Pages: [1]   Go Down
  Print
Author Topic: Cutting steel with a jigsaw  (Read 2798 times)
Wendan20
Offline Offline
« on: January 27, 2012, 07:45 AM »
Hello,
Has anyone cut steel (4 mm thick) with a jigsaw? I'm told that this is possible. I'm going to place two windows in a steel boat and have to cut the wholes out first.
I'm curious if anyone has experience doing this and tips are more then welcome!
By the way I'm using a Trion PS 300.
Greetings,
Daniel
Alex
Offline Offline
« Reply #1 on: January 27, 2012, 08:02 AM »
It is perfectly possible to do so. I've done it sometimes on small strips. But if you want to do a big piece like an entire window, I'd take it slowly. Metal on metal becomes hot very fast so I'd suggest doing it in small increments and allow the blade to cool down in between. Normally with metal a cutting oil is used as a coolant, but with a jigsaw held vertically this might be less practical.
« Last Edit: May 04, 2012, 10:33 AM by Alex » Logged
Acrobat
Offline Offline
« Reply #2 on: May 04, 2012, 12:28 AM »
I tried and went through a few blades even expensive bosch ones, just getting to halfway across a benchtop, so I switched to a grinder, much faster and then smoothed the edge with a hand file. Stainless steel is tough to cut, cost me a few jigsaw blades!
My Festool addiction fed currently by: Kapex 120, TS55R, DF500 & Domino accessories set, Rotex 125, ETS 150/3, DTS400, C12, Ti15 Impact Driver, Midi vac, Surefix Oiling/waxing Kit, OF1010 Router, Kapex 120
Wish List? Carvex420??, Belt sander with frame and planer with frame.
Uncle Festool
CharlesWilson
Offline Offline
« Reply #3 on: May 04, 2012, 10:00 AM »
I have done it fairly often. Keep the speed down, put some oil on the blade every minute or so and you can extend the blade life. If you try to cut through hardened steel or cast iron, prepare to wear out many blades quickly.
I met someone the other day who routinely cuts into cast iron bathtubs. The combination of cast iron (which seems to have bits of carbide embedded in its structure) and porcelain limit him to very slow cutting. A blade lasts about 6 inches before needing to be replaced. He has tried carbide tipped blades, diamond tipped blades with no improvement.
Sounds like you are just doing steel plate, and should have no problem.
Charles
Charles Wilson
Tom Bellemare
Festool Dealer
Offline Offline
WWW
« Reply #4 on: May 04, 2012, 10:23 AM »
I've cut a lot of steel extrusions like angle iron and the ones that are used for shelving that have the vertically elongated holes that accept brackets for adjustable shelves. I think I've made about a dozen of those cuts with a Trion and the same blade.
I think Alex is right, if the blade has a chance to get too hot, it probably goes down hill fast. I learned the hard way to not wear flip flops while cutting steel. Those little bits that fall to the floor are really hot.
Tom Bellemare
Customer Svc
Tool Home
www.tool-home.com
512-428-9140
Michael Kellough
Offline Offline
Southern New York
« Reply #5 on: May 04, 2012, 12:32 PM »
Charles
The best blade for ceramic coated cast iron is this type.
Silicon carbide grit impregnated abrasive cut off blade.
I ripped a large old claw foot tub in two with this type blade in an old Skil saw.
Makes a lot of dust but since it cuts fairly slowly and there are no teeth to grab
the work you could make pocket cuts if small openings are required.
For the OP, an aluminum oxide grit blade would work for steel but it will throw
a lot of sparks and very offensive dust.
Tom Bellemare
Festool Dealer
Offline Offline
WWW
« Reply #6 on: May 04, 2012, 03:02 PM »
I remodeled our guest bath a few years ago and it had a ceramic coated cast iron tub that was wedged in between the two long walls of the bathroom. It never occurred to me to cut it. I got out a sledge and went to town on it. It was incredibly noisy and messy (ceramic shards) but after hitting it for a while, I broke chunks off and eventually broke it in half.
Tom Bellemare
Customer Svc
Tool Home
www.tool-home.com
512-428-9140
Peter Halle
Global Moderator
Offline Offline
WWW
« Reply #7 on: May 04, 2012, 05:29 PM »
As possibly an interesting side note - you decide - while I was at JLCLive! I was talking with a bunch of the Festool guys about the Trion and learned that the power train aspect of that saw is deemed "virtually bulletproof."  It seems that only a couple have ever made it back to service here in the US due to power train issues.  One that did need to be served was used constantly to cut 3/8" thick steel.
RonWen
Retailer
Offline Offline
Location: One of the Thirteen Original Colonies of the United States of America.
WWW
« Reply #8 on: May 04, 2012, 05:43 PM »
I have cut lots of steel using a Milwaukee Sawzall with Lenox bi-metal blades with no problems.
CharlesWilson
Offline Offline
« Reply #9 on: May 05, 2012, 03:10 PM »
Charles
The fellow I spoke with was aware of the grinding option, but desires to do it with the jigsaw and dust collection so that he doesn't have to spend extra time tenting off the area, and cleaning up afterwards.
Charles Wilson
Pages: [1]   Go Up
  Print
Jump to:
