Author Topic: A LR32 video. The last video of the series. Video 7  (Read 142744 times)
Re: A LR32 video. Part two added. Part 3 added.
« Reply #30 on: March 25, 2013, 03:07 AM »
Great videos and thanks for explaining how to use it in a easy to follow manner.  Getting the lr32 tomorrow
Offline Bikeboy80
    • Drumm Design Remodel
« Reply #31 on: March 25, 2013, 10:25 AM »
I have a 1010 on it's way, guess I need to get the LR32 set next [blink]
Thanks for the great, easy to follow videos!
The Green Koolaid sure is sweet...
Kapex w/crown stops, Domino DF 500 Set, Syslites, PS300, RTS400, RO150, OF1010 w/LR32 Kit, TS75, 75" + (2) 55" rails, RO90, ETS125, RAS, Custom abrasive systainer, CTmini, CT36AC w/blastgates, PLANEX w/harness, TI15, T12+3 set, MFT/3 cross cut, Universal Cleaning set, Turbo Suction Brush, 12 drawer Sortainer, Extra Systainers with job specific tool collections
Offline skids
« Reply #32 on: March 25, 2013, 11:03 AM »
Nice..I want one. Let me know how you like it.
The funniest thing about this particular signature is that by the time you realise it doesn't say anything it's to late to stop reading it
Offline unityroad
  • photos
« Reply #33 on: March 25, 2013, 06:43 PM »
nice job. [smile]
You are only as good as your ability to get PAID.
Offline jobsworth
  • Does Anyone Know What Time It Is?
« Reply #34 on: March 25, 2013, 10:18 PM »
Good job eric,
Thanks for going through the trouble and spending the time for filming and posting these videos.
Offline erock
Re: A LR32 video. Part two added. Part 3 added. Part 4 added.
« Reply #35 on: March 30, 2013, 08:55 AM »
   Hey guys....here is part 4 of the series.  It talks about the 35mm cup hinge for the doors.  Enjoy!
 Thanks for all the positive feed back !   [cool]
http://www.youtube.com/watch?v=L2gQVWADWq4&feature=youtu.be
Eric
<<Edit:  Imbedded video - P.Halle>>
« Last Edit: March 30, 2013, 09:56 AM by Peter Halle »
Offline Michael Garrett
« Reply #36 on: March 30, 2013, 10:39 AM »
What brand hinges/plates do you recommend?  Where do you get yours from?
CT 26 HEPA, MFT/3 (2), TS 75 EQ, OF 1400 EQ,  DF 500 SET, CXS SET, C 15+3 SET, Ti-15 Basic, CENTROTEC INSTALLER SET 98-PC, TRADESMAN/INSTALLER CLEANING SET, DOMINO ASSORTMENT SYSTEM, LR 32 HOLE DRILLING SET, GUIDE RAIL FS 3000 (1), GUIDE RAIL ACCESSORY KIT, GUIDE RAIL FS 1400/2  (2), GUIDE RAIL FS 1900/2  (2), GUIDE RAIL FS 1400/2 LR 32  (1), Veritas MFT Clamping Kit,  Imperial & Metric Zorbo Forstner Bit Sets, RO 90, ETS 150/3, PSB 420 EBQ w/Accessory Kit, WCR-1000, PARALLEL GUIDE SET, CT 26 BOOM ARM SET, Veritas® Drilling Kit, MFK 700 EQ Router Set
Offline erock
« Reply #37 on: March 30, 2013, 11:34 AM »
Michael,
     In the video I used GRASS hinges.  I think the  model is 231.M    it's what is stamped on the back of the hinge.
My local woodworker store sell them for a couple bucks.  They are just like the Blum hinges.  I'm sure you can find them just about any
brick an mortar store and online.
Eric
Offline Jim Kirkpatrick
    • Jim Kirkpatrick Woodworking
« Reply #38 on: March 30, 2013, 11:50 AM »
That works fine but for overhead clearances, don't you want your door 1/4 shy of the height of your cabinets?  What  then?
Offline erock
« Reply #39 on: March 30, 2013, 01:20 PM »
Jim,
  Good question !
   I'm not a professional cabinet installer.  So maybe one of those guys can chime in and answer that a little better then me.
But my guess would be if I was to install my cabinets up against the ceiling I would want to use a half overlay hinge or of the like. I wouldn't use
a full overlay hinge if I was installing the cabinets up against the ceiling because I know the drywall/plaster is not going to be perfectly flat and level
with the wall the cabinet is being hung on.  So if you want to hang a cabinet flush with the ceiling then I would suggest using a different overhang with
the hinge.
  Also, If I wanted to, I could drill the holes for the 35mm cut hinge with the door still in a increment of 32mm and then take a couple mm's off the top and/or
bottom to achieve some type of clearance or reveal.  But the sides of the cabinets would still have a full overlay.
