #18 on: February 02, 2014, 04:09 PM »
ps:  ;)
Offline Bhend18
« Reply #19 on: February 02, 2014, 04:30 PM »
ps:  ;)
OK, that's just mean. I want one of those. [sad]
Offline NuggyBuggy
« Reply #20 on: February 02, 2014, 05:26 PM »
I really dislike multiple inserts in a single Systainer.   They're inconvenient to remove and reinsert.   Upper inserts often end up lying around to facilitate access to the bottom level, exposing the very tools you are trying to protect.  I like the cantilevered Systainers much better for the situations when the tools would fit.  I wish they had a model with just one cantilevered compartment, and wish they came deeper.
“I am on a drug. It’s called Charlie Sheen.”
Offline neeleman
« Reply #21 on: February 02, 2014, 05:36 PM »
ps:  ;)
I also WANT these original systainers from Fein!!!!!!!!
They will be available in the Spring.
Festoolian since 1998.
FESTOOL:
SYSROCK BR10 | SYSLITE KAL II | SV-SYS D14 | DSC-AG125FH | CDD9.6 | SYSLITE DUO | DF700 | HKC55 | TXS2.6 | CTL SYS | CXS2.6 | DWC18 | CTWings | BHC18 | CS50 | CMS-OF | MFT/3 | MFT/3-VL | KS120 | TS55 R | PSC420 | PS420 | BS75 | RAS115 | RO90 | RO150 | RS400 | RTS400 | RS300 | LS130 | DX93 | ETS150/5 | ETS150/3 | OF1010 | OF1400 | OFK500 | MFK700 | T18 | EHL65 | CTL26 | CTL22 | CTL MIDI | WCR1000 | D27-AS Plug-it | D36 UNI-RS | D36x7 | D50x2.5 | FS800 | FS800/2 | FS1080/2 | FS1400/2 (2x) | FS3000/2 | FSK250 | FSK420 | Gecko Dosh | Toolie | CE-SYS-2010 | RB-SYS CART (2x) | LEV1400 | LEV350 | SYS-MFT
PROTOOL:
Offline Bhend18
« Reply #22 on: February 02, 2014, 05:49 PM »
ps:  ;)
But probably NAINA.
Offline ART at WORK
« Reply #23 on: February 02, 2014, 06:19 PM »
Thanks thats a help I know where to look now. in the Piping department.
Offline Alex
« Reply #24 on: February 02, 2014, 06:53 PM »
But probably NAINA.
But I don't think Fein has the restrictive export policy Festool has. You'll probably be able to order one in Europe and have it send to America.
Offline Bhend18
« Reply #25 on: February 02, 2014, 08:43 PM »
But probably NAINA.
Will give that a try. Someone bump this thread when they're released.
Offline Brian Livingstone
« Reply #26 on: February 02, 2014, 08:56 PM »
Coincidentally I purchased a multimaster this morning.  I bought it to undercut door jambs for a few tile jobs I have on the go.  I have to say I am very impressed with the tool after its first day.
The package I bought has a canvas bag for storage.  I will have to get a new systainer to store it in.
Brian
Kapex, TS75, MFT, OF1010, OF2200, DTS400 REQ, Parallel guide rails, 800, 1080, 1400, 1900, 3000 guide rail, Domino 500, CT36, CT Midi, , RS2E, RO150, Boom Arm, Crown stops, 6 drawer Sortainer, Carvex, Syslite II, Festool safety glasses must start to wear.
Offline cnewport
« Reply #27 on: February 02, 2014, 09:19 PM »
Offline SRSemenza
« Reply #28 on: February 02, 2014, 10:38 PM »
I generally don't like having things stacked either. But the Multimaster isn't a tool I use a lot.  I put new/spare, and little used blades  in the bottom layer. In use blades in the top. So it is rare when I even need to go to the bottom layer.
Offline SRSemenza
« Reply #29 on: February 03, 2014, 12:17 PM »
Just a note on using the PVC cleaner on Systainers. Just wipe with a cloth dampened with the cleaner. Go easy, only use as much as needed. The cleaner is basically cleaning by dissolving a thin film of the plastic. If you start really going at it and scrubbing in circles you will get a swirly mess.
