Pages: 1 [2] 3  All   Go Down
  Print
Author Topic: "Chaos Theory" new How To Video from Guido Henn on Festool.de  (Read 34511 times)
GPowers
Offline Offline
Metric convert
WWW
« Reply #30 on: May 23, 2011, 12:43 PM »
In the beginning of the third video he is setting up the Domino, where it looks like he changes the Domino width setting, to the middle setting , WITH OUT THE DOMINO being turned on. I was told in the cabinet class that changing the width setting, with the Domino OFF, is a big no-no. As it can mess up the gears and should only be done when the Domino is ON?
Other then that I wish I has seen this video a year ago when I built my DIY Sysport.
Greg Powers
Brice Burrell
Online Online
Remodeling Contractor
WWW
« Reply #31 on: May 23, 2011, 01:20 PM »
You're right, the width should be changed with the Domino on.  However, you won't do damage as long as you don't force knob when the tool turned off.
Festoolfootstool
Offline Offline
The trouble with Bob is its all about Bob
« Reply #32 on: May 23, 2011, 04:36 PM »
All very basic stuff but interesting never-the-less. did anyone notice the domino was the earlier pin type
If the milk turns out to be sour, I ain't the kind of **** to drink it.......
Why do Festool accessories only have a two month guarantee here in the UK ?
woodguy7
Offline Offline
« Reply #33 on: May 23, 2011, 04:42 PM »
Thats because the mans got taste  Grin
Shirt size medium
fshanno
Offline Offline
« Reply #34 on: May 23, 2011, 08:28 PM »
In No. 3 the guy changes the mortise width with the motor off.
Ken Nagrod
Restricted
Offline Offline
« Reply #35 on: May 23, 2011, 08:32 PM »
It's all about the gear teeth meshing without forcing them.
Guido
Offline Offline
« Reply #36 on: May 24, 2011, 07:08 AM »
You are all right and also the manual says that you should change width while running the machine. But like Brice and Ken mentioned if you dont force the knob (sometimes !!!) you could also do it with the motor off - but it doesnt work always!!!
In such a video for the enduser I should have done it like it is in the manual not to confuse someone - next time I will do better ...  Wink
But also the professionals at Festool sometimes turn the knob (if possible) without running the machine, as you can see in this video at "Festool TV": He first turn of the motor and then change the width-knob:    http://www.festool.de/Service/tv/Ausgabe1Domino/Seiten/Domino-TV.aspx
Guido
woodguy7
Offline Offline
« Reply #37 on: May 24, 2011, 09:29 AM »
Well, i quite often turn the knob when the machine is off.  If there is any resistance at all then i click it on.  Like others said, as long as you don't force it !!!
Shirt size medium
Jay123
Offline Offline
WWW
« Reply #38 on: May 24, 2011, 08:37 PM »
Just got done watching all four videos Guido, great job!  I actually like the music too.
Jay
Festoller
Offline Offline
« Reply #39 on: June 03, 2011, 12:15 PM »
I have a question about the holes for Hettich Excenter fixing. Guido had that DIY jig for the two holes (10mm and 20mm) which he uses with two routers.
I am looking for the easiest way (except buying the 200 EUR Hettich Drill-Jig) to drill those two holes and was thinking if the MFS might be helpfull for this task.
My initial idea was to use a similar jig for the 10mm hole with a drill and forstner bit and the OF1010 with side stop, but when I saw the MFS 400 today I thought it might be usefull for this and other projects and even be more accurate since those Excenter fixings are not forgiving like the Euro Hinge.
Any idea how to improve the drilling process
The fact that we live at the bottom of a deep gravity well, on the surface of a gas covered planet going around a nuclear fireball 90 million miles away and think this to be normal is obviously some indication of how skewed our perspective tends to be. -Douglas Adams-
Tim Raleigh
Offline Offline
WWW
« Reply #40 on: June 03, 2011, 01:22 PM »
I think Guido's methodology is the best hands down. You get the right depth, the holes are perfectly centered and the proper depth and if you are using Festool routers, perfectly clean.
I use these fasteners (with a Hafele jig and drill) and they can be finicky.
The 10mm hole must be drilled precisely (vertically and horizontally) or when you install the connector it will pull the 20mm section of the connector forward which results in the connector not sitting flush with the surface of the substrate weakening the joint.
It is easier and faster to use a rafix-SE (or similar Hettich or Blum) type fitting. It's only one 20mm hole, it holds as well and I think the only risk is in the Rafix fitting turning in the 20mm hole (if bored too wide) during installation, which would make it difficult to line up the pin.
