rookie08
Offline
« on: March 07, 2012, 09:00 PM » |
I'm going to be building the wall unit over the next few weeks and was wondering if anyone else had and had some advice, or looked at it and had some suggestions. Any and all input is appreciated!  Cheers James
fritter63
Offline
« Reply #1 on: March 07, 2012, 10:39 PM » |
Make sure u can break it down and take it with you if you move !
rookie08
Offline
« Reply #2 on: March 08, 2012, 11:08 AM » |
I'm trying to source the cam connectors Guido uses so I can reconfigure if I move stuff around in the shop.
If we move I might leave it for the next homeowner. It could then easily add at least 20% to the sale price then. LOL
Festoller
Offline
« Reply #3 on: March 08, 2012, 01:52 PM » |
The fact that we live at the bottom of a deep gravity well, on the surface of a gas covered planet going around a nuclear fireball 90 million miles away and think this to be normal is obviously some indication of how skewed our perspective tends to be. -Douglas Adams-
sancho57
Offline
« Reply #4 on: March 09, 2012, 12:57 AM » |
You can always contact him.
He has posted here before and is a very nice guy and very helpful too.
Shhhhhh Dont tell the wife butttttt I bought another…….
Emer Construction
Offline
« Reply #5 on: March 10, 2012, 11:39 AM » |
i picked up the drill jig here. http://www.woodstocksupply.com/connector-drilling-jig-20166-hettich.htmli found rafix connectors pretty cheap on ebay.
« Last Edit: March 10, 2012, 11:49 AM by Emer Construction »
Steven
fritter63
Offline
« Reply #6 on: March 19, 2012, 10:39 PM » |
I've been doing the planning/prep work to build some sys ports based on Guido's plans and have noticed a problem.
The dimensions as he has them (420 mm deep using 400 mm slides) does not appear to give enough clearance for the systainer tops to open to full vertical (i.e., stay open). A T-Loc will need min 335 mm of extension for this, but when I check the slides ( I have a bunch of 400 mm already), then only extend to about 317 mm.
Anyone else noticed this? Is it a problem?
Would be great to hear Guido's comments on this.
(Simple solution is just to go to the 457 mm slides and deeper cabinet).
Kevin Stricker
Offline
« Reply #7 on: March 20, 2012, 12:38 AM » |
A better solution would be to switch to full extension 14" slides. Going over 16" deep would probably double your sheet goods as you need approx 16" of width depending on the slides used. At 16" deep you can get 2 sides, top, bottom, center divider, and another shelf per sheet.
You can buy 10 packs of 14" full extension slides for $65 on Amazon.
Timtool
Retailer
Offline
« Reply #8 on: March 20, 2012, 04:54 AM » |
Unless if you are using full extension slides, then you will need 550 mm slides to open Tlocs comfortably. Remember the top latch sticks out when in open position. I just measured on my sysport workbench, you need them to extend at least 450mm if you want the top to stay open.
Kevin Stricker
Offline
« Reply #9 on: March 20, 2012, 12:10 PM » |
Hey Tim, good point on the T-locs. For a T-loc to have full opening of the lid with the latch up uses 405mm. The minimum clearance needed for the lid to open is 330mm. A 14" full extension slide gives you 355mm, or 380mm with 1" over travel.
Btw the $65 price I listed in the previous email is for 10 pair of 14" slides with 1" over travel. You can get them directly from Gliderite for $33.90 plus shipping.
