Author Topic: Where is the info about printing labels for the "T - Loc"  (Read 70763 times)
Offline Steve R
« on: August 18, 2012, 10:41 AM »
I'm wondering where to find the file? info for printing labels for the "T". I would think this would be a sticky.
Cheers,
Steve
Offline Peter Halle
« Reply #1 on: August 18, 2012, 10:53 AM »
Cheers,
Steve
Here is the link: Festool  labels
<<Edit:  This topic is now a sticky - P.Halle>>
« Last Edit: October 11, 2013, 10:19 AM by SRSemenza »
Offline Steve R
« Reply #2 on: August 18, 2012, 11:21 AM »
Thanks, Peter.
I would ask.... besides asking this question. How would if find that link from the main Festool USA site? Don't get me wrong I like being able as just ask and have you tell me... but I'm a bit old school and would like to have found it myself.  [wink]
From what I'm finding this is to print one..... label on one full sheet of paper?!  Really waste that much paper to get just one label!
From looking at print setting suggestions...seems that the label is 3.6 x 2.4 inch... if that is correct then I can create my own file to print from that is much more adjustable than the PDF file you point to and can print several on one sheet of paper.
Is 3.6 x 2.4 inch the correct size?
Cheers,
Steve
« Last Edit: August 18, 2012, 12:13 PM by Steve R »
Offline john ferri
« Reply #3 on: October 22, 2012, 06:49 PM »
Found the step by step instructions and info on the website. I cannot seem to upload a PDF or JPG to the logo area. If I click on this area, it does not prompt me to add a file. Could this be a platform issue (I have a Mac Book Pro--although I'm obviously not a pro).
JF
Offline Peter Halle
« Reply #4 on: October 22, 2012, 07:15 PM »
I just tried it on my MacBook Pro and was able to do .jpg and .png formats by clicking on the logo area.
Offline Sometimewoodworker
    • Jerome's  Other work
« Reply #5 on: October 23, 2012, 01:26 AM »
JF
It's probably the program you are using to open the PDF.
FWIW I use Macs all the time.
Jerome
TS55, OF1400, Elu MOF96, Rotex150, DTS400, ETS150/3 Domino, MFK700, CXS, HL 850, Trend T11, Makita LS1212, Original Mini CV06 Cyclone, Workshop supplies drum sander, & WoodRat. Don't have don't want list: MFT
http://www.flickr.com/photos/nui-jerome/
Offline john ferri
« Reply #6 on: October 23, 2012, 10:05 AM »
I'm using preview to open the "blanko" file and trying to load a jpg. When I click on the logo area the space simply blinks. Drag and drop did not work. I also used "tab" to toggle between areas. Would love to solve this, maybe I need a preview update.
Thanks for the input.
JF
Offline Peter Halle
« Reply #7 on: October 23, 2012, 10:12 AM »
You need to open with Adobe Acrobat Reader.  See 1. on that page.
Offline woodie
« Reply #8 on: October 23, 2012, 04:44 PM »
Thanks for making this a sticky Peter! Finally motivated me to make labels for my MultiMaster and Hilti Impact. The "logo" window on the generic label does some funky resizing, nothing a little photo shop can't remedy though  [big grin].
Green - MFT/3, FS 1080/2, FS 1400/2-LR32, FS 1900/2, FS 3000/2, Parallel Guide Set, CT 26E, CT MIDI, OF1400 EQ, LR32 Drilling Set, MFS 400 Set, MFS 700 Set, Domino DF700 Set, Domino DF500Q Set, C12 NiMH Set, T18+3 Set, 2011 Centrotec Set, RO150 FEQ, RTS400 EQ, LS130 EQ, Planex LHS225, and various accessories
Red - KSS80 EC/370, MT55cc, P1cc, F160, F110 and Aerofix Guide Rails.
Offline john ferri
« Reply #9 on: October 25, 2012, 02:18 PM »
Updated to Adobe 9, started from scratch, worked perfectly--my systainer with ECE planes now has a lovely customized label. Life sure is grand.
Thanks Peter et al.
JF
Offline vkumar
« Reply #10 on: November 12, 2012, 11:31 AM »
Peter,
Can you please recommend the appropriate paper (and sources)  to print these labels on? I know you have  tons of experience in printing labels from 2 years ago ;)  I assume that this stock already has the right (long lasting) adhesive on it.
Vijay
Vijay Kumar
Offline Peter Halle
« Reply #11 on: November 12, 2012, 12:13 PM »
I'll look when I get home.  I'm assuming you looking so something for the T-loc version?
Offline vkumar
« Reply #12 on: November 12, 2012, 01:13 PM »
Yes for T Locs, although media should be the same for any Systainer right?
Vijay
Vijay Kumar
Offline Peter Halle
« Reply #13 on: November 12, 2012, 07:02 PM »
The labels that I have printed for my Systainers and also for "My Piggies" have held up well and stay stuck in my experience.
