Dovetail65
Offline
« Reply #60 on: September 28, 2011, 10:38 AM » |
Festoller
Offline
« Reply #61 on: September 28, 2011, 11:59 AM » |
Limey556: you need the Hettich Drilljig VB. I have long searched for the best and cheapest way to drill those Hettich VB Fittings and I think this is the best choice. http://web2.hettich.com/hbh/Start.do?localeId=EN&itemId=20166unfortunately I couldn't find a dealer for the Drilljig VB, but Woodstocksupply offers the one for Euro Hinges for $187 and the VB is usually the same price: http://www.woodstocksupply.com/hinge-drilling-jig-47303-hettich.htmlMaybe they can help? I have just used it to build a "Guido" closet and it was much easier than using two routers with two bits as Guido did. If you need to buy the 20 and 10 mm router bit and the rest of the equipment you probably still have to add a liitle bit more cash for the Drilljig (should be $180 or so), but if you don't have two routers anyway, the Drilljig will be much more convenient. It is also adjustable for the different sizes of the Hettich VB Fittings. Be sure to get the proper VB fitting for the thickness you're working with. For any kind of built in I would recommend this fitting, since it was very fast and easy to assemble and the whole closet seems extremely rigid.
The fact that we live at the bottom of a deep gravity well, on the surface of a gas covered planet going around a nuclear fireball 90 million miles away and think this to be normal is obviously some indication of how skewed our perspective tends to be. -Douglas Adams-
Festoller
Offline
« Reply #62 on: September 28, 2011, 12:41 PM » |
Limey556: I forgot, here's the plan for building the Guido VB Jig. It's from Holzidee 11 and in German as well as metric (mm), but I guess all you need is the dimensions. Hettich VB Jig.pdf (96.81 KB - downloaded 2068 times.)
Tim Raleigh
Online
« Reply #63 on: September 29, 2011, 11:39 AM » |
Festoller: Great info, and thanks for the link to Wood stock supply. Tim
Limey556
Offline
« Reply #64 on: September 29, 2011, 01:50 PM » |
Tim / Festoller Thanks for all the feedback great information as always from the FOG members.
I am not a full time professional at this mostly upgrading buildings I own. If I can't find the Hettich Jig I will build the Guido type one from the plans in the link provided. I am in the process of retrofitting a building with all built-ins to maximize space. I love the simplicity of the Hettich knock-down fittings and after watching Guido assembling them on-site I'm completely sold on this method of cabinet construction.
It will probably take a few attempts and different methods but I will work at it until I have a repeatable system or methodology down pat. I am considering the Festool LR 32 system along with the 1400 router for all of the other system holes any thoughts on that ?
Terry
Tim Raleigh
Online
« Reply #65 on: September 29, 2011, 02:54 PM » |
Terry: I know that Wood stock supply has the Hettich DrillJjib VB so you should be able to get it there. Hopefully I didn't buy the last one. I am a big fan of the LR32 system, and it's really why I started using Festool in the first place. It works flawlessly. I don't have the 1400 (plan on buying one) so I can't comment on that, but I love the 1010. It's light, and easy to manage reaching across a wide board. Obviously the best way to use it is to keep to 32mm increments in your sizes but I have used imperial measurement and as long as you mark the rail for the proper hole alignment you are good to go. There are some great tutorials here on FOG. I can't remember if the Guido builds a back on his cabinets or not and the video isn't working for me. The closet inserts that I have built hang on a cabinet suspension system which you might also want to look into depending on your approach.
pugilato
Offline
« Reply #66 on: September 29, 2011, 04:17 PM » |
Yes, the Guido cabinets had backs on them.
junk
Offline
« Reply #67 on: September 29, 2011, 06:00 PM » |
Tim
That Hettich VB Drill Jig is $380.00 CDN from Robert Bury Supply, they have one in Canada, I think the guy I talked said it was in Montreal.