« Last Edit: March 20, 2012, 12:30 PM by Kevin Stricker »
rookie08
Offline
« Reply #10 on: March 20, 2012, 01:53 PM » |
Thanks for all the input everyone. Here's where I am so far. Guido was incredibly kind and helpful and sent me the hafele parts and numbers (cut and pasted below for everyone). What a great guy! Guido if you are reading this thanks once more! I used buyhafele.com which is based right here in Baltimore so I got a bit of a discount, but they ship nationwide. Regarding the depth, I ended going 20 inches deep as I have about 20 drawers left over I want to adapt to the wall unit so I had to decided between going with the 14 depth for the systainers and then bumping out when I got to the 3 sections/towers with the drawers, or going 20 inches deep all the way across. Decided on 20 for a couple of reasons mainly, 1) makes it more flexible if I want to change stuff around in the future and 2) makes fabrication, faster, simpler, (for me), if main components are basically the same. On another thread someone mentioned CHS for slides and service and I got a great deal on a bunch of closeout 20's so that should take care of the systainer depth ( there will be some dead space behind the systainer section but overall it works better for me. Yes, I'll use a bit more material but I'm a bit "overstocked" on sheet goods so this will be a good chance to use some of it up.  Drill jig looks sweet, but dear, when it comes to price (poor pun, I know) LOL.  I'm planning on making the jigs Guido shows. Besides the depth difference, mine will be shorter due to height limits, plus I may add doors to the bottom in addition to the top. My shop is somewhat narrow and though I'm mostly dustless, thank you Festool, some still gets away, plus a bit of paint overspray here and there.  I'll post pics when I'm done if anyone is interested. Below are the part numbers from Guido fro the main hafele sight. "Here are some links for the right connectors you are looking for: Item #: 263.13.705 Rafix SE without Ridge, zinc, nickel-plated, 19mm https://hachol02.hafeleonline.com/OA_HTML/ibeCCtpItmDspRte.jsp?section=11730&item=18327 Item #: 267.00.012 Sleeve Nut, steel, brightened, M4, 5mm x 18mm https://hachol02.hafeleonline.com/OA_HTML/ibeCCtpItmDspRte.jsp?section=11730&item=18718 Item #: 263.21.817 Rafix Bolt, steel, zinc-plated, galvanized, M4, diameter 7 x 7.5mm https://hachol02.hafeleonline.com/OA_HTML/ibeCCtpItmDspRte.jsp?section=11730&item=18371 Item #: 263.20.856 Rafix Bolt, steel, zinc-plated, galvanized, diameter 7 x 15mm, 5mm" https://hachol02.hafeleonline.com/OA_HTML/ibeCCtpItmDspRte.jsp?section=11730&item=18367Cheers, James
« Last Edit: March 20, 2012, 01:55 PM by rookie08 »
BMH
Offline
Location: Oregon, UNITED STATES (US) Member Since: Aug 2008
« Reply #11 on: March 23, 2012, 12:08 AM » |
I am building a shorter version of the "Guido wall". Today I was doing most of the cuts and used the LR 32 stop flags to do repetitive cuts. It permitted to cut the time in half for the cuts. This came from a you tube video
Rookie08 thank you for the list of material. My local dealer only had a 1/3 of what I needed and was not going to be restock for another 2 weeks. Tomorrow is LR32 day and hopefully assembling the first cabinet if I didn't screw up. Bruce
jofuss55
Offline
« Reply #12 on: March 24, 2012, 01:39 PM » |
The WooDworkers Club of Norwalk, CT will be offering this as a one day demo later in the year.
Guido
Offline
« Reply #13 on: March 29, 2012, 12:34 PM » |
Hi fritter63 and anyone else building the chaos wall,
you are right, you can't open the lids of the systainers completly to 90º. If you like to do so, you have to switch to full extension drawers or - like you have suggested - use the next lenght of the drawer slides (450 mm) and make the cabinet deeper.
If you have a lot of old Systainer, you normaly won't have any trouble with this, because the lids are not so "smooth" than the lids of the T-Locks, they will stay open also in 80º position, like you can see on the photos below. Also the upper first row of drawers, dont make any problems although this lids can only be opend about 75º, because they are stoped by the 19 mm thick drawer front. But with the T-Lock systainer you have no chance, they will always fall down.
For me this is no problem and after more than half year using the "chaos wall" (funny term), I found out that this could be an advantage, because the lids (of the T-Locks only) are always closed an no dust can get into the systainers, and for getting things out an in, its for me handy enough. When I store the T-Lock in my wall, I also take of the front lock knob, because thats makes it more quick an easy to get things out an in. But nevertheless if I will find out that I need this feature, I would switch to fully extension slides. I think this is more useful than a deeper cabinet.
I hope this could help you a little bit, if somone have further questions let me know ...
Best regards
Guido
sancho57
Offline
« Reply #14 on: March 29, 2012, 06:29 PM » |
Hey Guido,
Thanks for stopping by.
I go to your site regularly and check to see if you have any new videos.
So any new one in the works?
I really do enjoy them and have picked up quite a few ideas from them.
Guido
Offline
« Reply #15 on: March 30, 2012, 02:02 AM » |
hi sancho, I am sorry, but my website was not updated for a longer time. Here are some links to my latest videos on youtube: 1. Making round tenons with the cms routing module ( sure you can use any router table  ):
2. An articel teaser video on building a shoe cabinet with finger joint hinges (I have wife and daughter so you all can imagine that this is a "great project"), and here is the video:
3. Two teaser videos on building a "premium router table", I think it was discussed here in another thread:
and the second part:
In April there will be a new video on using the bandsaw with some clever selfmade jigs, you can watch it on the "holzwerken" channel, here is the link: http://www.youtube.com/user/HolzWerkenTV/featuredHope you all like the videos and if you have questions let me know. Enjoy it and best regards Guido
sancho57
Offline
« Reply #16 on: March 30, 2012, 05:40 PM » |
Thank you Guido
as we say in the states
You are the man :>D
(which means your awesome )
fritter63
Offline
« Reply #17 on: March 30, 2012, 06:23 PM » |
 LOL! Is that the lid from a bulk pack of CDs/DVDs that you're using for the clear guard over the router bit? Please stop making everything look so easy... my wife might get the wrong impression about my productivity.
Guido
Offline
« Reply #18 on: April 01, 2012, 03:14 AM » |
Hi fritter, yes its a DVD lid, you can get it in different heights (10, 25 and 50 DVDs). You can also get a commercial version of this guard from festool for the CMS Router Table Module (costs in germany about 50 Euros see this link on ebay: http://www.ebay.de/itm/FESTOOL-Bogenfraeshaube-BF-OF-CMS-Nr-494643-/350117175161). This Fence is for routing curved workpieces an it is much more safer than a pivot pin, because you guide the workpice in a forward motion on a straight piece of plastic into the bit, Therefore its nearly imposible to get kickback. Pivoting the piece into the bit is a lttle bit more tricky, and if you dont move the workpiece forward when you reach the bit you can get a massive and dangerous kickback. The selfmade guard costs less than 5 Dollars and about 2 hours work - its very easy to built, really helpful and worth to bult it  . Best Regards Guido
bwiele
Online
« Reply #19 on: April 01, 2012, 11:08 AM » |
Oh great, now I have to pick up some of those Rosetta Stone DVDs so I can learn German. Will it never end?!?
BMH
Offline
« Reply #20 on: April 02, 2012, 12:35 AM » |
Guido,
I am making a smaller version of your "Chaos Wall", great introduction to the LR32 system. Everything is ready for the hardware but my local store is our of rafix hardware and the online store is back order. Everybody in the USA must be building a Chaos wall!
I like your design as it doesn't waste any space and if the lid opening become an issue I will go to full extension. What is the height of the first shelve in your system after the systainer pull outs ?
My next project is a Chaos wall for the garage. I want to build large drawers on the bottom and shelving on the top. What is the maximum depth and length of a drawer using 19mm plywood and the rafix system that will still give you a stable structure.
Thank you for your great videos and I wish I spoke German to understand all of the great information you present
Bruce
Guido
Offline
« Reply #21 on: April 02, 2012, 03:39 AM » |
Hi Bruce, the height of the sidewalls is 2750 mm and the height of the doors is 1392 mm, so the height of the sytainer area and the two drawer front rows under the doors is 1358 mm. That is for me maximum, because I want to see and get out things comfortable. A basketball pro can vary the height  If the depth of a cabinet is more than 450 mm you should use one more rafix connector in the middle of the board, so you have to make a third row of 32 mm holes in the middle of the sidewalls. But you should keep in mind that more depth also means less overview in the cabinet, when you store smaller things. For the systainers more depth is not necessary. I would not make a cabinets depth more than 620 mm. By the way - I gave the german text of the video to Festool-Germany to translate it in english. I dont know how far they are, but as soon I will get it back, I will make an english voice over. Regards Guido
rookie08
Offline
« Reply #22 on: April 02, 2012, 12:12 PM » |
Hi Guido, Don't mean to flood you here with questions.  I'm building the jig you show on the video for the rafix connectors and I'm trying to follow the drawing from your magazine article with the measurements. Maybe I'm just not very good at it but I'm having the hardest time getting the measurements to line up correctly. Any thoughts/directions? Thanks! James
Guido
Offline
« Reply #23 on: April 02, 2012, 02:19 PM » |
