Author Topic: any tips on using a Gifkins dovetail jig on the CMS with 2200 router fitted ?  (Read 1354 times)
Offline David Stanton
  • Festool Dealer Affiliate
  • Carpenter & Joiner, Photographer, Youtuber.
    • David Stanton
Can a guide bush be fitted for this jig or even an eccentric guide bush for the Leigh jigs?
The photo shows a Leigh eccentric guide bush fitted to a 1400 router but not in a CMS unit.
I need to fit this bush to an OF 2200 in a CMS.
Can it be done?
Click here for Dave Stanton on Youtube
KAPEX 120, ROTEX 150, ETS 5 150, TS55, 800-1400-2700 TRACKS,  PDC 18-4 TEC, DOMINO XL, CXS, TXS, EHL 65, SYSLITE, HKC 55 EB, PSC 420 EB, CTL SYS, SYSROCK
    • David Stanton
From the amount of views this post has had I would suggest that maybe Festool need to sort an answer for this predicament as I can not see any response and I would take it that there is no way of performing this basic task?
Does anyone else feel that there should be a way of using 3rd party jigs in the CMS?
Offline morris
The Gifkins jig doesn't need a Leigh jig type of guide bush .  If buying the Gifkins as  a kit the appropriate router bits are supplied. The router bits have a 1/4" or 1/2" shaft depending on the size of the template.
The Gifkins template rides on the surface of the router table. The Gifkins router bits have a bearing which follow the template and the cutting blades are above the bearing.
In other words no special equipment is needed. I have a festool 2200 router mounted to a standard router table and the Gifkins kit  works just fine .
