Author Topic: Sys-toolbox pvc organizer  (Read 11326 times)
Offline Dbn107
« on: October 12, 2014, 07:31 PM »
            Long time lurker here.  Borrowed a friends ts75 about a year ago and my festool obsession has taken over since.  Besides my growing festool collection, I've been switching over many of my non festools into Systainers and it has worked out great.  One area that has always bothered me is my hand tools, which previously I've had in several different open top tool bags and have never been satisfied.  I'm mostly a finish carpenter (built-ins, crown, etc) but often have to tackle odd jobs and need quick access to my tools.  Anyway I picked up a couple of the sys-toolbox's but hadn't gotten around to creating dividers to effectively house my tools.  Decided today to work out a quick solution for one of the boxes and although I haven't used it in the field I think its going to work out well and was quick and cheap.
« Last Edit: October 13, 2014, 12:10 AM by SRSemenza »
Offline #Tee
Re: Sys-toolbox pvc organizer
« Reply #1 on: October 12, 2014, 07:39 PM »
great idea! i like it better than the plywood setup
When youre feeling depressed just treat yourself to a systainer even if its a mini systainer its ok.
IG: tee212
Offline Peter Halle
  • Moderator on a Slow Day
« Reply #2 on: October 12, 2014, 08:23 PM »
Great job!  I know that I've got some PVC pipe around here somewhere.
Offline overanalyze
« Reply #3 on: October 12, 2014, 08:23 PM »
I like it! Great idea! Thank you for posting it.
Offline wow
  • Inactive Member
« Reply #4 on: October 12, 2014, 11:19 PM »
Clever design!
I'm sure we could figure it out, but would you mind sharing what size pipe(s) you used?
Offline SRSemenza
« Reply #5 on: October 13, 2014, 12:14 AM »
      Nice idea!  [thumbs up]
Offline Dbn107
« Reply #6 on: October 13, 2014, 07:00 AM »
1", 2" and 3" pipe.  Which I could say it was planned but just happened to have some scrap around and test fit a few pieces till I had something that used the space well.
Offline Scott in Bend
« Reply #7 on: October 13, 2014, 01:13 PM »
Pretty darn cool and the cuts look to be perfectly square.  How did you cut them so straight?  Are the PVC tubes glued to themselves and is the bundle loose in the toolbox?
Offline Dbn107
« Reply #8 on: October 13, 2014, 05:31 PM »
I set up a stop and cut all of the pipe on the chop saw (haven't sprung for the Kapex yet, but its next up) with a fine tooth blade.  It cuts easily with a finish blade but the plastic "dust" is really annoying.  The pipes are all glued to each other and friction fit into the tool box.  Its a tight fit but I could remove it if needed.
Dan
Offline copcarcollector
« Reply #9 on: October 13, 2014, 05:46 PM »
Dan - That is cool, thanks for the idea! Sure beats everything tossed on top of each other, like mine is now---
Offline PreferrablyWood
« Reply #10 on: October 13, 2014, 09:57 PM »
I'm soon going to get a Sys tool box or two, this is a nifty idea, thanks for showing!
850 HL E Planer rustic head standard head angle fence, MFS 400x2, MFS extensions MFS VB 700 x 1 MFS VB 1000 x 2 . CMS GE, sliding fence, VB and 2x VL extension tables, OF 2200, Accessory Set ZS OF 2200 M,36mm 5m antistatik hose, CMS OF+ CMS TS 75 insert modules. SYS-MFT Fixing-Set,  3.5m sleeved hose, Syslite duo, Sys 4 sort 3 x3, Sys Roll, Sys 1 Box x2 , classic Sys 3-Sort 4, classic Sys 3 Sort 6 x2, Sys Cart x3 Systainer 4 x2  as toolbox with selfmade inserts Systainer 5 as toolbox with insert.
Festool 18V HKC 55 Li 5.2 EB Plus FSK 420,FSK 250, Extra blade for the HKC 55 W32.TI 15, CXS 2.6 Ah version, RO 90 DX, PDC 18/4 plus DC UNI FF depth stop chuck,AD 3/8 square socket holder FF chuck, Centrotec Bits; -->Bit holder and bit selection BHS 65 CE TL 24x, ,Bradpoint DB WOOD CE SET ,Zobo (Forstner) D 15-35 CE-Zobo SET ,Masonary/stone bits DB STONE CE Set,Extender BV 150 CE, Countersink QLS D2-8 CE Hook turner HD D18, end centrotec<--.  TS 75 EBQ, PSC 420, OF 1010, RS 300 EQ, CTL Midi, MFT 3, Parf dogs x2pair +Bench dogs x2pair, FS 1080, FS 1900 .  will get Domino DF 700 XL,  CMS insert BS 120 Belt sander.