John
Tim Raleigh
Online
« Reply #68 on: September 30, 2011, 07:48 AM » |
Tim
John
Hey John: Thanks. Ya I got a price from Robert Bury in Brampton...439.11 cdn. Price from (US) Wood Stock Supply - 193.40.  Thanks again Festoller. I was told that (Hettich) discontinued making the Euro Hinge. Tim
Festoller
Offline
« Reply #69 on: September 30, 2011, 08:25 AM » |
Tim: I don't think so, at least I havn't heard anything in Germany about it. For the Guido clostet I used the Hettich Sensys Hinge, which is a great evolution from average Euro Hinges. They look very clean and well designed for a hinge and the selfclosing feature is spectecular. I will never use a different brand again. http://web2.hettich.com/hbh/Start.do?localeId=EN&itemId=9071239
Limey556
Offline
« Reply #70 on: September 30, 2011, 11:00 AM » |
Tim, can you expand on the closet suspension system. What are the advantages ? From what I could see on the drawing it provides adjustment in two directions but it seems to hang on a specialized screw I am not sure how many of these screws would be needed for security. I probably missing something here.
I was considering using a french cleat to hang the wardrobe inserts.
Love all the Festool stuff !!!! So far I have the C12, TS55, MFT3, Kapex with the UG Extensions, Parallel Guides, RO90, Domino, CT26E with the Boom Arm and the Tradesman Cleaning Vacuum set. I just got the new SCG10 Self Centering Guides for the Domino from Rick Christopherson RTS Engineering and love them.
I just finished re-habbing 20 windows with the RO90 and was amazed at how good this sander really is .
The Domino what can you say about this tool it's such a game changer that the FOG could probably dedicate a whole section just to this tool. I am sure I haven't even scratched the surface on all the uses and techniques.
Terry
Tim Raleigh
Online
« Reply #71 on: September 30, 2011, 01:07 PM » |
Terry: Here is a page showing a picture of the Hafele system which is exactly the same as the Hettich suspension system. CabinetSuspensionFittings.pdf (82.4 KB - downloaded 248 times.)    As the document says these are aluminum or steel rails, available in any size with a profile much like a z clips into which the hanger hooks onto. Essentially you fasten the rail onto the wall (into studs) and then hang the cabinet on the rail. Saves putting a back on the cabinet particularly if this is going to be used in a closet that already has doors on it or in situations where the wall serves as the back of the cabinet. Hope that helps. Tim
« Last Edit: September 30, 2011, 01:09 PM by Tim Raleigh »
Limey556
Offline
« Reply #72 on: October 01, 2011, 11:48 AM » |
Thanks for this Tim
n2scouting
Offline
« Reply #73 on: October 20, 2011, 09:20 PM » |
Hey guys this is my first post on the FOG, but I am so impressed with this project I am putting together the materials to build one. Does anyone have a USA source for the panel connectors used in the video. I think they are RAFIX fittings. Thanks.
Tim Raleigh
Online
« Reply #74 on: October 20, 2011, 10:51 PM » |
Welcome to the FOG n2scouting. See comment # 7. Good luck with your project, take some pictures. Tim
« Last Edit: October 20, 2011, 11:01 PM by Tim Raleigh »
joiner1970
Offline
« Reply #75 on: March 08, 2012, 04:20 PM » |
great videos but I dont like the way he drills out the handle holes on doors and drawers. Just drilling through with no scrap on the reverse, good way to get ugly blow out , I always hold a scrap of timber on the back when I drill out handles.
galwaydude18
Offline
« Reply #76 on: March 13, 2012, 05:51 AM » |
Brilliant layout there and great use of the Festool system!