  I never planned on mounting the cabinets up to the ceiling, I have 10 foot ceilings in my garage   [tongue]  [big grin].
Eric
Offline mastercabman
  • NORFOLK,VA
« Reply #40 on: March 30, 2013, 03:22 PM »
Jim,
  Good question !
the hinge.
Ericveal
Most framless cabinets have a 3mm reveal(top,bottom and sides)So you would need to make the doors 6mm smaller than the box.I have installed cabinets that had doors same height as the box.I had a real problem with some of the bases cabinets because after adjusting the doors some would hang up on the edge of the counter top.
Leaving a 3mm reveal gap allowes for adjustment and looks.
Just another reason why i did not go with the full 32mm kit.I have the BLUM ecodrill jig and finds it much faster to use for drilling the hinges holes.The jig not only drills the 35mm cup hole but also drills the 8mm holes for the plastic insert for the screws.
Offline erock
« Reply #41 on: March 30, 2013, 08:56 PM »
Thanks Mastercabman,
In the research I have done on the True32 system I remember the 3mm reveal.  That gives you the true zero  reveal.   And honestly that slipped my mind.
I know that with the true 32 method, the doors and drawers should be in increments of 32 +/- the reveal.  But since I planned on installing my cabinets
the way I did, I didn't bother cutting the 3mm for the reveal.
Eric
« Last Edit: March 30, 2013, 09:38 PM by erock »
Online copcarcollector
« Reply #42 on: March 30, 2013, 10:55 PM »
Eric - THANKS for the videos-- :)
« Reply #43 on: March 31, 2013, 10:54 AM »
Is the centering mandrel only used with the OF 1010?
Offline Brice Burrell
  • Remodeling Contractor
    • The Green and Dark Blue blog
« Reply #44 on: March 31, 2013, 10:59 AM »
I'd recommend you use the centering mandrel with both the 1010 and 1400 router.
« Reply #45 on: March 31, 2013, 12:59 PM »
Reason I ask was that the 1400 is screwed to the base.  Shouldn"t that automatically center it and is there enough play when screwing to plate to allow manual centering?
« Reply #46 on: March 31, 2013, 01:35 PM »
Well, there is a very small amount of slop.  It only takes a few extra seconds to to use the mandrel so it's worth it just to be sure none of your holes get out of line.
« Reply #47 on: March 31, 2013, 01:42 PM »
Does the same rule apply when mounting in cms?
« Reply #48 on: March 31, 2013, 04:50 PM »
There is no centering mandrel for the CMS, there are mounting rings included to center the routers.
Offline RDMuller
« Reply #49 on: April 02, 2013, 10:05 AM »
Excellent job.  Please continue adding segments.  At a retail level, I have taken this LR32 system back and refunded the money to the customer as they just could not figure it out.   These videos would have met his needs.  Your instructional style is great.
I have done some videos in the past (parallel guides and extensions) and just could not get excited about doing a series on LR32 as I have 3 other technologies to do this including a Delta 13-drill machine, a Blum 5 or 7 hole machine, and off course the plastic guides sold by several retailers.  All have pluses and minuses.
Keep up the good work.
Offline Connollyir
  • Love what you do.
« Reply #50 on: April 04, 2013, 05:13 PM »
Jim,
  Good question !
the hinge.
Ericveal
I have also had this same problem with countertops usually, our upper cabinets many times are held shy of the ceiling to correct for level anyway and we scribe moulding to cover the gap.
I really appreciate this video series and timely too considering I am probably going to purchase the system for my next job. I would appreciate a video on face frame applications as well since they are more common for me.
-Ian
Offline gtriderr
« Reply #51 on: April 04, 2013, 08:37 PM »
I am a hobbyist woodworker and spend evenings when wife and I are watching TV, especially in winter, reading posts on FOG.
I have always used my drill press to drill hinge mounting holes and a Rockler jig for shelf pins.  Just picked up the LR 32 and a OF 1010 router and have enjoyed watching your videos on the use of the LR 32.  # 4 video put it all together and I wanted to drop a line or two and say, great job and thanks.
John Stevens
MFT/3 w/ Cross Members & Table Extension, Quick Clamps, 4-11/16” Screw Clamps, Clamping Elements, 11-13/16” Screw Clamps, Qwas Dog Set, Imp/Metric Tape Rule, CT36, TS55ESQ, FS 1400, FS 2700, Guide Rail Connectors, Parallel Guide Extension Set, OF1010, OF1400,  MFK 700 Set, LR32, FS/2-LR32 32mm Holy Rail, MFS-400, MFS-1000 RAILS,  DTS-400 & RO125 sanderS, Router Bit Systainer, CMS-VL SET,  Delta Sandpaper Systainer, 5” Round Sandpaper Systainer, DF 500 E set, Domino Tenon Assortment Systainer, 9 Draw Sortainer, 12 Draw Sortainer., PS 420 EBQ, Carvex acc. kit, CXS Set &  T 18+3 Set, Centrotec 98-Piece Installers Set, SysLite LED Worklamps.
