Pages: [1]   Go Down
  Print
Author Topic: Can't cut a circle with ps300 and circle cutter.  (Read 1427 times)
Kingpen51
Offline Offline
« on: May 24, 2011, 09:47 AM »
I have the PS300 and the 490118 circle cutter and I can"t cut a good circle.  I'm using the scroll type blade 486563 and no progressive orbital mode.  I have to put the pin in the 200 hole to get close to a circle.  The 300 hole wants to go straight and sparks fly. Can someone please help.  A video would be great. Grin
Qwas
Retailer
Offline Offline
WWW
« Reply #1 on: May 24, 2011, 11:16 AM »
It's been 4 years since I cut a circle with the setup you described so I may be a little rusty.  Smile I had problems at first too, then I studied up on the blade offerings. I tried a S75/4 FSG (486 551) which is designed for curving cuts and everything was fine.
Steve Adams  QwasProducts.com
Kingpen51
Offline Offline
« Reply #2 on: May 24, 2011, 03:03 PM »
I was using the recommended blade but It didn't work.  It makes since to use a Trion blade because the other problem is I cant get a 90 deg cut. Thanks for the reply.
wood pulp
Offline Offline
Each another's audience...
« Reply #3 on: May 25, 2011, 08:34 PM »
Sparks?  Are your guide blocks tensioned too tight?
Kingpen51
Offline Offline
« Reply #4 on: May 25, 2011, 11:27 PM »
Guide blocks seem to be OK.  The blade wants to flex away from center causing the sparks and not a 90 deg cut.  I got the pin in the correct hole using a Bosch blade.  It cuts a nice circle now but not a 90.  I am going to try and get a Trion blade next.
Pages: [1]   Go Up
  Print
Jump to:
