sprior
Online
« on: February 18, 2012, 01:33 PM » |
Last weekend I bought the TS 55 EQ with the original justification of ripping and crosscutting pieces of plywood which were too big for my contractor sized table saw. My task for today is to rip some shelves from a piece of plywood, all the same width and while I can do it with the table saw I'd rather use the new toy. With the table saw I'd just set the fence to the right width and send the plywood through, but probably with some minor issues with the wood steering away from the fence. It appears that with the Festool saw you've got to measure/mark the width for a piece, put the guide rail in place, make the cut, then start measuring again. Is there a faster way that avoids measuring each piece individually? I don't have the parallel guide.
RvB
Online
« Reply #1 on: February 18, 2012, 01:50 PM » |
Make your own parallel guides  Greetz rick
ALLREADY GOT:Domino XL DF 700 - CS70 precisio - Kapex 120 EB - TS 55 EBQ Saw - EHL 65E - PS 300 EQ - OF 1010 EBQ - OFK 500 R3 - CTL 26 E - CTL Midi - BS 75 e-set - DTS 400 EQ - ROTEX 90 - FS SYS/2 - FS 1400/2 x2 - FS 800/2 - FS Bag
D 36 HW RS craftsman cleaning kit - D27/D36 portable cleaning kit - RO90 & DTS 400 abrasive sys - Festool & Protool tool-box - carpenter sys - Fein supercut sys - homemade drills&drivers sys - nailguns sys5 -SYS-CART RB-SYS
WORKIN' REALLY HARD FOR: UG-KA-SET - OF 1400 - ETS 125 - ROTEX 125 - Boom Arm - FS/2 3000
VictorL
Offline
« Reply #2 on: February 18, 2012, 02:00 PM » |
There are three options: 1. Mark each strip individually 2. Buy Festool parallel guides. (Tool nuts is very close to you) 3. Make your own parallel guides.
Cheers, VictorL
Jonhilgen
Offline
« Reply #3 on: February 18, 2012, 02:05 PM » |
Make some with a couple of drywall t-squares and some clamps. Do a search on the forum for homemade parallel guides for more ideas.
You're going to love your 55.
Jon
The more Festools I buy, the more money I earn. The more money I earn, the more Festools I buy. The more... TS 55, TS 75, Domino, CT22, OF 2000, C12, CXS, RAS, Trion, Fogtainers!
ccarrolladams
Offline
Location: Hollywood, California USA Member Since: Apr 2010
« Reply #4 on: February 18, 2012, 02:29 PM » |
 to The FOG, Sprior, Before Festool introduced the Parallel Guide Set with Extensions, I routinely needed to turn sheets of plywood into shelves of identical width using a TS55 and a Guide Rail. Although I now own a large shop with a Pressure Beam Saw, I still use my trusted method when the shelves need to be beveled. Since normally plywood shelves are made with the veneer grain running the long way, I start breaking down the sheet of plywood by carefully cross-cutting the sheet into pieces with parallel cut sides the length of the finished shelves. Step 2 is to use a sacrificial surface set at a convenient working height. At the end where I want to work I fasten a piece of scrap the same thickness as the shelves about the width of the shelves. Along the start end of the cut I fasten a long 4" wide piece of scrap at an exact right angle to the other piece of scrap but separated from the end scrap by just over the width of the shelves. At the far side or end of the cut I fasten still another long 4" wide piece of scrap, also separated from the end piece by just over the width of the shelves, at an exact right angle to the end scrap, but far enough from the start edge scrap the blank shelf plywood slides freely. Step 3 is to place a shelf blank sheet on the surface, snug to the start end scrap. Measure from the end scrap the width of the shelves, plus 2.2mm to allow for the kerf of the TS55 saw blade. Mark that at on both the start and finish end pieces of scrap. That mark is where the splinter guard of the guide rail needs to be. Clamp the guide rail so it stays on that mark. Step 4 is to fasten a small scrap of 12mm material to the start and finish long pieces of scrap snug to the far side of the rail away from the splinter guard. The way I use this fixture is to position a fresh shelf blank snug against the start scrap about 12mm beyond the rail's splinter guard. I make a clean-up cut of that factory edge of the blank. Then I move the blank's clean edge snug against the end scrap. From then on I hold the rail's far side against the small blocks make a cut and remove the new shelf. Then I keep doing the same thing until the remaining shelf blank is too narrow to support the guide rail. I solve that issue by using either the next blank or a finished shelf to support the rail and at the same time hold the last bit of blank snug against the end stop. Probably it has taken me longer to explain this fixture and method as it does to finish a batch of shelves. Long before I bought Festools I would use either double-headed nails or dry wall screws to temporarily fasten cleats and stops to my sacrificial surface, I continue to do so even when using guide rails, so clamps do not get in the way of using the TS55. Each time I set up this sort of fixture I place the end scrap a different distance from the end of the sacrificial surface, so the groove from the saw blade is not in the same place.