Hope this helps.
Tim
Festoolfootstool
Offline Offline
« Reply #41 on: June 03, 2011, 01:22 PM »
Hi I think the easiest and cheapest away to compete the task is the way it was done in the video.this was not a diy jig but a user made jig you could make the same thing using a piece of phenolic if you wanted something more attractive
I do not own the mfs 400 but i see there is some sort of guide you can attach to the rails you would need two of them and you would still need two machines.
and i'm not sure if you could get the hole centres close enough together.
so why not just use a .50 cent piece of ply or mdf for the jig that way you can use it over and over.
FestoolMike
Offline Offline
« Reply #42 on: June 20, 2011, 09:41 AM »
When the last two parts of the video are on air, there will be next a version with the fully video (about 33 min - without breaks). I will ask festool that we make this version with an english voice over. I think its better than subtitels - you should concentrate on the tools not on reading  Wink
Guido
Guido,  outside the article, could you share the overall dimensions of one of the boxes (LxHxW)?  Would lie to build a set this weekend.
Thanks, in advance
Mike
Guido
Offline Offline
« Reply #43 on: June 20, 2011, 01:42 PM »
Mike, no problem, please visit my Website "hobbywood.de" and click "kontakt" and "email senden" to give me your email-adress and I will help you.
Regards
Guido
Festoller
Offline Offline
« Reply #44 on: July 19, 2011, 09:15 AM »
Guido:
Is the article/ plan (dimensions) already available? I couldn't find a new Holzidee, the last one is from June 2010.
Rolf
Offline Offline
« Reply #45 on: July 26, 2011, 11:40 AM »
Guido,
Your elegant solution to this universal storage problem is very useful because it can easily be scaled to fit one 's requirements of available space, or systainer (or other container) dimensions, or material sizes that are available, etc. The video flows well and shows the sequence and some details.
How did you position the hole for the threaded steel dowels that connect the bottoms and tops to be 9.5mm (assuming 19mm thick material) from the panel ends? - template? jig? LR32?
What do some other members use?
thanks
Alan m
Online Online
« Reply #46 on: July 26, 2011, 01:19 PM »
 Welcome! to the fog.
now
wish list
pugilato
Offline Offline
« Reply #47 on: July 26, 2011, 03:33 PM »
I think that if I were ever to go to Europe, I would hit the Festool store and get stuff that you cannot get here and ship it over.  I love that table saw where the saw moves and the wood is stationary.  And that clamp for corners...
Festoller
Offline Offline
« Reply #48 on: July 27, 2011, 03:31 AM »
Here's the "Holzidee" (pdf) download including plan and dimensions from Festool Germany (it's metric and in German):
http://www.festool.de/Aktionen/Festool-fuer-Heimwerker/Holzidee-Heimwerken/Seiten/Holzidee-Magazin-Ausgaben.aspx
click on Download Holzidee 11, it starts at page 46.
mattfc
Offline Offline
« Reply #49 on: July 27, 2011, 06:17 AM »
Yes they are well worth reading through.. lots of pictures and plans for load of ideas, pretty easy to follow, also some good jig ideas for CMS etc, plus so good explanations on topics like finishing
here are some screenshots from the PDFs to give you all a taster, sysports, workshop storage plus lots more!
FestoolMike
Offline Offline
« Reply #50 on: July 31, 2011, 10:00 PM »
That large clamp cart is rockin'...  I would love to build something like that.  I only with the sheet goods were not as expensive and better quality.  But that excites me... I may need to leave the forums for a moment.  Scared
FestoolMike
Offline Offline
« Reply #51 on: July 31, 2011, 10:09 PM »
One more thing.  I wanted to give a shout out to Guido.  He has been very helpful at patient with the euro 32 system noob (me).
As I was shooting Guido messages as the different phases occur, this time I thought I would see what the group thinks.
This didn't occur to me as I learned to construct face frame cabs, the hinge placement is not supremely critical in the sense where the hinge attached to the frame.  Now with the euro style you must be able to figure out where to bore the hole in the door as it relates to the hole series inside the cabinet.
Guido in the video uses some sort of plastic piece that snaps into the case holes and the door is then slid under the other side and aligned.  A pencil mark is transferred from the jig and locates the hinge cup in the door.
Does anyone know where I can find such a inexpensive piece of plastic??   Huh?
Thanks to everyone and especially you Guido.  Thanks
Mike
« Last Edit: July 31, 2011, 10:10 PM by FestoolMike » Logged
Rolf
Offline Offline
« Reply #52 on: August 29, 2011, 06:40 PM »
The piece of plastic is the Hettich MultiBlue location marking template.
