Author Topic: Chair repairs and building drawers  (Read 1300 times)
Offline TBR
« on: December 07, 2017, 12:37 PM »
I have wanted to buy a Domino 700 XL for a long time. The 700 has the advantage over the 500 of doing more using the seneca adaptors and the sort of work I want to do with it encompasses external doors, garden furniture, as well as drawers for indoor use. Although the first 2 projects I have lined up are really smaller scale work better suited to the 500, I can't justify buying both machines so the 700 with adapter seems the best option.
Project 1 - Repairing Dining Chairs
As you can see in the photos, the side seat rails have come away from the stile. I previously replaces the dowels with some Unibond  but now they have failed (the dowels might have been pine or something not up to the task).
Some questions...
1. As shown in the photo, the rail and stile aren't perfectly flush. there is a step of about 2-3mm. Is this going to make lining up the domino slots problematic? How is it best to tackle this?
2. The rail is 27mm wide so I am assuming that 8mm dominos are the best size to get. I see that 8mm dominos are sold as 50mm long or as 750mm long rods. The stile being 32mm wide could perhaps take a 30mm deep slot. Would a 50mm long domino be strong enough? Is one large domino better than two or more smaller ones? What is the strongest configuration?
3. Which is the best glue to use?
Project 2 - Plywood Drawers for under stairs
I am going to make some cabinets with drawers on ball bearing runners and made from 18mm plywood. I have done this previously and found it pretty time consuming to fill in all the cavities between the layers prior to painting. Would mdf be better choice?
I am looking to also buy a MFT/3 for this task (I already have a TS 55).
There are many ways to buy dominos. I am thinking of buying an assortment in Systainer (Festool 498899 1060 Piece DOMINO Beechwood Assortment) that comes with a selection of smaller cutters. It seems most economical in the long run that way, right?
Here is my shopping list so far - have I missed anything useful?
Festool DF700 EQ-Plus 240v Domino XL
Festool 493487 Trim stop
Festool MFT/3
MFT FX set
Seneca Adapter
Bessey BAN700 Band Clamp
Normal people... believe that if it ain't broke, don't fix it. Engineers believe that if it ain't broke, it doesn't have enough features yet.
Offline jobsworth
  • Burger Babe Says: I Even Buy Green Bananas
Re: Chair repairs and building drawers
« Reply #1 on: December 07, 2017, 01:22 PM »
Clamping elements would be useful.
Loving the Calif sun....
Offline John Stevens
  • Ardmore, PA
« Reply #2 on: December 07, 2017, 09:47 PM »
My step-dad was a great furniture repairman, and after working with him on a few jobs I got the idea that repairing furniture can be a lot harder than building it from scratch.  Are you completely opposed to using screws in pocket holes to fix the chairs?  I think it would be very difficult to register a DF700 or DF500 accurately.  (If building from scratch, you’d bore while the pieces were still straight and square, then shape them after boring.). Sorry if this isn’t the answer you were hoping for, but maybe it’ll be useful anyway.
—John
What this world needs is a good retreat.
--Captain Beefheart
Offline TBR
« Reply #3 on: December 08, 2017, 06:49 AM »
—John
John, thanks for the advice. While I always like an excuse to buy a new Festool, I need to pick the right tool for the job.
I just ordered a kreg k5 pocket hole jig.
Now I am going to make good use of my 3D printer and make a vac port to fit my ct. :-)
Domino will have to wait for another day...
Offline Sparktrician
« Reply #4 on: December 08, 2017, 08:13 AM »
If you're talking about making an adapter to fit your CT hose to the Kreg Jig, you might look at this page at Leigh Jigs.  Look under the accessory kit for the Super FMT.  There's a step adapter shown that I have used with my older Kreg Jig.  It joins the 27mm hose to the Kreg Jig without muss or fuss.  Leigh sells them separately, too.
- Willy -
Offline ear3
« Reply #5 on: December 08, 2017, 08:59 AM »
Another cheapo option is to get a 1 1/4 PVC pipe or elbow fitting and hollow out the interior with a dremel or similar tool to make the fit, like in this example:
http://festoolownersgroup.com/member-projects/a-drawing-table-and-two-chairs-for-my-4-year-old-granddaughter/msg60009/#msg60009
Kapex KS 120 w/UG Cart and Extensions • CXS Set • T18+3 w/Centrotec Installer's Set • PDC 18/4 • TS 75 • TSC 55 • HKC 55 w/250, 420 and 670 FSK rails • Carvex 420 w/Accessory Kit • Domino 500 Set • Domino 700 XL • OF 2200 w/Base Accessory Kit • OF 1400 • OF 1010 • MFK 700 EQ Set • LR 32 • MFS 400 w/2000, 1000, and 700 extensions • Rotex 90 • Rotex 150 • LS 130 • ETS-EC 150/5 • ETS 150/3 • Pro 5 LTD • RTS 400 • RAS 115.04 • RS 2 • HL 850 • Vecturo OS 400 • CT 26 w/Long-Life Bag • CT Sys w/Long-Life Bag • MFT/3
Offline TBR
« Reply #6 on: December 09, 2017, 12:50 PM »
—John
Would you recommend that I use some carpenters glue as well as the pocket screws?
  • Ardmore, PA
« Reply #7 on: December 09, 2017, 10:02 PM »
Yes, after leveling the broken dowels and scraping away any old glue and finish from the joint area.  Sizing the end grain.  But I’m not a good furniture repairman.  There are probably more than a few readers shaking their heads from side to side at my suggestion of using pocket screws.  (I’ve found that a butt joint that’s pocket-screwed and glued is very strong.  But strong enough for a chair?)
My step dad would have filed or sanded down the broken ends of the dowels and used a razor blade to scrape away any glue and finish where the pieces join. Then he’d disassemble all the joints and re-do them.  He didn’t own a pocket-hole jig.  He’d make new dowel holes.  It was labor intensive and he charged $20 or more per hour back when $20 was worth something, so his clients either had a sentimental attachment to the piece or it was a very expensive piece.  Otherwise it’d be more economical to buy a new piece.
—John
--Captain Beefheart
Offline epicxt
« Reply #8 on: December 10, 2017, 02:53 PM »
I'd also vote for a more secure option than just glueing and pocket screwing. Re-drill for new dowels at a minimum.
n = number of Festools I've got.  (n + 1) = Festools I want
Offline Gregor
« Reply #9 on: December 11, 2017, 01:33 AM »
Registering the domino on the stile using pencil marks looks possible.
Making a small shim/wedge from a scrap to clamp on the stile to give you an edge that is parallel to the rail (both the side and the end grain face) would also be a matter of minutes.
  • Ardmore, PA
« Reply #10 on: December 11, 2017, 09:20 PM »
In which case you might want to consider the DF700 after all.
http://festoolownersgroup.com/member-projects/chair-repair-with-domino-connectors/
—John
--Captain Beefheart