Offline gbrunner77
« Reply #11 on: October 15, 2014, 02:47 PM »
Hi Dan,
I love the idea! Been on my "to do" list for a while now, what is the pipe you used for? I had a quick look in a local DIY store and all the pipe the had was really thin….
Many Thanks
Graham
Offline Davej
« Reply #12 on: October 15, 2014, 04:38 PM »
Hi Dan,
Many Thanks
Graham
Plumbers merchant for 1/4"  1/2"   2"   3"  abs pipe.  Electrical merchant for  20 mm conduit. I would think that should cover most of your needs.
Dave
I dont mind growing old but i refuse to grow up
Offline PA floor guy
« Reply #13 on: October 15, 2014, 04:50 PM »
Awesome job
Offline rst
« Reply #14 on: October 15, 2014, 08:17 PM »
Great post, you prompted me to finally switch my tools from the Bucket boss I've used for 15 years to the deep systainer toolbox.  It makes access and visibility much better.
Offline gbrunner77
« Reply #15 on: October 16, 2014, 03:10 PM »
Hi Dan,
Many Thanks
Graham
Dave
Thats great thanks!  [big grin] Much Appreciated
Offline Billy stray
« Reply #16 on: August 25, 2017, 09:07 PM »
Ive been searching for an idea like this for days and kept coming up with the same 2 images ,i really like this, its cheap and the best thing no wasted space 👍
Billy
Offline RDMuller
« Reply #17 on: August 25, 2017, 10:06 PM »
Great idea.  To cut PVC, use these ratchet scissors.  They are phenomenal, cut square, squeeze easily, and are cheap.   You can use them while standing on a ladder working with your arms above your head.  I have had some nasty plumbing adventures lately!  They come in various sizes.  They will also cut pex.    Sorry they don't do copper tubing!
https://www.menards.com/main/plumbing/rough-plumbing/pipe-tubing-hoses-fittings-accessories/plumbing-tools/plumbing-hand-tools/pipe-cutters-pipe-shears-parts/superior-tool-reg-2-1-2-o-d-pvc-ratcheting-cutter/p-1444444236892-c-8610.htm?tid=3293091250715416162&ipos=1&bargainStoreId=3083
Offline tazprime38
« Reply #18 on: August 29, 2017, 08:59 PM »
I done this a few years back and did post some pics. It wasn't  my thread.
I did this to a CK tool tote bag using 42mm and 32mm waste pipe mainly. Recently I bought the Vaughn tool tote bix that is part of a similar toolbox system to systainers only slightly larger, which I like.
For this I used standard square downpipe and round wastepipe. For tools with thin shafts I used plastic 15mm pipe.  It works really well untill you start throwing extra tools ontop.
I will be redoing my CK tote bag with the square downpipe as much easier to fit various size tools and no space is wasted.
Anther thing I will be doing is to cap off the base if the pipes so if I filled one up with small parts for example plumbing bits, I can simply slide the pipe 'container' in and out of the tote as needed.
Will post pictures later.
@Dbn 107
I tried cutting  the square pipe with the evolution mitre saw , only to shatter the pipe. So done them by hand and then ran a deburrer around the cuts.
With my toe box on its system roller it is very easy to move about too.
Offline Naildrivingman
« Reply #19 on: August 30, 2017, 05:34 AM »
A much better use of pvc than what I attempted a while ago.  I thought that lining my golf bag with pvc pipe would be a good idea to guide the club shafts back into the bag.  It worked so long as I was riding in a cart, then didn't when I had to walk the course!  A little on the heavy side....
Dance with who brung ya...
Offline BJM9818
« Reply #20 on: August 30, 2017, 07:40 AM »
OP great idea
Naildriver try this. They have been around for years.
https://www.amazon.com/Player-Supreme-Golf-Tubes-Dividers/dp/B01M35G3SS
Offline tazprime38
« Reply #22 on: August 30, 2017, 12:39 PM »
For those that don't use facebook here is my tote oganiser.
This is a vaunt tote set on a trolley of the same system but badged and sold under Dakota name by Rutlands.
I have plastic pipe glued together for small tools and square downpipe for larger tools. I have onle welded the downpipe in pairs but probably weld either the rows together or in fours so they don't wobble about.
I have used the waste pipe solution in a CK tote (same as Magma tote) for many years.
Every tool just stands in its own place and can be found and placed back easily.
The Vaunt and Dakota systainer type toolboxes are bigger than tanos systainers and the tote is a fantastic size compared to the tanos or makita tote. With the wheeled dolly its brilliant. I have a bucket tool organiser which I may adapt so it can be attached to this tote but with the option of removing via maybe velcro.
