ctfeet
Offline
« on: February 22, 2012, 09:50 AM » |
Hi all, got my Domino a couple months ago and have just started using it - so far it seems like a great tool as I'm sure you all know! I have seen one issue though and I don't know if it's normal or a problem. A few times already I have pushed the switch to the on position and the green plastic switch cap popped completely off. Not a big deal to put back on but this doesn't seem normal to me - especially for an $850 tool. So I ask - is this normal or have I been Diagnosed with Defective Domino Disease? Thanks for your help Stan
« Last Edit: February 22, 2012, 09:53 AM by ctfeet »
Sparktrician
Offline
Location: Northern Virginia (That's in the USA, Pilgrim!) Member Since: Dec 2009
« Reply #1 on: February 22, 2012, 09:56 AM » |
I rather suspect that you may not be pushing the switch completely on. When that happens and the switch isn't fully engaged, it will pop back off. Once I made the conscious effort to fully engage the switch, I didn't have the issue any more. This holds true for the RAS, as well. The switches are very similar.
- Willy -
MFT/3 x2, TS55, Guide Rails x3, Parallel Guide Set, CT22 w/Boom Arm, CT Mini, RO90, RO125, ETS125, RTS400, RAS115.04, C12 + Centrotec Imperial Bits, CSX Set, DF500 Domino Set, SCG-10, Domino Plate from RonWen, MFK700 Set, CMS-GE, OF1010, OF1400, OF2200 Set, LR32 System, MFS System, Syslite, Systainers, Sortainers, clamps.
Coming attractions: Carvex, Kapex, Ti-15, more "Stuff"-tainers...
Peter Halle
Global Moderator
Online
« Reply #2 on: February 22, 2012, 10:01 AM » |
Stan,
Sorry to hear about the switch, I remember one other member here having a similar issue. Probably not a bad percentage when you consider how many Dominos are out there.
Call the service department at 800-554-8741 and talk to them. Not only will they help you, but I predict that you will come out of that conversation feeling FesLove.
ctfeet
Offline
« Reply #3 on: February 22, 2012, 10:02 AM » |
When that happens and the switch isn't fully engaged, it will pop back off.  I don't mean the Domino doesn't stay running (though it doesn't), what I mean is the green switch cap comes completely off the machine which in turn causes the machine to stop running.
Sparktrician
Offline
« Reply #4 on: February 22, 2012, 10:04 AM » |
Much different issue. Call Festool's support line as Peter mentioned. They're wonderful to deal with.
- Willy -
fisheye
Offline
« Reply #5 on: March 06, 2012, 11:27 AM » |
I've had the same issue on my domino a few times, but it's been pretty infrequent so far. Intend to call it in soon.
agehall
Offline
« Reply #6 on: March 06, 2012, 12:11 PM » |
Not exactly related to the OPs actual problem, but I really wish Festool would redesign the switch on the Domino. I find it very difficult to operate and since I always hold the machine by the powercord, it's just way off for me.
TS55, CXS, DF500, CT-22, CT MINI, OF1010, MFT1080, VAC-SYS SE1 + SE2, CMS-TS55, KS120, RO150, RO90, LR-32 kit, 2xFS1400/2, FS800/2, FS1400/2 LR-32
fdengel
Online
« Reply #7 on: March 06, 2012, 01:35 PM » |
I hope I'm not reading that right. The power cord does not impress me as being a very good place to hold an electrical device, particularly not one with teeth. I used a Domino in a class I took (don't have my own yet), and iirc, I thought at the time that the switch would be better implemented as a trigger more like the one on a drill, underneath the handle -- rather than a switch that needed to be explicitly turned off... obviously, pull toward the handle not away from the cutter, or it would be harder to use instead of easier.
agehall
Offline
« Reply #8 on: March 07, 2012, 03:44 AM » |
I guess "power cord" isn't the right word. I usually hold on to the plug-it connector when plunging.
