Author Topic: Upgrading the Sys-Roll  (Read 4626 times)
Offline Willy668
« on: February 24, 2018, 02:33 AM »
Because I work mostly on rough building sites, I was not so happy with the rock hard wheels on the sys-roll. The systainers are bumping all around, and the slightest rock or piece of wood will stop the wheels completely.
The other day I put the sys-roll on a handtruck to move everything to another room in the building, and this was a huge improvement. So i've put rubber wheels, with air, on the sys-roll and it works great!
With very little work, replace the axel with a wider one, and nothing even has to be changed on the sys-roll itself. Like it's ment to be replaced.
Thought I'd share it with you guys.
Offline TinyShop
Re: Upgrading the Sys-Roll
« Reply #1 on: February 24, 2018, 02:55 AM »
Nice work! Are you able to provide a parts list so as to assist others who may want to adopt your great mod idea?
Offline PeterK
« Reply #2 on: February 24, 2018, 09:07 AM »
Really excellent upgrade idea!
Yes please list materials and sources if you can.
Offline Peter Halle
« Reply #3 on: February 24, 2018, 09:18 AM »
Great idea.  Adding larger wheels on the rear would cause the SYS-Roll to lean forward.  Has that caused any issues for you?
Offline Willy668
« Reply #4 on: February 24, 2018, 10:15 AM »
That's correct, sharp  ;D
At this point it's leaning a little bit forward. So I ordered bigger front wheels which have the same mounting points to I can replace them easily.
I will write down all the parts which I had to get to get the Sys-roll updated. Will do that shortly.
Offline SRSemenza
« Reply #5 on: February 24, 2018, 11:02 AM »
The off road Sys-Roll!   Especially nice since it is easy to do.   [thumbs up]
Online pettyconstruction
« Reply #6 on: February 24, 2018, 11:27 AM »
How bout putting a shim between the wheel and the base?
I like the changes,Charlie
Sent from my iPhone using Tapatalk Pro
Offline live4ever
« Reply #7 on: February 24, 2018, 12:30 PM »
I was JUST looking into how to do this last night!
Offline Mark Enomoto
« Reply #8 on: March 03, 2018, 02:25 AM »
Cool... I just posted a new message about the Rotatruck stair climbing handtrucks... they are pricey! https://www.rotacaster.com.au/shop-product/rotatruck-lite/stair-climber-lite
Offline neilc
« Reply #9 on: March 03, 2018, 10:40 AM »
The back table and legs are also interesting!  Can you show more details?
Offline ben_r_
« Reply #10 on: March 05, 2018, 01:37 PM »
Ha! Thats an awesome idea! Great job!