Mark Enomoto
Offline
« Reply #5 on: February 18, 2012, 04:13 PM » |
I learned this trick from the late John Luca's website, woodshopdemos.com. 1. Get some stair gauges http://www.amazon.com/Empire-Level-Brass-Stair-Gages/dp/B001CJZV20/ref=sr_1_11?s=hi&ie=UTF8&qid=1329594697&sr=1-112. Aluminum ruler and or something that you can clamp the stair gauges to. 3. Mark you cut 4. From the opposite side of the splinter guard set the distance from the edge of the rail to the end of the material, set the gauge and check it the ends of the rail. * I use the aluminum part of the rail to reference off of as the guiderail tends to get chewed up as you use the rail. Using any portion of the guide rail will give you a consisten point of reference... Can't find John's posting but if you haven't seen his site, its a wealth of good info not only on Festools but general woodworking. Good Luck
Brice Burrell
Online
Remodeling Contractor
« Reply #6 on: February 18, 2012, 07:35 PM » |
....Can't find John's posting but if you haven't seen his site, its a wealth of good info not only on Festools but general woodworking....
Just a quick note on John's site, unfortunately, it's not longer up.
Peter Halle
Global Moderator
Online
« Reply #7 on: February 18, 2012, 08:12 PM » |
Just a quick note on John's site, unfortunately, it's not longer up. Not intending to hijack, but John's domain was taken over by another woodworking entity. John's information is still out there on that site. Here is the url for John's stuff. What a guy he was! http://legacy.woodshopdemos.com/Peter
Corwin
Online
« Reply #8 on: February 18, 2012, 08:52 PM » |
... My task for today is to rip some shelves from a piece of plywood, all the same width and while I can do it with the table saw I'd rather use the new toy. ...
You can use a combination square (or two) to assist you in placing your guide rail on your workpiece. Measure from the back edge of your guide rail to the cut edge of the splinter guard to get the width of your rail, then set a combination square to the difference between that measurement and the width you want for your shelves. If you have a second combination square, use the first one to set the second to the same setting. Now you can use the combination square(s) to locate the back edge of your guide rail in relation to the edge of your material. This is a simple method to use until you make or buy some parallel guides...
Shirt Size: L
PaulMarcel
Offline
« Reply #9 on: February 18, 2012, 09:35 PM » |
Not intending to hijack, but John's domain was taken over by another woodworking entity. John's information is still out there on that site. Here is the url for John's stuff. What a guy he was! http://legacy.woodshopdemos.com/Peter Well there's a way to make a successful website... wait until someone who made one regrettably passes on then grab the domain. Instant traffic. At least they eventually put John's old information back up.
Visit my blog for Festool adventures Shirt size: L  Twitter: @HalfInchShy
Ken Nagrod
Restricted
Offline
« Reply #10 on: February 18, 2012, 09:41 PM » |
You could always see if you can get a hold of John's cd with the whole site's posts in PDF. Not sure if I'm allowed to copy mine for others, so if there's an attorney on the FOG, speak up.
Peter Halle
Global Moderator
Online
« Reply #11 on: February 18, 2012, 10:27 PM » |
Not intending to hijack, but John's domain was taken over by another woodworking entity. John's information is still out there on that site. Here is the url for John's stuff. What a guy he was! http://legacy.woodshopdemos.com/Peter Well there's a way to make a successful website... wait until someone who made one regrettably passes on then grab the domain. Instant traffic. At least they eventually put John's old information back up. Paul, I think that Woodcraft (?) now owns the site. Perhaps they purchased the site. Ken, I am not an attorney, but my guess is that would be copyright infringement. The DVD is available thru Woodcraft and John's wife does benefit. If anyone is interested: John's website on DVDPeter
Brice Burrell
Online
« Reply #12 on: February 18, 2012, 10:48 PM » |
Not intending to hijack, but John's domain was taken over by another woodworking entity. John's information is still out there on that site. Here is the url for John's stuff. What a guy he was! http://legacy.woodshopdemos.com/Peter Well there's a way to make a successful website... wait until someone who made one regrettably passes on then grab the domain. Instant traffic. At least they eventually put John's old information back up. I'm calling dibs on halfinchshy......
Ken Nagrod
Restricted
Offline
« Reply #13 on: February 18, 2012, 10:48 PM » |
Brice, that was good!  Thanks, Peter. Good find!
PaulMarcel
Offline
« Reply #14 on: February 19, 2012, 12:06 AM » |
Yeah, I did see that the DVD is for sale there and definitely that's a good thing for the family. I think Woodcraft could have maintained the site and put the DVD's ad there instead of pigeon-holing it behind a sidebar link.
Once I'm gone, Brice, you can have HalfInchShy! The rubber chicken on the bench, though, goes to Ken.
