Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 23, 2013, 12:33 AM
Home
Search
Login
Register
Login
Festool USA
Festool International
Woodworking & Power Tools Forum - Festool Owners Group
FESTOOL DISCUSSIONS
Festool How To...
MFS700 and MFK700 trim router to do inside roundovers
Pages: [
1
Go Down
« previous
next »
Print
Author
Topic: MFS700 and MFK700 trim router to do inside roundovers (Read 1598 times)
TomGadwa1
Offline
on:
April 24, 2011, 10:48 PM »
I had a need to do roundovers on the inside of some 30 mm trim. I decided to try using my MFS700 router guide set, the MFT3 and some quick clamps to do this. I am doing this on some quarter inch thick stock. Do to the look that I wanted on my project I decided that I needed to stop the roundover before the end of the workpiece. I did this by sizing the MFS700 to allow the MFK700 on the vertical base to ride within the inside rectangle formed by the profiles of the guide. I placed a reference and support piece of quarter inch material behind the piece that I wanted to do the roundover on. This supports the router base and references the workpiece parallel to the MFS700. I then centered the workpiece between the profiles and sized them to compensate for the amount of the thickness of the side trim which is why I needed to stop the router on each end of the workpiece in the first place. The support and workpiece were secured using double sided sticky tape. I then routed the piece. Much to my horror when I checked the result I found that I had the cutter set too deep leaving an ugly groove at the top of the piece. After I said some words that I can not post I set the cutter properly, ran it again and got the desired result.
TS55 EQ OF1400 EQ DFQ 500 Q RO 125 LR32 SET Guide Rail Acc Kit Parallel Guide Set MFK 700 EQ Set MFS700 ETS 150/3 EQ Domino Cutter Assortment T15-3 Drill Set RO 90 EQ Workshop Cleaning Set CT36 Kapex 120 MFT/3 LR32 1080 FS 1400 FS 1900 WCR1000 PSB300 Boom Arm Set Clamping Elements RS 2 E Kapex UG Set Zobo Forstner Set Centrotech Installers Set OF1010 OF2200 ZS-OF 2200 SYS1000 Syslite CT MIDI FS 800
There Are Those That Can Do, There Are Those That Can Not Do, Those That Can Not Do Have Those That Can Do Do The Things That They Can Not Do So That They Feel That They Have Done Something.
There ain't no something for nothing machine.
Julian Tracy
Offline
Re: MFS700 and MFK700 trim router to do inside roundovers
Reply #1 on:
April 25, 2011, 09:59 AM »
Seems like an awful lot of work to do a process the router table would do in a few seconds...
JT
TomGadwa1
Offline
Reply #2 on:
May 24, 2011, 12:07 AM »
Thanks for the reply. The reasons for using this setup to do this task are as follows, I wanted to try out my new MFS700 set and new MFK700 trim router and also I feel more comfortable safety wise to do the work this way. To me putting a smallish piece of material onto my 3.5 HORSEPOWER router table unit seems to me like a bit of overkill. In addition I was able to get quite precise and repeatable results with this method.
Pages: [
1
Go Up
Print
« previous
next »
Jump to:
Please select a destination:
FESTOOL DISCUSSIONS
=> Festool Tools & Accessories
=> Festool Tool Reviews
=> Festool How To...
=> Festool Tool Problems
=> Festool Jigs & Tool Enhancements
=> Festool Wish List
=> Festool and Tanos Systainers
=> Ask Festool
=> Sales & Dealer Area
=> Fun, Games, Diversions
GENERAL DISCUSSIONS
=> Member Projects
=> Other Tools & Accessories
=> Other Tool Reviews
=> Hand Tools
=> Building Materials
=> Finishing and Painting
=> Various Woodworking & Crafts Topics
=> Home Improvement & Other Projects
=> Member Connections
FORUM TECHNICAL
=> Gallery & Attaching Images
=> Forum Features & Functions
=> Forum Rules, Guidelines, & Suggestions
OFF-TOPIC
=> Computers, Gadgets, Technology
=> Photography
=> Sports & Recreation
=> General Friendly Chat
=> Classifieds