If you go to onlinelabels.com you can choose the media type.  My labels are the weatherproof poly laser.  Frankly printing weatherproof on an inkjet is silly.  The label will stay stuck but the ink will run.  But, that is also an option.  For classic systainers I used the OL8250LP which is 8 labels per page and did my layouts in Adobe Illustrator.
The Festool program for the T-Locs does a label image that is 3 3/8" x 2 1/8".  The issue is that you can't really move it around to meet a label template location, so you would have to order full sheet labels and then cut them out.  Lots of waste.
That size is pretty close to a business card and the new T-Locs have a recessed place that allows you to buy a plastic cover and just slip plain paper behind it - like Brice said.
If you want to go the label route I would suggest that you try out printing a test label on paper and then run it thru again and again and again trying the various positioning options available thru Adobe Acrobat Reader.  I think that it is conceivable that you could print between two and 5 per page if you re run your paper thru the printer.
If you order from the link above you can order as little as one sheet but the cost is pretty out there versus purchasing in a slightly greater amount, so check that out.
Sorry I couldn't help more.  I would play around with some stuff but my plate is full and I would have to get permissions etc.
Offline vkumar
« Reply #14 on: November 12, 2012, 07:30 PM »
Peter thanks for the details.  I will do some experimentation.
Vijay
Vijay Kumar
Offline lujin
« Reply #15 on: August 08, 2013, 02:15 PM »
Cheers,
Steve
Here is the link:  Go Here to Print Custom Labels for T-Loc's
This link takes me to the Festool USA main page.  Where do I go from here?
Thanks, Jim
Offline fdengel
« Reply #16 on: August 08, 2013, 02:55 PM »
I've been cutting mine from an index card.
I kind of line it up and cut it just a bit too large then gradually trim it down until it fits to my satisfaction.
Obviously this is only useful if you have good handwriting...
Offline Peter Halle
« Reply #17 on: August 08, 2013, 07:26 PM »
Festool (not Festool USA) has made some changes to their website to direct viewers to the correct country.  Unfortunately lots of links will no longer work for those in countries rying to go the the Festool website in another country.
Here is a link to the T-Loc label printing program that will work:  http://www.festool.co.uk/Service/T-LOC-custom-labels/Pages/Create-your-label.aspx
Offline mike68au
« Reply #18 on: August 08, 2013, 07:52 PM »
Thanks Peter.... I was trying to find it again myself and kept getting re-directed to the US site.
Offline lujin
« Reply #19 on: August 09, 2013, 08:17 AM »
[/quote
Thank you Peter, much appreciatred.
Jim
Offline gkaiseril
« Reply #20 on: November 15, 2013, 11:01 AM »
JF
Please do not use the "Preview" on the Macs. It does not properly handle PDF forms and corrupts the form so it might not display or print the added images or text on another system.
If one downloads the latest version of Reader, XI, you will be able to save your custom made label.
These labels were created using Adobe's LiveCycle form creation product and will not work on non-computer devices like the iPad, android tablets, or other mobile devices.
The labels are set for printing on A4 size paper and not U.S. letter size so the label will be slightly smaller because the A4 page size is being shrunk to fit letter size. You could cut a little larger to fit the slot or use the protective cover. If one does not use the auto rotate and center the label will print in the upper left hand corner so one only needs to cut the right side and bottom.
« Last Edit: November 15, 2013, 11:48 AM by gkaiseril »
George Kaiser
TS 55 REQ, RO 90, RO 150, CT 26, PSB 420, MFT/3
Offline NL-mikkla
  • www.m144h.com
« Reply #21 on: February 20, 2014, 04:39 AM »
Just found out that there is standard already a plastic label cover in the tloc systainers.
On the left side is a blank slot, for custom labels I pressume, and there is already one plastic cover placed in.
Funny, have these things for quite a while now but never noticed.
Offline gkaiseril
« Reply #22 on: August 16, 2014, 09:08 PM »
Yes they have come with one for a long time. You can also purchase more if you feel you need to cover the insert holders.
George Kaiser
Offline dainfo
« Reply #23 on: July 11, 2017, 08:14 PM »
Hi!
Do any of you have the sizes for a label on the t-loc lock?
I want to make labels with the logo of my company..
 [thumbs up]
Cheers
Offline Gregor
« Reply #24 on: July 12, 2017, 02:20 AM »
Hi!
 [thumbs up]
Cheers
Standard credit card size.
« Reply #25 on: July 12, 2017, 11:26 AM »
3 3/8" x 2 1/8"
Offline live4ever
« Reply #26 on: July 12, 2017, 12:34 PM »
@Gregor @Cheese @dainfo
I believe he was asking about labeling the actual T (the green lock).
Offline Gregor
« Reply #27 on: July 12, 2017, 03:44 PM »
Sorry.
« Reply #28 on: July 13, 2017, 11:39 AM »
Whoops... [doh]
Offline DashZero
Re: Where is the info about printing labels for the "T - Loc"
« Reply #29 on: April 30, 2019, 07:10 PM »
I will see about making a custom label drawing for it. ill add it to http://festoolownersgroup.com/festool-and-tanos-systainers/custom-label-pdf-for-everyone/
Hi!
 [thumbs up]
Cheers