Ken Nagrod
Restricted
Offline
« Reply #15 on: February 19, 2012, 12:11 AM » |
...and the Saw Stop. I think Brice is still upset over the WCR-1000 hockey check.
sprior
Online
« Reply #16 on: February 19, 2012, 01:00 AM » |
Keeping this thread on track... I've been searching around on this forum and found at least 4 strong contenders for homemade parallel guides, but because of the way these discussions go it can be hard to follow and really determine what ultimately happened. Is there any agreement on what the top one or two designs are (with parts available in the US)?
ccarrolladams
Offline
« Reply #18 on: February 19, 2012, 05:10 AM » |
Apparently there is no consensus about home designed alternatives to Festool Parallel Guides with Extensions. Many of us have provided details our the approach each of us takes. Based upon your OP my impression is that you had a short deadline to make a batch of shelves. That being the case, my suggestion is to go to a local Festool dealer who has a Parallel Guide set in stock and purchase that. If the shelves are narrow, then you will need the extensions. The method I suggested to you can be built in minutes with the equipment you stated you already have available.
sprior
Online
« Reply #19 on: February 19, 2012, 08:53 AM » |
I guess I should have mentioned that I finished those shelves yesterday by measuring them individually and they came out great. My continued interest in this thread is in having a more efficient solution for next time.
ccarrolladams
Offline
« Reply #20 on: February 19, 2012, 08:28 PM » |
Hi Sprior, it is good to know you made all the shelves you needed. Now that you measured each individually and obviously cut carefully, you will better appreciate Festool solutions that are as accurate and also more time efficient. Although a lot of people have found home made solutions, so using expensive purchased components, I encourage everyone needing accurate repeated parallel pieces to seriously consider that set from Festool. Also, do not forget the extensions, because there is a savings buying them included. And, it might turn out the first job after buying the parallel set needs pieces so narrow the extensions are needed.
sprior
Online
« Reply #21 on: February 28, 2012, 10:42 PM » |
OK, I went and bought the complete parallel extensions set today. Does anyone have a good suggestion/part number for an english replacement for the metric rules on the guides? I'm assuming it'll be nicer to either stick english rules over the metric ones or peel the metric ones off and replace them.
Wonderwino
Offline
Location: American Bison Country Member Since: Apr 2008
« Reply #22 on: February 28, 2012, 11:10 PM » |
I have a Fastcap metric/standard tape that makes the conversion from inches to metric to set your parallel guides a no-math no-brainer. I have actually started to work in metric full time and it is much easier. http://www.mcfeelys.com/product/FSC-403/FastCap-MetricStandard-Tape-Measures
Water separates the people of the world; wine unites them.
sancho57
Offline
« Reply #23 on: February 29, 2012, 01:04 AM » |
Ive been learning the metric system since I got my festools. It actually is a lot easier to use then imperial measurements. For example if ya got something thats 430mm wide and ya need something that 314mm then you would just subj 314 from430..to easy. Its does some getting used to. I still refer to imperial all the time. I will break myself of it.
I use a metric folding rule I got from amazon and a true 32 tape measure I also got from amazon.
Shhhhhh Dont tell the wife butttttt I bought another…….
zapdafish
Online
« Reply #24 on: February 29, 2012, 03:26 AM » |
I use the TS55 to break down the sheets into manageable pieces for the tablesaw so I usually cut everything slightly oversized with the TS55 and then use the tablesaw to get them exact.
RonWen
Retailer
Offline
« Reply #25 on: February 29, 2012, 07:30 AM » |
Paul, When you go it will no doubt be from a hockey brawl...
andvari
Offline
« Reply #26 on: February 29, 2012, 11:10 AM » |
Metric is the better system so one might as well learn to use it.
sprior
Online
« Reply #27 on: February 29, 2012, 01:04 PM » |
It seems that my latest question was misunderstood - I didn't mean to ask whether or not I should switch to metric, I asked if anyone had converted their guides to imperial and what they had used to do it. I know how metric works, but I think in imperial and any plans I get are likely to use imperial, so for now the metric is an irritation point for me. I just got back from the local hardware store and looked for any tape measures with metric on them and they only had one junky looking one.
GreenGA
Offline
Location: Marlton, New Jersey, USA Member Since: Oct 2007
JR
« Reply #28 on: February 29, 2012, 01:21 PM » |
You will find 100's on Amazon.
I think you will also find the one from FastCap which has metric in both directions.
Never use a 2x4 when a 2x6 will do just as well
SYS-Lite, CMS/GE, TS55, KAPEX, MFT/3, CXS Kit, C15 Set, TI 15 Set, C12 Set, CT48 w/Boom Arm, HL850, RO90, RTS400, DTS400, LS130, DX93, RO150, ETS 150/3, RAS 115/4E, RS2E, Domino Classic, OF1010 EQ, OF2000E+, OF1400, MFS700, LR 32-SYS+97" rail, 2011 Centrotec, Zobo Forstner Bit Set, Guide Rail Kit, Parallel Guides, Tradesman Cleaning Set, Shinex, lotsa 'tainers (Sorts, Attics, Classic, New and Blue). Coming Attractions: MFK700 Kit, Workcenter, Domino XL Kit, Carvex 420 & Accessory Kit
sprior
Online
« Reply #29 on: February 29, 2012, 01:27 PM » |
Thanks GreenCa - it appears you're talking about metric/imperial tape measures. I'm really after the best self adhesive imperial rules to place over the metric ones on the Festool guides - do you have a recommendation for one of those?