Tedric Pancoast
Offline
« Reply #77 on: April 14, 2012, 11:50 PM » |
Interesting videos. I've been a professional cabinetmaker for 15 years and learned a few tricks! We use RTA fittings all the time but we also have a half million dollars worth of saws and CNC machining centers. A few things in the video did make me smile and wonder, 1. The edgebanding on the doors and drawer fronts seems to magically appear. No mention is made of it's application. I find myself wondering if there is a $30,000.00 Holzher edgebander just off camera.  2. The gaps on the fronts are VERY good. Nice work Guido!! That makes me think that some (a lot of them anyway) are cut on some type of commercial panel saw. I really enjoyed watching the videos. Thanks for posting them. Ted Pancoast President Ted Pancoast Woodworking tedpancoastwoodworking.com
txrpls
Offline
Location: San Antonio, Texas, USA Member Since: Feb 2012
« Reply #78 on: May 05, 2012, 10:46 PM » |
Getting ready to make a modified Vesion since there is only white 4x8 0.75 melamine sheets available around here. I can't seem to find any 5mm or 1/4" for the back. Do you think that will work OK? Also is the white melamine iron on tape any good?
Tedric Pancoast
Offline
« Reply #79 on: May 06, 2012, 12:02 AM » |
Getting ready to make a modified Version since there is only white 4x8 0.75 melamine sheets available around here. I can't seem to find any 5mm or 1/4" for the back. Do you think that will work OK? Also is the white melamine iron on tape any good?
1/4" white melamine should be widely available. Where in the world are you? As far as the tape, ironing on white melamine tape is a pain. You have to get the temperature just right. Too hot and you'll melt the tape. Not hot enough and the glue won't bond. You'll have better luck with a hot air edgebander of some type. A full blown hotmelt edgebander is the best option for pvc and polyester banding.
Timtool
Retailer
Offline
« Reply #80 on: May 06, 2012, 03:28 AM » |
I used to iron on the melamine edges, and then bought a small mechanical benchtop edge bander, the main difference is that it works allot faster. But it doesn't hold better compared to ironed on properly. As Tedric said, there is a danger of melting the plastic, and it will happen a few times until you learn the correct work flow. The most tricky part for me is/was trimming the edges, i had this special knife but it doesn't work ferfectly, now i just set up my router table with the fences pulled up a few mm so the protruding edge band can slide under, and with a 45 degree but i make perfect trims.
Kevin Stricker
Offline
« Reply #81 on: May 06, 2012, 10:51 AM » |
If you are shopping at the Depot, you should be able to get some melamine faced hardboard that is about 1/8-3/16" thick that would be considerably easier to install than a full 3/4" back. Regarding the edge banding, make sure you buy from a cabinet supply or online. Don't be tempted by the big box edgebanding, it is very thin and friable.
txrpls
Offline
« Reply #82 on: May 06, 2012, 03:05 PM » |
Ok, seems like the only thing available in my area is 4x8 sheets. I tried google translate without much luck. I trying to figure out if there would be any problem with the sliding hardware if I change the depth to 16" instead of 16.535" to minimize waste. Anyone see any problem?
sheeschen
Offline
« Reply #83 on: May 30, 2012, 11:03 AM » |
I'm considering making some version of these, too, and am thinking the same thing - 16" depth to fully use the sheets. Looking at the drawers supporting the systainers, he uses a deep block of wood to hold them in place. They could easily be almost two inches shorter. In other threads where people have built their own sysports, I think some people use 14" slides, which should easily fit in a shallower cabinet. I don't know if you'd be able to keep the lids open in that case, though.
My German isn't so good, so I haven't read the article, just looked at the pictures. Maybe a lot of the waste goes towards making the drawer sides. Looks like the drawer sides are 15mm instead of 19mm, but it's a possible use of the waste if you want to follow the depth dimension exactly.
An alternative that I'm thinking about is to build 4' upper cabinets with rolling sysports underneath. Size the sysports to match the height of my MFT/3 so they could be used for material support. Should be somewhere around 7' to the top instead of 8' - I'm just average height, so there's no way I'd be able to reach the upper part of the 8' cabinets without grabbing the stepstool.