Hi James, the best way to get a perfect template is to start with Pos. 1 the 9 mm thick plywood template (500 x 230 mm). Mark all holes with long straight lines across the whole template you need this lines later. Use your drill press with a fence to align the holes in a straight row. Start with the smaller 17 mm holes (here for a 17 mm guide bush for german routers) if you dont have a 17 mm guide bush use the next near available in inch with a perfect matching forstner bit. The center of the hole should be "about" 121,5 mm. Dont worry when the center is 121 or 122 mm from the long side of the 9 mm template board but take care that both holes are in a line or row (dont know the right term). The distance between both holes should be "about" 154 mm. To get this perfect use a left and a right stop block on your drill press. So for now you have a left and a right stop and a long fence mounted on your drill press. Dont move these stops and the fence to make the other two bigger holes (30 mm or what ever you have in inch) but put a 32 mm scrap piece against the long fence to move the template abolutely parallel to the first two holes. Dont try to move the fence, because its nearly imposible to get it absolutly parallel moved!!! Now you have all holes perfectly parallel aligned to the side edges of your template board. Next step is to make and mount the fence bords Pos. 2 and 3. Start with the easy to make fence board Pos. 2 (500 mm x 80 mm x 18 or 19 mm plywood). Mounting this on the template is a little bit tricky because the offset between the center of the bigger holes and the fence must be exactly 9,5 mm (not 10 and not 9!!!). This very important because the rafix need a hole wich is open on the edge of the board and you get no opening with 10 mm and a too big opening with 9 mm offset. The best method is try and error and first only use two screws to mount the fence. Next challenge is the fence in the middle of the template, which separates the left and the right holes. Now first you have to measure "your" distance between the holes. If it is perfectly 154 mm you can make a 80 mm wide fence, if it is e.g. 153 mm you have to make the fence only 79 mm wide (37 mm left + fence width + 37 mm right). You see you can only vary the width of the fence and you have to stick perfekt to 37 mm left/right!!! Mounting this fence is the same tricky like the longer fence, so use the try and error method and move it when necessary and fix it again with screws. Keep in mind its a template not a furniture masterpiece, it has to work perfect but need not look perfect  Hope you could understand what I mean, its not so easy to explain this in english ... otherwise ask again  Good luck and best regards Guido
BMH
Offline
« Reply #24 on: April 06, 2012, 11:34 AM » |
Guido,
Thank you for all of your answers. The garage project will have large deep drawers on the bottom for storage of our winter and summer seasonable stuff. Upper part narrow cabinets with doors for easy access. In the next few years the garage is going to go through a couple of remodel, so I will need to take everything down and reassemble in a different area. The rafix system will be perfect for this and 620mm will give me the depth necessary for the bottom drawers.
You gave a good description on how to make your template. Laying out all of your lines before you start is the key step. Using screws has permitted me to use the same jig on another project by modifying the center piece and adapting it to a 42mm separation from the edge.
Bruce
Michael Garrett
Offline
« Reply #25 on: May 09, 2012, 07:51 PM » |
is there a set of plans for this with dimensions, cutlist and complete parts list. I'm new to woodworking and this would be a good start project for my garage.
CT 26 HEPA, MFT/3, TS 75 EQ, OF 1400 EQ, DF 500 SET, CXS SET, CENTROTEC INSTALLER SET 98-PC, TRADESMAN/INSTALLER CLEANING SET, DOMINO ASSORTMENT SYSTEM, LR 32 HOLE DRILLING SET, GUIDE RAIL ACCESSORY KIT, GUIDE RAIL FS 1400/2 (2), GUIDE RAIL FS 1900/2 (2), GUIDE RAIL FS 1400/2 LR 32 (1), Veritas MFT Clamping Kit, Zorbo Forstner Bit Set
BMH
Offline
« Reply #26 on: May 09, 2012, 11:33 PM » |
Michael Garrett
Offline
« Reply #27 on: May 10, 2012, 12:03 AM » |
Thanks, Bruce that helps a whole lot. I can read it, I spent 17 years in Europe in the Military.
hrrb
Offline
« Reply #28 on: May 10, 2012, 03:58 AM » |
Blimey!  (Said with a rough woodworkers voice) I love the transformation on page 46 (44 in a printed version). From a tool rack with very few pieces of Festool stuff, it suddenly transforms to a nice wall with humongus loads of systainers!  I got to build such a wall! The cabinets are nice but the increase in Festool stuff is the initiator! /Henrik
Michael Garrett
Offline
« Reply #29 on: May 10, 2012, 12:26 PM » |
Height of the sidewalls is 2750 mm. Is this correct? I thought the panels come in 48 x 97.
