Rick:
It really depends on how smooth your planed pieces are.
Let's assume it calls for starting with 60, like Alex suggests. I'd:
- use gear driven mode (mode switch to the left) with 60 until it looks "fuzzy" instead of seeing the planer marks,
- switch to RO mode (mode switch to the right) with same paper and give a once over,
- use gear driven mode (mode switch to the left) with 80 until it looks "fuzzy" instead of seeing the marks from the rougher grit,
- switch to RO mode (mode switch to the right) with same paper and give a once over.
At grits 100 and up, I'd stick to RO mode until about 500 or 1000 (polishing). Then I'd go back to strictly gear driven mode.
I realize your not going that high but if you were...
I don't think you save time by skipping grits or steps. It's too easy to change from step to step or grit to grit with this system.
