Author Topic: Show your systainer  (Read 24524 times)
Offline Mortiser
Re: Show your systainer
« Reply #90 on: February 12, 2019, 09:35 PM »
Does someone know if the lids for the Sys-Storage Box will fit the Sys-Toolbox 2 ?
http://www.leevalley.com/us/Festool/page.aspx?p=70732&cat=5,105,71886
The clear lids? Not sure of the physical size would fit , it might,  I have both and can check when I go to the shop. But you would need to come up with some type of hinge / attachment even if they would fit. But that could be worth exploring for added versatility. Though if you really needed larger closed space , a regular Systainer can do that job.
It looks doable. But would take some work. A vertical slot needs to be cut in each corner (easy), Some sort of screw or rod added to mount the lid.  The center would still have quite a bit of open space under the handle. I did not take any measurements.
Thanks Seth for checking that. I would like to use the toolbox but have a lid to keep the dust (or most of it) out of my hand tools. I may give this a try.
Rich
Online SRSemenza
« Reply #91 on: February 12, 2019, 11:26 PM »
I didn't take any measurements and certainty of success is not guaranteed. If you try it post it!
Offline Billy stray
« Reply #92 on: February 15, 2019, 10:57 PM »
I like the blue tooth speaker, got any pics of inside ?
Billy
Offline joiner1970
« Reply #93 on: February 17, 2019, 02:49 AM »
Not my video but just got the link, that is another way to use systainer
"A little bit of rhythm makes Systainers go round"
https://www.instagram.com/p/BsTUu98FoKd/
Lol that's my fault that one. I know the Insane Dane and while chatting one day I said why didn't he attempt a full size systainer version of that micro sys tank that we had seen.
Being completely mad he loves a challenge and this was the resulting video.
Sadly he's not having a good start to 2019 as just the other week some scumbag broke into his van a stole a big chunk of his Festools :-(
Sent from my WAS-LX1A using Tapatalk
Offline Mario Turcot
« Reply #94 on: February 21, 2019, 09:09 PM »
Mike Farrington made a video about his used of systainers and I thought it might give people some ideas
Mario
Offline mickmick
« Reply #95 on: February 27, 2019, 09:23 AM »
thanks Mario - I found this vid helpful for putting my Senco pc1010 in a sys4.
“Pain and suffering are always inevitable for a large intelligence and a deep heart.”
― Fyodor Dostoyevsky, Crime and Punishment
Offline DashZero
« Reply #96 on: March 01, 2019, 02:21 AM »
Measuring in SYS-1
Offline DashZero
« Reply #97 on: March 01, 2019, 02:23 AM »
Laser in SYS-2
Offline DashZero
« Reply #98 on: March 01, 2019, 02:26 AM »
Grinder in SYS-3
Offline DashZero
« Reply #99 on: March 01, 2019, 02:27 AM »
Blower in SYS-2
Offline DashZero
« Reply #100 on: March 01, 2019, 02:32 AM »
Impact in SYS-2
Offline blaszcsj
« Reply #101 on: March 01, 2019, 12:35 PM »
Did you cut the foam out of the dewalt box? and it fit? I have this kit in the tough case. @DashZero
Laser in SYS-2
OF1010 EQ Router | MFT/3 | DF500Q | Carvex 420 | ETS EC 150/3 | CT 36 Auto Clean | TSC55 | LR32 | OF1400 EQ Router | ZOBO Metric Set | CXS Li 2.6 - 90 Limited Edition | Universal Cleaning Set | HKC55 | Centrotec CE-SORT | RO150 FEQ | DTS 400 | RO90 DX | CTSYS | C18 Drill | SysLite KALII | Syslite STL 450 | RAS 115 E | OF2200 EB
Offline DashZero
« Reply #102 on: March 01, 2019, 12:41 PM »
Yes i cut the Kaizen foam to fit it.  I still have the bulky hard case that came with it that doesn’t stack or store well.  I made the labels and printed them and laminated them.
Laser in SYS-2
Offline dwillis
« Reply #103 on: March 12, 2019, 12:15 PM »
Two sets of Wera nut drivers (metric and Imperial) on FastCap Kaizen foam bed. Blocks of Kaizen foam glued to the bed make up the dividers that hold the nut drivers in place.
« Last Edit: March 12, 2019, 12:21 PM by dwillis »
Remember that the only scientist to walk on the moon was a geologist.  Dr. Harrison Schmitt - Apollo 17 - Valley of Taurus-Littrow - 11 to 17 December 1972.