Offline erock
« Reply #52 on: April 04, 2013, 10:03 PM »
John Stevens
Hey John,  [welcome]  and  [thanks]
I hope you get time to  learn the LR32 system and keep us updated on some project you use it on.
And to all the other guys, Thanks for the kind words.  I'm glad you have enjoyed the videos.   I'm brainstorming on the next video that will talk a little about
a base cabinet.
Eric
Offline Wooden Skye
« Reply #53 on: April 04, 2013, 10:29 PM »
Eric
Great videos, nice beanie!  After this series, you should do a video of the drawers you did using the domino and domiplate.  I saved this article, but a video would be a bonus.
Bryan
TS 55, (2) 1400 Guide Rails, 1900 Guide Rail, MFT/3, Domino DF 500, 2 domino systainers, ETS 150/3, RO 90, CT 26, (2) OF1400, RO 150. RTS 400, LR 32 set, PS300 jigsaw, 3 abrasive systainers, (2) sys toolbox, (2) sys mini, clamps and other accesories
Offline erock
« Reply #54 on: April 05, 2013, 07:51 AM »
Eric
Bryan,  I believe BuilderBob did a video on making a drawer with the Domino.  He didn't use the Domiplate.
I think I remember seeing the video on Youtube about 6 months ago.
If their is enough interest I would do a video making a drawer with the Domiplate.
And let me publicly say  [thanks]  for the beanie cap!   It's a great community we are part of. The way  guys  reach out and help each other is just fantactic!
Eric
Offline skids
« Reply #55 on: April 05, 2013, 08:59 AM »
Eric
If their is enough interest I would do a video making a drawer with the Domiplate.  And let me publicly say  [thanks]  for the beanie cap!   It's a great community we are part of. The way  guys  reach out and help each other is just fantactic!
Eric
Interested
Offline erock
« Reply #56 on: May 04, 2013, 04:58 PM »
Well, I finally got some free time to record and edit part 5 of my LR32 series.   This video talks a little about a base cabinet.
Grab your cutie with a glass of white wine and cuddle up too the computer with her and watch this one.   [eek]
                    http://www.youtube.com/watch?v=Ofnq3pQmZgA&             feature=youtu.be
Let me know what you crazy cats think.
Thanks,
Eric
Offline sprior
I think these videos have been great and really helpful.  What I'd like to see is a real start to finish video how you make a wall/base cabinet - when do you allow for the dimensions of and apply edge banding to the sheet goods?  I wonder if you cut one edge, apply the edge banding, then use that as a reference to cut the other edge?  Is it the same when making your cross cuts?  So are the edges already finished by the time you're making the LR32 holes?  Are you using Domino's for the joinery?  How are you allowing for mounting the cabinets to the wall - french cleat or something else?
Offline erock
Thanks for the positive feed back.
I cut all my cabinet parts to size first.  Then I edge band them.  Following the edge banding I use the LR32 system.  The edge banding I use is iron on.
It adds about 1mm.  I'm sure it wouldn't make a difference if I edge banded after using the LR32 system.
I do use a combo of 6mm domino's with pocket holes.  In fact, in one of the upcoming videos I had plan on showing how the domino helps with assembly.
So stay tuned buddy  [wink].
I mount my upper cabinets and base cabinets the same way.  I recess the backs of my cabinets 18mm, the thickness of the plywood I'm using to build
the cabinet.  That allows me to use a cleat (not a french cleat, because I don't cut a 45 on it).  The cleat attaches to the top and sides of my cabinets
and for me, it's a very strong method to hang a upper cabinet.  I used GRK 3-1/8" cabinet screws to hang the cabinets.
By me using a 5mm back panel for my cabinets it save on 18mm plywood, reduces the cost of the cabinet and reduces the weight of the cabinet.
I thought about making a video showing how to make a cabinet from start to finish, but I didn't think that many guys would be interested in it because
if you search Youtube for cabinets their is a few videos already out.  I'm trying my best to bring new material available to guys.   But, If I get enough
interest from people willing to see a video from start to finish of me using all my Festool tools, I may consider it.
Thanks,
Eric
« Last Edit: May 04, 2013, 05:29 PM by erock »
+1 on start to finish. What size euro screws do you use?
« Last Edit: May 04, 2013, 05:37 PM by Michael Garrett »
