Zacharytanner
Offline
Location: Upstate New York...Adirondack Mountains Member Since: Nov 2009
« on: May 20, 2012, 05:57 PM » |
Hi Guys, Anyone using their Domino to plunge holes to attach a table top to the apron with clips? I always used my biscuit joiner...which died 2 days ago. If so do you know the depth setting off-hand? I am not near the shop to play around with it.
Thanks, Frank
Festool Kapex KS 120EB w/ 4 Blades Domino DF500 Set Domino DS Systainer 4,5,6,8,10 TS55 w/ FS1400 and FS2700 Rails MFT/3 with Accessories CT33E D36 Tradesman Trion PS300 Jigsaw RTS 400 EQ Orbital Sander RO 125 125 Abrasive Systainer with , 60,80,100,120,220 Grit Festool paper 2 Systainer Carts Festool T18+3 Kit CXS Kit with Centrotec Wood Bits ETS 150/3 150 Abrasive Systainer Festool Toolie RO 90 RO 90 Abrasive Systainer OF 1010 Router
Frank
jacko9
Offline
« Reply #1 on: May 20, 2012, 06:00 PM » |
Thanks, Frank
Frank, Most of the clips that I have been using call for a 3/8" deep slot 3/8" down from the top edge. I cut this with my table saw before assembling the apron. Jack
Zacharytanner
Offline
« Reply #2 on: May 20, 2012, 06:12 PM » |
Hi Jack, I used to do it that way, then I started using my Biscuit joiner to do neat recesses without having a full length cut along the whole apron. I have the table assembled and went to use my B-Joiner and realized it crapped out. Now I am waiting for the new trigger assembly.
Thanks, Frank
Frank
Alan m
Online
« Reply #3 on: May 20, 2012, 06:19 PM » |
i think you aare the only person to answer your own question. the settings are specifice to the hardware (bought or made) you have. i have used this tecnique with homemade buttons (rectangular blocks with a rebate on one side). it works great
barnowl
Offline
« Reply #4 on: May 20, 2012, 06:41 PM » |
Thanks, Frank
I use Z-clips that I buy from Rockler, and set the Domino height on the 28 mm setting. Works perfectly.
best wishes,
Steve
TS-55, assorted rails, Domino, Kapex, OF1400, ETS 125 EQ, RO 125 FEQ, RO 90, PSB 300 EQ, CT-22, CT-26, MFT-3
RL
Offline
« Reply #5 on: May 20, 2012, 06:58 PM » |
I like green.
jacko9
Offline
« Reply #6 on: May 20, 2012, 07:18 PM » |
I think you're overcomplicating it...use a domino!
[ ERROR: SPECIFIED ATTACHMENT MISSING ]
Nice
Zacharytanner
Offline
« Reply #7 on: May 20, 2012, 07:28 PM » |
DUH...Don't I feel stupid.Thanks
Frank
Zacharytanner
Offline
« Reply #8 on: May 22, 2012, 04:51 PM » |
Thanks Barnowl....Works like a charm
Frank
Frank