Offline DashZero
« Reply #104 on: March 12, 2019, 12:53 PM »
That look pretty cool.  Good idea gluing the dividers.
Offline harry_
« Reply #105 on: March 13, 2019, 09:17 PM »
My version of a `quick and dirty` SYS-air.
The first pic is just the unit with the lid open showing guns & hose. Usually there is a bottle of glue in there as well.
Second pic is a more unobstructed view. It also shows the `divit` where the hose and the power cord lead out with the ability to close the lid. That divit was due to a mishap on the jobsite which later proved to be fortunate.
The third pic shows the modification to the compressor to allow it to sit on its 4 feet. The modification was to remove about 1 to 1 1/2 inches of tubing from the frame. I can't remember for sure, but I think I also turned the motor 180 laterally on it's mounts so the starter capacitor would clear the tank. Unmodified is still fit in the systainer, but rather sloppily and as a result made the unit made a ton of noise.
This is just a 1 gallon Senco compressor i picked up at the cheapo-depot as my prior systainer version had blown it's reeds with replacements no longer available.
For those wondering:
Yes, I can and generally do, run this with the lid closed. Helps keep the crud out of the box and makes it quieter. It has only popped the thermal one time. My guy was running speed base on a 90 degree day with the lid closed. Nothing but nailing, everything had been pre-cut and dry fitted already. in a systainer or out of one, this little compressor was never intended to run a 15 gauge gun at that production level as it only 30% duty cycle if I remember correctly. He thought he burned it up but it was just the thermal breaker. He admitted that the unit hd not been keeping up with him. And yes, I/we have more appropriate compressors for that.
Offline Don T
  • Phoenix, Az
« Reply #106 on: March 16, 2019, 07:22 PM »
Here is my Milwaukee impact with battery,  charger, torque sticks, and sockets for wheel removal. This is going with me when we travel in the Fifth wheel during the summer.
294461-0
Offline UncleJoe
« Reply #107 on: March 18, 2019, 07:59 AM »
Here is my solution for my Sys Toolbox. This has worked pretty well for me. It may not be what you want but it may give someone some inspiration to help solve their tool storage issues. I use mine in the shop but have taken it to the job site a few times. I simply took an old bucket organizer I had from Home Depot, if I remember correctly, I think I paid about $7. I cut it apart and used pop rivets to attach it. I may have used a few small bolts (10-32) to reinforce it. I have inside loops for tools and a lot of pockets. It can be removed if I ever decide I don't like it or need it anymore but I have been using it for about 2 years and it is quite handy. I can move it to where I am working and have all my most used tools within easy reach.
I am not young enough to know everything!
Offline tallgrass
« Reply #108 on: March 21, 2019, 02:21 AM »
This is not a systainer post directly. I was modifying one of my systainers and I found this file underneath the plastic insert. Most likely from packing. Kind of neat for festool swag. The only thing I have gotten from Festool for free.  [big grin]
Offline mickmick
« Reply #109 on: March 22, 2019, 07:01 AM »
A toolbox. Warning - these things take bloody ages.
« Last Edit: March 22, 2019, 07:05 AM by mickmick »
Offline Joort
  • Small furniture projects.
« Reply #110 on: April 17, 2019, 05:20 AM »
Nice thread guys, Fingerlicking and very OCD friendly.
I made this insert for my beloved OF 1010.
Plywood and 4mm cork.
Fits snugly and secure.
The router is now laying correctly (rather than reversed).
Next time I will use thinner plywood.
For the rest I'm very happy.
Of course, this is 1% necessary and 99% fun.
Festool, Makita and Klemmsia
Offline Vondawg
« Reply #111 on: April 18, 2019, 09:10 AM »
Aw come on Joort you just want to show me your LED lights
How about a little show and tell....looks like you have an great idea under there.
Offline lubomisl
« Reply #112 on: May 09, 2019, 02:49 PM »
[ Specified attachment is not available ] [ Specified attachment is not available ] [ Specified attachment is not available ] :)
« Last Edit: May 12, 2019, 09:50 AM by lubomisl »
Offline Joort
« Reply #113 on: May 21, 2019, 05:24 PM »
Ok, here is the thread: http://festoolownersgroup.com/festool-jigs-tool-enhancements/best-value-for-money-jig-for-festool/
Offline ColossusX
« Reply #114 on: May 22, 2019, 10:31 AM »
My M12 systainer.