You can find it on German ebay.
GreenGA
Offline Offline
JR
« Reply #53 on: August 29, 2011, 06:57 PM »
Does anyone have a yearly account with Adobe for converting PDF to Word documents online? I know there are a few FOG'ers that speak German but I know that I do not.  Nor do I know the binary language of moisture evaporators , but I would really like to read those PDF files on the German Festool site.
I am not certain if Festool Corporate would be concerned.  If so, never mind...  Huh?!
Ahhh...
I forgot to add that once converted to Word docs, they could then be run through the Google universal translator.  It would not be perfect, but that would be, I believe, easier than attempting to read German.  Yes, the pictures are pretty and pretty informative, but.
« Last Edit: August 29, 2011, 07:00 PM by GreenGA » Logged
Never use a 2x4 when a 2x6 will do just as well
SYS-Lite, CMS/GE, TS55, KAPEX, MFT/3, CXS Kit, C15 Set, TI 15 Set, C12 Set, CT48 w/Boom Arm, HL850, RO90, RTS400, DTS400, LS130, DX93, RO150, ETS 150/3, RAS 115/4E, RS2E, Domino Classic, OF1010 EQ, OF2000E+, OF1400, MFS700, LR 32-SYS+97" rail, 2011 Centrotec, Zobo Forstner Bit Set, Guide Rail Kit, Parallel Guides, Tradesman Cleaning Set, Shinex, lotsa 'tainers (Sorts, Attics, Classic, New and Blue).
Coming Attractions: MFK700 Kit, Workcenter, Domino XL Kit, Carvex 420 & Accessory Kit
Rolf
Offline Offline
« Reply #54 on: August 30, 2011, 08:57 AM »
Standard Adobe Acrobat (not Reader) can save PDF documents in a number of formats, e.g. HTML, JPEGs, etc ... including MS Word. (I use a Mac).
Which part of the document are you interested in? perhaps I can help.
Limey556
Offline Offline
« Reply #55 on: September 27, 2011, 03:35 PM »
 Blink
Does anyone know where to purchase  the Hettich knockdown connectors  seen in the Guido movie ?
Roll Eyes
richard.selwyn
Offline Offline
Normandy, France
« Reply #56 on: September 27, 2011, 04:34 PM »
No, but I think you should look at Lamello clamex system. I know they're not cheap and the best ones need a special tool, ( but the basi ones can be used with a biscuit jointer with a special blade) but to me they seem to do the same as the hettich only better. I bought the zeta machine and really like it in spite of the festoolish price.
Regards
Richard
Tim Raleigh
Offline Offline
WWW
« Reply #57 on: September 27, 2011, 06:38 PM »
Blink
Roll Eyes
Custom service Hardware Catalog Page 90
Tim
Limey556
Offline Offline
« Reply #58 on: September 27, 2011, 07:30 PM »
Thanks for the reply Tim I don't supose you know where they seel the jig or better yet the dimensions to make the Jig that Guido used? Huh?
Tim Raleigh
Offline Offline
WWW
« Reply #59 on: September 28, 2011, 10:17 AM »
Hafele sells them but they are expensive and you may need to provide proof (letterhead, business card etc.) that you are in the business.
Search for Rafix jig on Google.
I think the jig that Guido uses is the best solution for occasional use and unless you have experience (practice) it's more accurate than the Hafele jig.
I would just buy the connectors and build your own jig through trial and error. The video gives you a fair amount of clues as to what is required. If you look at the RafixHafele documentation it will show you that you need a 10mm, 20mm and 5 mm bits for these connectors. The Hafele site has downloadable catalogs that give a little more detail on additional connectors and assembly.
Unless you need the flexibility to move or break down your cabinet frequently or need to mass produce panels on a CNC to modular system (32mm) for easy configuration, shipping and assembly on site, ready to assemble fittings (RTA) such as these don't really make much sense. Also, you do need to make extremely accurate cuts (dimensionally and square) for this system, or the connectors may not work properly.
These fittings create very good (butt) joints but like Richard said above the Lamello clamex system will be easier to use if not a little more pricey. By the time you bought the Hafele jig and figured out how to use it, you could probably assemble your whole cabinet with the Lamello tool.
For occasional use assembling a cabinet box with biscuits, dadoes, screws and glue is cheaper faster, just as strong (or stronger) as using these types of connectors. There is a brilliant DVD by Frank Klaus called biscuit joinery showing how to build bookcase using knock down hardware among other things.
Tim
Pages: 1 [2] 3  All   Go Up
  Print
Jump to:
