Author Topic: wire systainer  (Read 2418 times)
Offline bror
    • diafer.nl
wire systainer
« on: November 17, 2017, 06:26 PM »
In the Netherlands electrical wire is usually sold in cardboard boxes. They contain 100 meter of copper wire (2.5 mm).
The wire is pulled out from the middle. It always curls up and gets tangled. It is rather a hassle to get the excess wire back in the box.
when we use 5 wires at the same time it usually gets very messy. Don't like em.
I have been looking for wire dispensers on the internet and did not find any I like. Because most of my tools are in systainers I would prefer a wire dispenser in a systainer. Couldn't find it on the FOG either.
I tried to make one myself:
Thanks for watching
Rogier
« Last Edit: November 17, 2017, 07:01 PM by bror »
Offline Bob D.
Re: wire systainer
« Reply #1 on: November 17, 2017, 10:09 PM »
I'd say you did more than try, you did it!
And a nice job too. Thanks for sharing your solution.
Offline aloysius
Re: wire systainer
« Reply #2 on: November 17, 2017, 10:28 PM »
A lovely, neat solution to a totally unnecessary problem.  With the exception of Comms cable (which is dispensed in the same manner as yours) all our local power cables are dispensed from plastic spools.  Using a corresponding plastic crate prevents all those annoying "twisties".
What about your heavier cables:  SDIs, twin actives, twin & earth 4mm, 6mm, 10mm square etc?  Surely they aren't centre-dispensed as well?  That'd be a nightmare!
« Last Edit: November 18, 2017, 07:13 AM by aloysius »
FOG-wit since '95:  Some say since birth...
Offline SRSemenza
Re: wire systainer
« Reply #3 on: November 17, 2017, 11:53 PM »
Nice. I like the way the reels come apart to quickly transfer a new coil onto them.
Offline antss
Re: wire systainer
« Reply #4 on: November 18, 2017, 11:11 AM »
Seth , I think your collection needs one of those.
Offline Bert Vanderveen
Re: wire systainer
« Reply #5 on: November 18, 2017, 11:43 AM »
In the Low Countries cabling with wires covers 90% of all uses. It is required to go through conduits (pvc and abs mostly). Other types are mostly 'selfcontained', eg for linking circuit boxes you'd use 5-core (or more) cable. The rolls these come in are impractical to store in a systainer.
The boxes shown have a feature that should help dispersing without hassle: the central hole in the cutout — you are supposed to thread the start of the wire through this. The OT probably dislikes doing that as much as I do.
Cheers, Bert Vanderveen
TS55 · TS55R · OF1010 · DF500 Mk2 · MFT/3 + VL + CMS TS55 + CMS PS300 + LA-CS 70/CMS · CTL Midi · RTS400 EQ · 2 x CXS Li 1,5 · T15+3 Li 4,2 · TI15 Impact Li 4,2 · Centrotec Sets 2008 + 2015 · PSB300 · LR32-SYS · RO150 · Kapex KS120 · 2 x MFK700 · RO90 · OFK700 · BS75 · OFK500 · OF2200 · CMS-GE … | Mirka 1230L P&C | Hammer A3 31 Silent Power · Hammer N4400
Offline Coen
Re: wire systainer
« Reply #6 on: December 03, 2017, 08:20 PM »
Nice!
But with 5-wires I was thinking of the cabling for a 2xL, 2xN cooking outlet (Perilex). Then you would need 2x Brown, 2x Blue, 1x Green/Yellow. You replace the two black rolls for that?
